[Official] Alphacool Eisbaer Thread - Page 21 - Overclock.net - An Overclocking Community
post #201 of 213 (permalink) Old 03-03-2019, 06:23 AM
os2wiz's Avatar
Rep: 63 (Unique: 41)
Quote: Originally Posted by Sheytan View Post
whould you guys recomend eisbaer 420 over ekwb phoenix 360 or is the ekwb aio better?
The EKWB Phoenix 360 is end of life. No longer available for sale. I know not why.
Technology is NOT a liberator . Whom technology serves is a class question.
Technology wielded by the capitalist class benefits only the exploiters.
Technology wielded by the working class will serve ALL Humanity.
Ryzen 9 3900X at 4.275GHZSamsung 970 EVO m.2 NVMe 1TB
AMD Radeon VII gpu, MSI X570 MEG Unify motherboard, AlphaCool Eisbaer 280 Extreme
32GB G.skill TridentZ NEO DDR4 3600mhz CL16-16-16-36 1.5V
os2wiz is offline
post #202 of 213 (permalink) Old 03-03-2019, 07:11 AM
gothicVI's Avatar
Rep: 0
Quote: Originally Posted by os2wiz View Post
That is baloney. I have had the Eisbaer 360 for over 2 years. It is quiet. Only when I use the bios to max out all my case fans do I have any significant noise and that is not primarily the Eisbaer. I have yet to refill it bit it is not abig deal. The cap for the reservoir is conveniently located. I have heard no breast beating from EKWB aio users. I am not aware they have a 360 or 420mm AIO. Alphacool does have the 280mm Eisbaer Extreme AIO with a professional quality pump, water block, and a thick radiator. It has gotten good reviews. It is expensive though and runs about $279. Probably worth every penny of it.
Good for you. Still, I wouldn't dare to call it baloney
Mine started becoming noisy and you'll find a lot of similar reports online. Also refilling is a pain in the a** w.r.t. open loops or constructions with fill ports on the highest point of the loop. I never disputed the good cooling capacity - that after all was the main reason for me for buying it in the first place. Still I'd not buy it again. It is good cooling wise yes also the rads are great (I'm still using all Alphacool parts now), but there are issues (e.g. refilling) and it is more expensive than comparable aios (see e.g. Gamers Nexus last roundup).
gothicVI is offline
post #203 of 213 (permalink) Old 03-06-2019, 01:19 PM
nisc's Avatar
Rep: 0
Has the dc lt pump been revised? Are there batchs of the same model?
nisc is offline
post #204 of 213 (permalink) Old 05-21-2019, 12:34 PM
CelticGamer's Avatar
Rep: 2 (Unique: 2)
Forgive my ignorance, I'm new to AIO's and have a few questions.
1. The Eisbaer 360mm is listed being "expandable". I understand that means it's compatible with some of their GPU waterblocks. What else does that cover? Other brands of waterblocks? Full coverage one's meant for Custom loops? What all could be used with this unit?
2. Do many of you run push pull fans on this AIO? Any issues?
3. How long could one expect to go before needing a refilling?
Main Gaming Rig
(9 items)
Alienware Alpha R1
(5 items)
Ryzen 2700X
MSI X470 Gaming Pro Carbon
ROG STRIX RTX 2080
16GB ADATA XPG Z1 DDR4 3000mhz @ 3466mhz
WD BLUE 1TB
Thermaltake Grand Toughpower RGB 750W GOLD
Corsair H60
Corsair 570X RGB
Operating System
Windows 10
Intel i7 4785T
Nvidia 860M 2GB+BlindRageVbios+335Core+650Memory
16GB G.Skill Ripjaws
1TB 7200RPM
Operating System
Windows 10
CelticGamer is offline
post #205 of 213 (permalink) Old 06-22-2019, 04:55 PM
Rep: 0
THIS is how you bleed an Eisbaer or Eiswolf
THIS is how you bleed an Eisbaer or Eiswolf. I have an Eisbaer on my CPU and Eiswolf on my Vega 64
Keep the radiator hooked up, just use the quick disconnect extensions and the flow indicator as a temporarily inserted bleed point.
Remove everything from the case and run the pump.
Shake rotate, turn and invert all the components except the flow indicator, keeping it as the highest point for the air to collect.
Open the extra plug at the top of the flow indicator, fill with fluid and repeat.
remove the extra extensions and flow indicator, or keep it inline if you want.
Blankmang is offline
post #206 of 213 (permalink) Old 06-22-2019, 06:21 PM
os2wiz's Avatar
Quote: Originally Posted by Telstar View Post
uhm… I came here because I'm considering the new eisbaer extreme core, which is a 280 rad, pump (with good specs) and tank under one armor… and pair it with EK velocity block.
They took a similar approach to EK MLC with the 2 pieces design.
I guess i'll go fully with EK instead hen they restock the core-rad parts.
I just bought the Eisbaer Extreme 280 a week ago. Aside from going crazy trying to fit it in my Corsair Graphite 780T case which is a large tower (I had to mount it outside of the case on top because the top drive cage is welded and not removable, but it works quite well in that location. I can't attest to great thermals as my computer is in my sun room and even with 2 air conditioners it gets quite warm at this time of year. I will have a better idea how good it is in September when it cools down a little. Also my MSI X470 Gaming M7 AC does not have the greatest vrms. I will upgrade to the MSI X570 MEG ACE in a month and I will report my findings then.
2. Push-pull is a waste of time on thin radiators like this
3.When pre-filled good for usually 3 years before refill. Mine still is good after 3 years. But it varies to a degree not all experiences are the same.
os2wiz is offline
post #207 of 213 (permalink) Old 06-24-2019, 07:27 AM
kicurry's Avatar
Rep: 2 (Unique: 2)
So do you disconnect from the radiator? how do you get air out of radiator, I am missing something.
Thanks for the tip.
kicurry is offline
post #208 of 213 (permalink) Old 06-24-2019, 09:34 PM
Rep: 0
blankmang
Thanks for the tip.
post #209 of 213 (permalink) Old 06-24-2019, 09:45 PM
os2wiz's Avatar
It is not the pump . It is air in the pump. Bleed the system and the noise will be gone. "No investigation, no right to speak. " - Mao Tse Tung
os2wiz is offline
post #210 of 213 (permalink) Old 06-25-2019, 06:22 AM
kicurry's Avatar
Rep: 2 (Unique: 2)
Great, thanks for that!
kicurry is offline
