50C Water Temp - Overclock.net - An Overclocking Community
50C Water Temp
post #1 of 8 (permalink) Old 10-17-2016, 04:50 PM - Thread Starter
BoatOnGoat's Avatar
Rep: 9 (Unique: 7)
So I've had my build for about 2-3 years and it's always had, well, high water temperatures under load.
i7 4770k @ 4.5GHz 1.25v
2x GTX 780ti's with a small overclock
The CPU will always stay under 70C and the GPUs will always stay under 55C.
The components are all crammed in a Corsair 350D with a top 240x30mm rad and a front 240x45mm rad. Under typical gaming loads like BF4 (what I consider a full gaming load) water temps always creep up to about 50C but never over. I'm more less here to write a note that all components I have are still fine, including pump and most importantly, tubing. I used the PrimoChill Advanced LRT. Just to share with others that worry if their liquid temp is too high.
BoatOnGoat is offline
post #2 of 8 (permalink) Old 10-17-2016, 08:01 PM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
What is the Delta T?
That's the difference between the water temp and the temp of the air entering the rad(s).
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 8 (permalink) Old 10-17-2016, 09:08 PM
RX7-2nr's Avatar
Rep: 175 (Unique: 159)
Rising water temp because your tags are not dissipating enough of the heat load. Whats the fan setup and rpm? You might need to crank up the fan speed a bit to cool all that with two slim 240s.
How to unlock AMD Official Overclock mode in Catalyst
Easy Automatic Shutdown for Overheating CPU (water pump failure)
XSPC Photon 270 mounting plate for the Corsair 750D
AMD
(6 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
post #4 of 8 (permalink) Old 10-18-2016, 08:03 AM - Thread Starter
BoatOnGoat's Avatar
Rep: 9 (Unique: 7)
About 25C.
post #5 of 8 (permalink) Old 10-18-2016, 08:04 AM - Thread Starter
BoatOnGoat's Avatar
Rep: 9 (Unique: 7)
2x Noctua NF-F12s full speed on front rad (intake)
2x Corsair SP 120 Quiet Edition full speed on top rad (intake)
1x Corsair AF 120 Performance Edition full speed on rear (exhaust)
post #6 of 8 (permalink) Old 10-18-2016, 09:14 AM
Overclock Failed...
About 25C.
That's a problem.
From looking at the post above I'd guess your problem is air flow.
Four intakes and one exhaust?
post #7 of 8 (permalink) Old 10-18-2016, 05:03 PM - Thread Starter
BoatOnGoat's Avatar
Rep: 9 (Unique: 7)
That's a problem.
Well I've tried multiple fan setups and all yield a 1-2C difference, I chalk it up to cramming so much into a small mATX chassis with only 480mm of rad space.
(Temp is the same even if case window is open, so it's not like I'm "pushing" too much air in or anything.
post #8 of 8 (permalink) Old 10-18-2016, 08:35 PM
RX7-2nr's Avatar
That's a problem.
Agreed. 4 intakes might not be a problem, the exhaust though may be. Again, I'm just basing my opinion off of the picture of your case. but it looks like INTAKE might be a big problem. If your rads cannot breathe a lot of cold air INTO them they cannot dissipate their heat OUT of them. Ambient temps of course play a game here as well, but I dont thing that 30C ambient temps are the problem.
AMD
(6 items)
Ryzen 1800x
ASUS P6T
1tb WD Black
Cooler Master V850
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
