First Custom loop - Overclock.net - An Overclocking Community
First Custom loop
post #1 of 30 (permalink) Old 06-27-2016, 07:01 AM - Thread Starter
r_aquarii's Avatar
Rep: 2 (Unique: 2)
hi all, i will be upgrading my casing from silverstone ft02 to thermaltake core P5 and will be doing a red/white theme.
need some advise on WC parts.
current build:
NZXT Hale 90 1000w/SST 850w strider gold
Intel skylake 6700k
gigabyte Z170 gaming 7
corsair lpx 16gb ddr4 3000mhz
gigabyte r9 390 (will be upgrading to sli 1080 once price stabilize)
Samsung 950 pro 500gb
Corsair h80i V2
cheap 27" 1440p monitor (waiting for acer x34p)
i will be purchasing those parts from performance-pcs
RAD: XSPC RX480 V3 - white/alphacool-nexxxos-ut60/HARDWARE LABS BLACK ICE SR2 (pls help me decide on which has a better performance)
pump/res: XSPC D5 PHOTON 270 RESERVOIR/PUMP COMBO PWM with aluminum screw ring (any fitting issue with TT P5?)
WC block: XSPC RAYSTORM PRO - White (should i get EK Z170X Monoblock? im concern about future upgrade)
fitting: RIGID REVOLVER COMPRESSION FITTING 3/8" X 1/2" STRAIGHT KNURLED 10 PACK - ANODIZED RED
tubing: PRIMOCHILL 1/2IN RIGID PETG TUBING - 36IN - CLEAR (12 PACK)
coolant: MAYHEMS PASTEL ICE WHITE CONCENTRATE - 250ML (is 250ml enough?)
drain plug: XSPC BALL VALVE - CHROME (i think i need other fitting as well, pls advise)
tools: XSPC ACRYLIC/PETG EASY CUT / EASY BEND TOOLKIT
extra: DARKSIDE 480MM QUAD RADIATOR GASKET (do i need this?)
extra: SATA-2-MOLEX ADAPTER (for D5 pump to sata)
i'm open to any suggestion and add-on for my build.
thanks in advance.
r_aquarii is offline
post #2 of 30 (permalink) Old 06-27-2016, 07:11 AM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
See below...............
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 30 (permalink) Old 06-27-2016, 07:13 AM
Overclock Failed...
Uh, 36 feet of tubing is kind of overkill? I find that 6 foot lengths result in less "wastage" when cutting to size.
The Rad gasket isn't necessary but is nice for making a good seal between the rad and case or fans and rad. It can also serve as a template for cutting.
post #4 of 30 (permalink) Old 06-27-2016, 07:22 AM - Thread Starter
r_aquarii's Avatar
Rep: 2 (Unique: 2)
its difficult to get tubing here in singapore and since its my first loop, i expect alot of wastage and i want to keep some spare for future usage
post #5 of 30 (permalink) Old 06-27-2016, 07:43 AM
Overclock Failed...
36 feet is a lifetime supply.......
Stop looking at computer sites. Acrylic tubing (cast and extruded) is available form online plastic retailers.
post #6 of 30 (permalink) Old 06-27-2016, 08:32 PM - Thread Starter
r_aquarii's Avatar
Rep: 2 (Unique: 2)
will cut down on the number of tubing.
any other advise?
post #7 of 30 (permalink) Old 06-27-2016, 11:54 PM
Overclock Failed...
Make sure the bending rubber in the tool kit is for the size tubing you're buying.
You need fans. And they will have a great effect on how much heat will actually be removed from the system vs how much noise the WCing system will make. See This For Some Information
A 4 x 120 rad is kind of overkill, unless you plan on using quiet, low pressure fans.
I don't know how experienced you are, but you may want to consider:
Learn to crawl before you walk, and learn to walk before you run.
Build the new computer.
When it's up and running to your satisfaction, then add the WCing using soft tubing.
When that's all OK switch over to hard line tubing.
post #8 of 30 (permalink) Old 06-28-2016, 12:34 AM - Thread Starter
r_aquarii's Avatar
Rep: 2 (Unique: 2)
4x120 rad will be using for nvidia 1080 sli as well
i have 4 gentle typhoon with me and will be using it to connect to nzxt grid+ v2
post #9 of 30 (permalink) Old 06-28-2016, 02:20 AM
Overclock Failed...
What's the Corsair H80i for?
post #10 of 30 (permalink) Old 06-28-2016, 03:55 AM - Thread Starter
r_aquarii's Avatar
Rep: 2 (Unique: 2)
that is on my current build. intend to keep it for spare if i go for full open loop
if i go for 3x120 or 3x140 rad. will it be sufficient for 6700k with OC and SLI 1080?
