Phanteks Enthoo Evolv ATX - Page 90 - Overclock.net - An Overclocking Community
post #891 of 1989 (permalink) Old 05-03-2017, 02:58 AM
doyll's Avatar
Rep: 1682 (Unique: 933)
Originally Posted by kevindd992002 View Post
When did you buy your case? I've heard that Phanteks upgraded the fans on the Evolv ATX from the SP to the MP but their website still doesn't reflect the change.
The replacement fan for PH-F140SP is not a PH-F140MP fan.
While they look like PH-F140MP they are not the same .. nor do they have same specifications. Best I can tell they are no-name / no-model number fans that have PH-F140SP outer housing and motor with a PH-F140MP impeller.
I have not been able to get any of these MP impeller case fans, but Phanteks told me
F140MP_BK (3Pin for case installation)1200RPM +/- 250 rpm.
1.31 mmH2O
24.2 dBA.
Which is rpm specificaton of PH-F140HP_ii and PH-F140MP at 1200rpm
and
CFM will be the same as MP
I think that means at PH-F140MP at 1200rpm performs the same as these new case fans .. which is about 66cfm
PH-F140MP are PWM controlled 500-1600rpm; 68.1cfm; 17-25.3dB(A); 1.62mm H2O
"No Name/No Model #" are variable voltage 1200rpm; xx.xcfm; 24.2dB(A); 1.31mm H2O
CoolingTechnique tested the PH-F140HP_II .. the same fan in round housing versus square housing on PH-F140MP
CoolingTechnique testing data is at 1222rpm there is 68.1cfm, and 1.71mm H2O
CoolingTechnique testing data is at 1416rpm there is 79.9cfm and 2.286mm H2O (1416rpm is below 1600rpm spec because load resistance lowers fan speed and all specs are +/-250rpm)
PH-F140MP specification data is at 1600rpm there is 68.1cfm and 1.61mmH2O .
Phanteks shows PH-F140MP and PH-F140HP_II having same performance, but CT test data is radically different from Phanteks data.
I tried PH-F140MP on CLC radiator and the worked quite well. I have not compared them on my Siltent Loop 280mm cooler but suspect they would work well.
I'm trying to get a couple of these newer 'no-name/no-model #' fans to test.
doyll is offline
post #892 of 1989 (permalink) Old 05-03-2017, 09:55 AM
kevindd992002's Avatar
Rep: 85 (Unique: 67)
and
Ok, I see. Thanks.
@ciarlatano
FYI.
My Rig
(14 items)
Intel® Core™ i7-8700K
ASUS ROG MAXIMUS X CODE
EVGA GeForce GTX 1080 Ti FTW3 GAMING
G.SKILL F4-3200C14D-16GTZKW TridentZ Series
Samsung 970 EVO NVMe (OS Drive)
Samsung 850 EVO
SeaSonic Platinum-760 (SS-760XP) Power Supply
Custom Watercooling Loop
Phanteks Enthoo Evolv ATX Glass
Operating System
Microsoft Windows 10 Enterprise
Dell S2716DG Gaming Monitor
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
kevindd992002 is offline
post #893 of 1989 (permalink) Old 05-04-2017, 11:10 PM
Linux Lobbyist
realtomatoes's Avatar
Rep: 1 (Unique: 1)
Originally Posted by dlewbell View Post
As Ciarlatano mentioned, top 360 with front 280 sounds like a good idea. I don't have any water cooling experience, but just calculating based on radiator area leads me to believe the difference between a 360 & a 280 should only be about 10% or so.
360*120=43,200mm^2
280*140=39,200mm^2
i got an xe360 in front and an alphacool 280 on top.
i would recommend placing the 360 in front, get fresh air for your largest rad and the 280/240 on top.
realtomatoes is offline
post #894 of 1989 (permalink) Old 05-04-2017, 11:33 PM
But then the 360 top/280 front is better looking.
My Rig
(14 items)
Samsung 850 EVO
Operating System
Keyboard
Ducky Shine 3
Mouse
Roccat Savu
Mousepad
Steelseries Qck
post #895 of 1989 (permalink) Old 05-05-2017, 12:06 AM
kaiqi07's Avatar
Rep: 20 (Unique: 19)
Just collected my newly powder coated and cut ventilation holes of my evolv atx front panel. Had sent the whole case's alu panel to be powder coated
In Progress: Project Rampage II
Project Rampage Build Log
Intel i7 3930K
ASUS Rampage IV Extreme
Gigabyte GTX 780TI 3 Way SLI
Seagate 3TB Barracuda
Kingston HyperX 3K 120 SSD X 3
Caselabs STH10
Seasonic X1250
kaiqi07 is offline
post #896 of 1989 (permalink) Old 05-05-2017, 02:59 AM
kaiqi07's Avatar
Took the panel outs and inspect. Very good powder coats done by the powder coating company. Block off the screw holes to prevent the coats go into the thread holes.
Will head home to fix it back to the frame.
Intel i7 3930K
Caselabs STH10
Seasonic X1250
kaiqi07 is offline
post #897 of 1989 (permalink) Old 05-05-2017, 08:11 AM
Mhazz's Avatar
Rep: 4 (Unique: 3)
THAT looks AWESOME... This design suit nearly perfectly that case ! Really good job.
White is not my favourite color for a case (because of my dirty gardener hands biggrin.gif) , but I can't wait to see it mounted.
Well done, sir !
PS : I hope it will help for temps and airflow, I think that was the basic purpose rolleyes.gif
Mhazz is offline
post #898 of 1989 (permalink) Old 05-05-2017, 08:20 AM
kaiqi07's Avatar
Well done, sir !
Thanks for the compliments. Was actually gonna wait for the Mass Order for the modded panels. But i don't wish to have the same panel as other so had to think of other designs myself. Saw the angled tempered glass and edges of the panels gave me the idea that hex is the way to go.
For my past few builds, white has always been my case Color. When I was choosing Color for the powder coating, I had a urge to go deep red haha. But chose white as the base Color. So right now I will decide what Color should I paint for the Fan grilles.
Intel i7 3930K
Caselabs STH10
Seasonic X1250
kaiqi07 is offline
post #899 of 1989 (permalink) Old 05-05-2017, 09:59 AM
aberrero's Avatar
Rep: 39 (Unique: 34)
Are you painting the rest of the case as well?
aberrero is offline
post #900 of 1989 (permalink) Old 05-05-2017, 10:13 AM
kaiqi07's Avatar
nope. dont really like full white rigs. I love the contrast of black and whites. Thats what i did with my previous build.
Project Rampage: Corsair Obsidian 800D
Project Rampage II: Caselabs STH10
*for the caselabs build i never took a completed full tower photo
Intel i7 3930K
Caselabs STH10
Seasonic X1250
kaiqi07 is offline
