[Official] Alphacool Eisbaer Thread - Page 12 - Overclock.net - An Overclocking Community
post #111 of 215 (permalink) Old 06-09-2017, 02:39 AM
orbitalwalsh's Avatar
Rep: 19 (Unique: 14)
Originally Posted by hurricane28 View Post
No wonder the pump was making this terrible noise.. the loop is full of air and its not even topped off with coolant:
Guess i have to go to the store and buy myself some distilled water to top it off...
I was planning to buy Mayems aurora blue with some clear tubing but since that all went south pretty fast that ship has sailed unfortunately because Alphacool decides that Mayhems coolant damages water cooling components without any proof..
People that are interested can go look for themselves how Alphacool is treating their customers: https://www.overclock.net/t/1624192/alphacool-pump-vpp755-review-of-noise-issues-and-problems
Pretty disturbing and worrying if you ask me.. and makes me think twice on buying Alphacool products again..
you mounting to AM4 ? if you are HEADS UP! nut is in wrong place - Yes i Know instructions tell you to mount underneath but unit doesn't make enough contact with the chip set so you are meant to mount the nut between the spring and plate for pressure. The stand along AM4 kit comes with a thick washer so you can still have the nut underneat to act as a guide
also Aurora is not support by any brands, thats the show piece fluid from Mayhems and they even state it for show purposes .Mayhems Pastel is a different matter biggrin.gif
orbitalwalsh is offline
post #112 of 215 (permalink) Old 06-13-2017, 06:15 PM
wywywywy's Avatar
Rep: 0
Has anyone used both the old Eisberg and the new Eisbaer?
How do the two compared, especially with regards to noise and reliability?
My Eisberg is dying - super low flow, sometimes none at all, and the noise is getting louder and louder. And I am thinking of replacing just the pump/block with an Esibaer solo.
Thanks.
wywywywy is offline
post #113 of 215 (permalink) Old 06-14-2017, 09:58 AM
Dasboogieman's Avatar
Rep: 106 (Unique: 83)
Thanks.
I just ripped apart my Eisbaer and reused the 360mm rad for my custom loop.
Dasboogieman is offline
post #114 of 215 (permalink) Old 06-14-2017, 04:11 PM
diggiddi's Avatar
Rep: 107 (Unique: 86)
I have kinda the same issue with my eisberg which failed, I need to hook it up to my 240 Glacer eventually,
not 100% sure what I need to do that
But can it run.... Angry Birds???
About the NVidia GTX 970
"When comes down to it, it's really a $250 card with lies printed all over the box."--Rexer
diggiddi is offline
post #115 of 215 (permalink) Old 06-18-2017, 01:42 AM
Overclocker
hurricane28's Avatar
Rep: 155 (Unique: 92)
What a pile of garbage the Eisbaer 360...
I tried EVERYTHING to get rid of the air bubbles but there is no way of getting them out.. Its making a very annoying sound and i took the cooler out of my case and shook it pretty hard which got rid of the air but now its back..
I will contact my retail store if i can get a new one or my money back as i can't even change the coolant without voiding my warranty..
I really wish i spend a little more and got myself something proper like EKWB kit..
hurricane
AMD RYZEN 2600x
Asus Crosshair hero 7
MSI GTX 970 gaming 4G
G.Skill F4-3200C14D-16GFX
Samsung 950 pro, 256 GB
Cooler Master V850
Alphacool Eisbaer 360
Phanteks Enthoo Luxe tempered glass
Operating System
Windows 10 Pro
Asus VG248Q
Keyboard
Logitech G910
Mouse
Logitech G900
Audio
logitech Z-2300
hurricane28 is offline
post #116 of 215 (permalink) Old 06-29-2017, 03:58 AM
wywywywy's Avatar
Rep: 0
Anyone knows how to open this up please?
I want to open it to clean the window and the pump.
I have removed the 4 copper screws on the bottom, and cleaned the copper plate already, but I don't see a way of disassembling the rest?
Thanks.
wywywywy is offline
post #117 of 215 (permalink) Old 06-29-2017, 06:22 AM
Thanks.
Mayhems blitz kit! sorted biggrin.gif no stripping any part needed for any thing watercooling related
post #118 of 215 (permalink) Old 06-29-2017, 07:58 AM
wywywywy's Avatar
Rep: 0
There's bits that I want physically scrub off unfortunately!
On that note, Blitz says it can't be used on plated products - what's up with that?
wywywywy is offline
post #119 of 215 (permalink) Old 06-29-2017, 08:08 AM
Blitz is mildly corrosive, that is why its so good at cleaning. Pretty self explanatory why it shouldn't be used on plated goods.
I ditched the Eisbaer for a full custom loop as soon as I could. I don't trust AIOs anymore, too many things that can go wrong with no way of being corrected.
You do know that resevoir has a fillport right? its that little cap with the flathead screw on it next to the 2 hoses going in to the CPU. Its even marked "fillport" on mine. You can literally unscrew it, fill it up, screw it back and fire it up to let the coolant circulate.
post #120 of 215 (permalink) Old 06-29-2017, 08:12 AM
wywywywy's Avatar
Rep: 0
I have very very limited space, hence I have to use the Eisbaer.
I want to go proper custom loop eventually, but I'll need a lot of custom parts designed and machined, so it will take a long time.
wywywywy is offline
