CPU, and Radiator upgrade, on water-cooled rig. - Page 2 - Overclock.net - An Overclocking Community
post #11 of 211 (permalink) Old 11-07-2016, 11:10 AM - Thread Starter
toolmaker03's Avatar
Rep: 93 (Unique: 70)
I am still looking for a good way to reattach the case lighting on this system.
any ideas?
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #12 of 211 (permalink) Old 11-07-2016, 01:23 PM
RDKing2's Avatar
Rep: 17 (Unique: 14)
3M VHB double sided tape. Use it for my lighting, pumps and aquaero power adjust's. Will hold just about anything. For more isolation like on my D5 pumps I stack 3 layers. http://solutions.3m.com/wps/portal/3M/en_US/Adhesives/Tapes/Brands/3M-VHB-Tape/
RDKing2 is offline
post #13 of 211 (permalink) Old 11-07-2016, 01:32 PM - Thread Starter
thanks, this looks like it should work.
the contact Velcro I used was a total flop, the stuff worked great for about 3 months. tongue.gif
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #14 of 211 (permalink) Old 11-09-2016, 03:18 PM - Thread Starter
ok, so why do I buy 25mm extensions and 50mm extensions for my builds?
well after building several different builds, I have learned pretty much all the different reasons for the tubing to collapse on a water loop.
so I will start with the 50mm extensions, I use these because I use fan shrouds on my radiators, the shrouds are 20mm thick and the fans are 25mm thick. together the length is 45mm, so I use 50mm extensions to extend the connection to the radiator beyond the fans and shrouds. then I will attach a soft 90 3-way fitting, to the end of the 50mm extension, I will attach a 3/8" X 5/8" compression fitting on the end of the soft 90 3-way fitting. completing that section of fittings that attach to the radiator. all of this is done to prevent the tubing from collapsing, if I just attached the compression fitting to the radiator and ran the tubing from there. the tubing would collapse after a few months of laying on the edge of the fan. this set of fitting will prevent this from happening. the 25mm extension are for one of the connections coming out of the back of the PC case, and the other 25mm extension, is for the connection to the out line of the pump reservoir combo.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #15 of 211 (permalink) Old 11-10-2016, 10:49 AM - Thread Starter
ok, so I have these phobia 120mm fan shrouds, these shrouds have 8 X 5mm holes for led lighting. so, I am going to redesign the radiator I have on there now. by replacing one of the fan shrouds with three of the phobia fan shrouds, than I will add lighting to each of the radiators by inserting 4 X 5mm LED lights into each of the phobia fan shrouds. this should light up the outside of the build a lot, when the LED lights are on. biggrin.gif
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #16 of 211 (permalink) Old 11-10-2016, 11:03 AM - Thread Starter
ok, so In a effort to make maintenance on this build a little easier I am going to change the arrangement on the fans. currently the top radiator pulls air in form the bottom, and exhausts that air through the top of the radiator. cleaning the fan filters is a difficult task as there is not much room to get a hand in there to clean off the collected dust. so, I am going to reverse the direction of the fans, they will pull air in from the top, and exhaust through the bottom. this will allow for easy access to the fan filters that will now be on top of the radiator. I will do the same design style on the new radiator to be mounted off the back of the PC case. the intake will be from the far fans, and exhaust toward the PC case. again this will make for having easy access to the fan filters on that radiator as well. onto the PC case fans currently the intake is in the front of the case, and the exhaust is out the back of the PC case. the fan filters in the front of the PC case are a joke. so I am going to reverse those fans as well, and add filters to the rear PC case fans.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #17 of 211 (permalink) Old 11-11-2016, 12:47 PM - Thread Starter
ok, so maintenance on this rig, it was built 6 years ago, three years ago I added the second pump because the first pump died. 4 years ago I replaced the motherboard, and DVD drive, because they got damaged. for the first two years of operation I needed to remove the inline filter and clean it. so, for the last three years I have done nothing to this build but blow out the dust from the inside of the PC case, and clean off the fan filters once a year. I have not flushed or changed the antifreeze, I have not even toped it off in three years. so, I would call this a low maintenance build.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #18 of 211 (permalink) Old 11-14-2016, 08:50 AM - Thread Starter
ok, the new CPU is here, and I should get the rest of the upgrades this week.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #19 of 211 (permalink) Old 11-14-2016, 04:58 PM - Thread Starter
http://imgur.com/a/nrxWw
when the rest of the upgrades get here, I will have a better pic.
