Phanteks Enthoo Evolv ATX - Page 16 - Overclock.net - An Overclocking Community
post #151 of 1989 (permalink) Old 01-19-2017, 01:29 AM
Brando465's Avatar
Rep: 0
Hey guys,
Late response but the build has taken longer than anticipated!
About 2 months ago I decided to make the jump from air cooling with a H60i to water cooling. After much procrastination I finally did some research on new cases and water cooling setups. It didn't take long to end up at the Enthoo Evolv ATX Tempered Glass. I then spent 2 weeks looking into builds people had done in them (which took me to here). Some final last minute changes were made with the help to some of the fellow members here.
I made 3 trips to my local PC store in a week to get the parts. Originally I thought it would have only taken a few days to build but I was wrong. It has ended up being a week and a half (tear down to all testing complete).
I went with a PE 240 in the front and a SE360 in the top (doing the fans in the roof mod). I spent a few hours with a dremel cutting out the channels from the top of the case and the rad bracket. After the multiple test fits the fans were able to fit. From there I started to re-assemble the case and start putting the components in. Once all the parts were in it was time to test fit and bending of pipes. That was done over a few nights after work. Finally the system was flushed and filled. First shot... NO LEAKS! thumb.gif
With the first stress test and the temps were horrible (almost 80 C). I spent the next 4 nights playing around with fans/speeds/and the case. I worked out that the case was not very free flowing. With the top and front panel off the temps dropped by 20 C. The solution ended up being turning the fans up a little more and sealing the top off with tin foil (something I saw on here). The temps became acceptable (there must have been a loop of hot air coming back down). So the other night I pulled the plastic off the glass and sat back and enjoyed the amazing look of a custom hard line water cooled PC with a glass panel.
PC Specs:
- i5 2500K (OC to 4.2ghz)
- 16GB RAM
- Gigabyte GA-Z68-UD3P-B3
- XFX Radeon R9 290
- Samsung 128GB SSD
- 2 x HDD (1TB & 2TB)
- Seasonic 750W
Water Cooling:
- EK-XRES 140 DDC 3.2 PWM Elite Pump/Reservoir Combo
- EK Supremacy EVO CPU Waterblock (Acetal/Nickel)
- EK CoolStream PE 240 Dual Radiator
- EK CoolStream SE 360 Slim Triple Radiator
- EK 12mm Fittings (Black)
- EK R9 290X Water Block (Acetal/Nickel)
- Thermaltake Riing 12 High Static Pressure 120mm
Photos:
Brando465 is offline
post #152 of 1989 (permalink) Old 01-19-2017, 02:52 AM
b0gd4n's Avatar
Rep: 0
Originally Posted by Toan View Post
Does anyone know if I can fit 2 EK XE 360mm in this case? I've searched online everywhere and I can't seem to find the answer. The closest picture I can find that MIGHT answer my question is posted below.
I want to go with the same setup as pictured, EK XE 360mm up top with AP60s in push and an EK XE 360mm up front with AP60s in push behind the front cover. As far as I can see from the pics the front radiator does go down into the basement of the case. Maybe I have to go with EK's slimmer 360mm radiator up top to be able to fit the 360mm XE in the front?
Hey there.
I'm the guy with the build pictured there (here are a few more pics of the build http://imgur.com/a/aL9t2
Not sure if you got you're answer, as I see this thread got quite big - but I was wondering the same thing before starting the build.
I think I found someone that did manage to get 2 360s in there, but he had to mod the case somehow.
I decided to stick with 1 360 (a slim SE version, as there's not much top clearance) and a fatter 280 in the front. The front rad goes into the basement, but really don't see how you can fit a 360 there, with a 360 on top as well.
b0gd4n is offline
post #153 of 1989 (permalink) Old 01-19-2017, 03:39 AM
doyll's Avatar
Rep: 1696 (Unique: 938)
When using fans / radiator in top of Evolv all opening between motherboard compartment and top must be blocked to stop the air going through fans / radiator from circling back into motherboard compartment.
Vent area of Evolv ATX can be almost tripled by simply removing 4 screws, popping top off and setting it back on.
https://www.overclock.net/t/1418637/official-case-phanteks-case-club-for-lovers-owners/13240_20#post_25198233
Details of where screws are and blocking openings in radiator / fan mounting tray.
doyll is offline
post #154 of 1989 (permalink) Old 01-19-2017, 10:55 AM
0451's Avatar
Rep: 40 (Unique: 35)
Black aluminum foil tape is wonderful for sealing this case. What are your water temps under load?
Originally Posted by b0gd4n View Post
Hey there.
I saw your build on PC Wars and it inspired me to get an Evolv ATX and go watercooling. My build evolved into something original but the goal was for it to look like yours but red and black.
Smallblock Power
I7 7700k
Asus Maximus IX Formula
ATI Radeon Vega 64
Corsair Vengeance LPX 3733
Samsung 960 Pro
EVGA 1200P2
5 Radiators
2 Pumps
9 Fans
Phanteks Enthoo Evolv ATX TG
Samsung Cf791 34" Curved Ultrawide
Keyboard
Hall Effect RGB
Mouse
Razr Diamondback RGB
0451 is offline
post #155 of 1989 (permalink) Old 01-19-2017, 11:36 AM
doyll's Avatar
Vinyl tape of match or complementary color works well too
Anything works as long as all the openings are blocked off does the job.
I'm an air-head now, except for a be quiet! Silent Loop 280mm on my Luxe. blushsmiley.gif
Only reason I even tried it was I got it for a very good price, so if I hadn't liked it I could have sold for what I had into it. I've tried a few other AIO/CLC coolers .. all were CLC and I couldn't get them out of my house fast enough. But the Silent Loop 280 is nice and quiet. I just wish it would support a GPU waterblock. But I don't know if it's pump has enough power to push coolant through a full cover water block.
doyll is offline
post #156 of 1989 (permalink) Old 01-19-2017, 01:39 PM
Optics Fiend
Blackops_2's Avatar
Rep: 81 (Unique: 66)
Tag.
So what if you remove the PSU cover entirely? Could you not fit a 360 there? I guess it would easily clear up space for a 280 or 240.
Currently i'm planning on building new this summer when Vega releases. I'd like to at least have 120x6 or more incase i want to through another GPU in the build down the road.
Is there anyway to move the top rad over some to clear a 120 on the exhaust?
Green Envy
(12 items)
Purple Haze
(12 items)
i7-3770k @ 4.5ghz
Gigabyte G1.Sniper 3
EVGA 780 Classified
EVGA 780 Classified
16GB GSkill Ripjaws DDR3 2133
WD Raptor
Seasonic 850w M12II
Cooler Master Glacer 240L
Phantek Enthoo Pro
Operating System
Windows 7 64-Bit Home premium
Asus VG248QE
Keyboard
Logitech G15
Ryzen R5 1600x
Fatal1ty AB350 Gaming-ITX
Diamond 7970
G Skill DDR4 3200
Western Digital Black
Samsung 850 Evo
Corsair SF600
Black Ice Nemesis L-Series 240 Stealth
EK-FC7970 CSQ
Mayhems X1 UV Purple
Fractal Design Define S Nano
Blackops_2 is offline
post #157 of 1989 (permalink) Old 01-20-2017, 01:46 PM
tucuman's Avatar
Rep: 0
Hi, everyone. This is my first-time water cooling so I bought the EK Extreme 360 kit. I'm planning to install the radiator in the front but I'm not sure where to put the pump. Do you guys have any recommendation on what is the best way to do my loop? I wanted the pump at the button compartment.
tucuman is offline
post #158 of 1989 (permalink) Old 01-20-2017, 02:37 PM
paskowitz's Avatar
Rep: 58 (Unique: 45)
Well, you could mount it in the bottom chamber DIY, or get an EK top, attached it to the res and then mount the res to the radiator via a mounting bracket. The latter is what most people do.
Phanteks Enthoo Evolv Tempered Glass: Anthracite | i7 4790K: 4.8Ghz/1.33v | EVGA GTX 980 Ti Classified: 1535/8100Mhz | KLEVV Genuine: 2666Mhz 16Gb DDR3 | Asus Maximus VII Formula | EVGA G2 850W | Samsung 950 PRO 256Gb NVMe SSD | Samsung 850 EVO: 500Gb SSD | HGST Deskstar NAS: 6Tb | Acer Predator X34 | CPU Delid w/CLU on die&IHS | CLU and Fujipoly pads on GPU | Watercool Heakiller IV Pro | EK-FC780 GTX Classy | Hardware Labs Nemesis 280 GTS Xflow | Hardware Labs Nemesis 360 GTR | 6x Corsair ML Pro 120 | 2x Corsair ML Pro 140 | 17995 3DMark Firestrike (Top 100 WW w/4790K&980 Ti) | NZXT HUE+ | Phanteks RGB LED strips | MNPCTech metal cable combs | Primochill carbon fiber sleeving | Viviid Vinyl Epoxy carbon fiber vinyl wrap
paskowitz is offline
post #159 of 1989 (permalink) Old 01-20-2017, 04:47 PM
0451's Avatar
Just drill some holes in the bottom and mount it. You may need to mount the pump sideways because the inlet tube goes straight up.
Smallblock Power
I7 7700k
ATI Radeon Vega 64
Samsung 960 Pro
EVGA 1200P2
5 Radiators
2 Pumps
9 Fans
Keyboard
Hall Effect RGB
Mouse
0451 is offline
post #160 of 1989 (permalink) Old 01-21-2017, 01:37 PM
Petrolhead
MoDeNa's Avatar
Rep: 7 (Unique: 6)
Hi all,
Surfing on the net searching top mods for the Phanteks Enthoo EvolV ATX Tempered Glass case to improve my rig temperartures finally I decided to go one step further and design mine, as many of you guys did before.
Using the same config, of course, I have to say that the gain is much noticiable, specially with configs with AIO kits or radiators in top, with a decrease of around 12º - 15º Celsius in my processor temperatures, and an overall improvement to the other components.
I would like to recommend Phanteks that they could offer as an accesory a similar top panel, in order to satisfy this case customers and potential ones, because, actually, in my opinion, this is the best good looking case in the market.
My rig specs:
i7 5820K @ 4,0 GHz
Corsair H110 GTX
Asus X99A - USB 3.1
16 GB RAM DDR4 Kingston Hyper X 2.667 MHz
SLI Geforce GTX 1070 Founders Edition
Samsung SSD 850 EVO 500GB
2 x Western Digital Red Nas 2 TB
Seasonic Platinum 1200w
These are the pictures of the build and the mod:
Kind regards,
R9 3950x
(10 items)
AMD Ryzen9 3950x
Gigabyte X570 Aorus Xtreme
EVGA RTX 2080 Ti XC Ultra
G.Skill 32 GB (2x16) 3200CL14 @ 3733CL16
Corsair MP600 1TB m.2 SSD
Seasonic 850w Prime Ultra Titanium
Phanteks Enthoo 719
Dell Alienware AW3418DW
Keyboard
Corsair K63 Wireless
Mousepad
Logitech G900 Chaos Spectrum
MoDeNa is offline
