[Official] Alphacool Eisbaer Thread - Overclock.net - An Overclocking Community
post #1 of 203 (permalink) Old 07-05-2016, 03:55 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
Originally Posted by AT-Eduard View Post
Eisbaer Landingpage
Product Information
With the “Eisbaer”, Alphacool is fundamentally revolutionizing the AIO cooler market. Where traditional AIO CPU-coolers are disposable products which are neither upgradeable nor refillable, the Alphacool “Eisbaer” is modularly built and can be upgraded, rebuilt or refilled at any time. This means that the “Eisbaer” is not only an AIO, but also fully built on classic water cooling components. That means it is quieter and more powerful than the average AIO solution.
The individual components:
Radiator
Alphacool depends on a radiator made of pure copper. The base of the radiator is the popular Alphacool NexXxoS series, which is well-loved around the world. The pure copper construction raises the cooling performance enormously compared to the usual aluminium radiators used in classic AIOs. The slight thickness of the fins ensures enormous cooling power in fans with low rotational speed. This ensures that the performance of the “Eisbaer” when adjusting the fans down decreases much more slowly than in radiators with higher fin thickness.
Hoses
The flexible PVC hoses make installing the “Eisbaer” easy. These hoses are easier to arrange and move into the right position. So the hoses don’t bend and stop the flow of the water, both hoses have been fitted with anti-kink springs. The 11/8 mm size is also a standard in the water cooling field, alongside the 13/10 and 16/10.
Quick-lock closure
The “Eisbaer” was designed with expandability directly in mind. This is why you’ll find a quick-lock closure on one of the hoses. This quick-lock mechanism is compatible with Alphacool HF quick-lock closures (1010383, 1010394, 1010395, 1010442), with which the circuit can easily be expanded to include anything from a radiator to a graphics card cooler. Furthermore, the “Eisbaer” is compatible with the upcoming Alphacool GPX-Pro graphics card AIO, which will use identical quick-lock closures.
Fans
The “Eiswind” fans were developed specially for radiators and generate a high static pressure in order to push cool air through the fan blades. Both fans can be regulated with PWM to anywhere in an enormous range from 550 to 1700 RPM. A PWM Y-adapter is included with the “Eisbaer” so that both fans can be controlled by the motherboard or a separate fan control with a PWM connection.
Connectors
All connectors are based on the classic G1/4 inch thread, the standard thread in the water cooling field. This way, all attachments can be switched out for others any time as desired. This also means that, for example, you could later decide to switch to thicker hoses or even HardTubes and set your system uniquely apart.
All these features make the “Eisbaer” cooler into something extraordinary. Its enhanced appearance from the illuminated logo and the illuminated reservoir, which also contains the pump, lets the interior of your PC shine in a whole new way. The soft-touch surface of the pump case is a further visual highlight.
With the “Eisbaer”, you get an all-around perfect product that is not only extremely high-powered but also works very quietly.
Pumps
The basis of the pumps is the Alphacool DC-LT Ceramic Ultra Low Noise, also available separately. The pump runs extremely quietly and can be regulated to between 7 and 12V. It can also be regulated through the motherboard. If the “Eisbaer” is being run alone, the 7V setting will still have next to no performance loss, as shown in diverse test results. The insulated pump case further perfects the noise generation and ensures that vibrations are almost completely absorbed.
The smooth and shiny polished copper base of the cooler ensures optimal heat absorption and can relay the heat over the fine slit structure of the cooler to the water quickly and efficiently.
Technical Details:
Pump (Alphacool DC-LT 2600 Ultra low noise Ceramic):
Speed: 2600 RPM
Voltage: 7-13.5V DC
Power consumption: 4W
Maximum flow rate: 70L/h
Maximum head: 0.85m
Fan (Eiswind 12):
Bearing: sleeve bearing
Voltage: 12V
Power connection: 4-pin PWM
Rated speed: 550-1700 (+/- 10%)
Airflow: 63.85 cfm / 108 m3/h
Static pressure: 1.66 mmH20
Volume: 29 dB(A)
Scope of Delivery:
1x Alphacool Eisbaer with 120x45 / 240x30 / 280x30 or 360x30mm radiator
1x Intel Backplate
1x Intel bracket
1x AMD bracket
PWM Adapter
Mounting material
Thermal paste
Compatible to Sockets:
Intel: 1156, 1155, 1150, 1151, 1366, 2011, 2011-3 (also to Narrow tent with the optonal special narrow tent kit), 771
AMD: AM2, AM2+, AM3, Am3+, FM1, FM2, FM2+, C32, 604, G34
What is real special?
In the near future we will preent our GPX-Pro AIO for graphic cards. Also the stand alone GPX-Pro wich has a pump included. With the coming up extension kit, you can connect everything ver easy smile.gif
Reviews online on:[/B]
Germany:
Computerbase https://www.computerbase.de/2016-06/alphacool-eisbaer-test/
PC Games Hardware Alphacool Eisbaer: Silent-Kompaktwasserkühlung im PCGH-Test
Hardwaremax Test: Alphacool Eisbaer
Hardwareluxx Erweiterbare AiO-Kühlung Alphacool Eisbaer 240 im Test - Hardwareluxx
France
Comptoir-Hardware Test • Alphacool Eisbaer 240 - Le comptoir du hardware
Modding.fr [TEST] Alphacool Eisbear 240 CPU | modding.fr
USA
LegitReviews Alphacool Eisbaer 240mm AIO Liquid CPU Cooler Review - Legit ReviewsIntroduction to the Alphacool Eisbaer AIO Liquid CPU Cooler
Techpowerup Alphacool Eisbaer 240 Review | techPowerUp
Thermalbench Alphacool Eisbaer 240 CPU Cooler
Italien
ReHWolution.it ReHWolution | Alphacool Eisbaer 240 ST30 CPU All In One Liquid Cooling | Recensione esclusiva
Some pics
AT-Eduard is offline
post #2 of 203 (permalink) Old 07-05-2016, 04:06 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
post #3 of 203 (permalink) Old 07-13-2016, 04:48 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
Now Available in our shop, Alphacool Eisbaer, all versions: Solo, 120, 240, 280 and 360mm version
You can find them here: http://www.aquatuning.co.uk/search?sSearch=eisbaer or in on of our other 22 shops world wide if you search for "Eisbaer".
post #4 of 203 (permalink) Old 07-14-2016, 02:41 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
post #5 of 203 (permalink) Old 07-24-2016, 04:07 AM
manolis1996's Avatar
Rep: 0
Hello i am new in overclock.net and i just ordered my new alphacool icebaer solo...
I read one thread about coolermaster/alphacool ICEBERG and i want to answer some specs...are these specs (Maximum flow rate: 70L/h
Maximum head: 0.85m) validated? Ι want to put in the loop 2 radiators 240 and 240 or 360 and 240 with one reservoir and gpu block...can it handle it?
Thanks a lot!!!
manolis1996 is offline
post #6 of 203 (permalink) Old 07-25-2016, 12:53 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
Hi Manolis1996,
comptoir-hardware.com a big french website made a review with the Eisaber, 2x 240mm radiators and an Asus Posaidon graphic card. They had no problems with the Eisbaer. Thats the reason why i am thinking, it will work.
post #7 of 203 (permalink) Old 08-06-2016, 03:04 AM
wywywywy's Avatar
Rep: 0
Alphacool, if you ever do a revised version of this, please consider putting the G1/4 ports on the SIDES.
Because the Eisbaer/Eisberg is already quite tall, having the ports on the top makes even taller, making any sort of SFF build impossible.
wywywywy is offline
post #8 of 203 (permalink) Old 08-08-2016, 12:35 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
We will not have a new revision, but we are working on a further new AIO with other details. But if you do not like the Eisbaer, wait for the be quiet Silent loop, Alphacool is the OEM manufacturer wink.gif Or you buy the Fractal Kelvin wich is also from Alphcool wink.gif
post #9 of 203 (permalink) Old 08-08-2016, 01:25 AM
wywywywy's Avatar
Rep: 0
Didn't know about the Bequiet AIO. Thanks for letting me know. Any idea when is it coming out?
Yes I'm planning to get the Kelvin. Just wish they'd sell the pump-block on its own like the Eisbaer biggrin.gif
wywywywy is offline
post #10 of 203 (permalink) Old 08-08-2016, 01:41 AM - Thread Starter
AT-Eduard's Avatar
Rep: 13 (Unique: 8)
I do not really know the realease date of the be quiet silent loop. But i am sure, release will be in the next 3 month.
