White buildup in drain line? - Overclock.net - An Overclocking Community
post #1 of 5 (permalink) Old 10-17-2016, 05:20 PM - Thread Starter
latexyankee's Avatar
Rep: 4 (Unique: 4)
Not sure what the white buildup is in my drain line coiled up under my drive bays. Obviously there is no flow through it since its a dead end. Should I be concerned? I was going to wait until spring to drain and do a cleaning but now I'm not sure. Been running Mayhems pastel berry blue for 12 months with no temp issues. The pic doesn't do it justice, half of the line has a milky white color to it.
The residue is ONLY in (or noticeable) the drain line. The rest of the loop still looks very berry blue, like some smurf ****e.
latexyankee is offline
post #2 of 5 (permalink) Old 10-17-2016, 05:23 PM - Thread Starter
Rep: 4 (Unique: 4)
This image looks like the tubing is sort of stained. You can see the white mix with the dye when moving the line. this is right at the end, just before the valve.
post #3 of 5 (permalink) Old 10-18-2016, 11:22 AM
Founder
LiquidHaus's Avatar
Rep: 78 (Unique: 72)
some pastel coolants develop white buildup if the system/pump hasn't run in a while. since this is a drain line and not much flow comes through, it's just the mix separating and settling.
www.liquid.haus
Team Heatkiller
LiquidHaus is offline
post #4 of 5 (permalink) Old 10-19-2016, 07:05 AM - Thread Starter
Rep: 4 (Unique: 4)
Ok thanks, so no real concern?
post #5 of 5 (permalink) Old 10-19-2016, 07:53 AM
More Vcore
The EX1's Avatar
Rep: 107 (Unique: 99)
You are fine. Pastel is a nano fluid so if you have a dead spot in your loop like a drain line, the particles can begin to build up and stick to the inside of the tubing. It isn't uncommon.
Test Bench
(14 items)
1920X Threadripper
ASUS ROG Zenith Extreme
ASUS RX 560 Strix
ASUS RX 560 Strix
ASUS RX 560 Strix
G.Skill Tridentz DDR4
Western Digital Blue M.2
EVGA 1600 G2
Noctua NH-U12S TR4-SP3
Corsair SP120s
Corsair AF140
Corsair 780T White
Operating System
UNRAID
ASUS VG245H
ASUS VG245H
ASUS VG245H
Keyboard
RAZER Black Widow Ultimate
Keyboard
RAZER Black Widow Ultimate Overwatch Edition
Keyboard
Logitech G15
Mouse
Razer Naga
Mouse
Steelseries Warcraft MMO Mouse
Mouse
Logitech G502
Audio
Razer Kraken 7.1
Other
USB Hubs/extensions/cables
Intel Core i7 6950X
ASUS ROG Rampage V Edition 10
nVidia Titan Xp Collector's Edition Galatic Empire
Corsair Special Edition Blackout Dominator DDR4
Samsung 960 EVO M.2 NVM.e
Crucial MX300 SSD
OCZ SSD
Corsair HX1000i Platinum
Custom red sleeved cables
EK RGB Monoblock
Alphacool Monsta 360mm Radiator-White
Hadwarelabs NEMESIS GTX 560mm Radiator
Noiseblocker 120mm PWM fans-White
Noiseblocker eLoop 120mm fan-Red
Noctua Industrial 140mm fans
Phobya Slim 180mm fans
Swiftech D5 Pump
Bitspower D5 pump top
Bitspower D5 pump mod kit
Singularity Computers Ethereal Dual Reservoir mounts
Monsoon Free Center compression fittings
Bitspower Deluxe White fittings
Primochill Grillz Hex radiator grill
Primochill Advanced LRT Tubing
Koolance in-line filter
XSPC G 1/4 temperature sensor
Silverstone PWM fan hub
EK M.2 Heatsink - Nickle
FrozenQ LFX Reservoirs - White
FrozenQ LFX Aluminum Reservoir collars
Silverstone TJ11
Custom acrylic panels
Operating System
Windows 10
Alienware AW3418DW Ultrawide
Keyboard
GALAX HOF
Mouse
Razer Starcraft II Edition Mouse
Mousepad
GALAX RGB Mousepad
Audio
ASUS Supreme FX Hi-Fi DAC
Audio
Sennheiser Game Zero - White
Other
NZXT USB 2.0 internal hub
Other
NZXT Hue+
Other
Darkside LEDs and extensions
Ryzen R7 1800X
ASUS ROG Crosshair VI
Powercolor RX Vega 64 Red Devil
RX Vega 64 Limited Edition
GALAX HOF Limited Edition DDR4
Western Digital Black
Optical Drive
ASUS Blu-Ray/DVD-RW
EVGA 750 GQ
EVGA 750 GQ
Deepcool Captain 240mm
Primochill Praxis Wet Bench
Operating System
Windows 10
The EX1 is offline
