CPU, and Radiator upgrade, on water-cooled rig. - Overclock.net - An Overclocking Community
post #1 of 211 (permalink) Old 11-01-2016, 05:52 PM - Thread Starter
toolmaker03's Avatar
Rep: 90 (Unique: 68)
ok, so I have a AM3+ rig and the CPU has started to click as it is processing information. the FX8350 CPU in there now, is like 5 years old, so the CPU has done its job, now I am looking at replacing it, with the FX8370 CPU.
http://www.newegg.com/Product/Produc...82E16819113374
the full system specs.
http://imgur.com/a/SIem8
the completed build.
ok, so I did a cost out for this build as is it now, and I did a cost out for the upgrades I am adding to it.
the current build.
$400 PC case
$25 PC case fan wire extensions.
$30 PC case vandal power & reset switches
$40 4 strips of PC case CCFL lighting
$90 6 PC case fans corsair 120mm AF fans
$18 3 PC case fan filters
$70 PC case G-vans fans & light controller
$30 Asus DVD drive
$25 3.5" FP USB hub
$200 Asus sabertooth 990FX mobo
$150 FX8350 CPU
$200 Asus GTX480 video card
$283 Enermax 1350W PS
$220 Two intel 520 120G SSD's
$80 Samsung 8G 1600Mhz DDR3
these are the actual PC components.
$273 13 BP soft 90 3-way fittings
$116 4 BP 1/4 turn valves
$36 6 BP 25mm extensions
$80 10 BP male to male rotary fittings
$16 2 AC T-fittings
$16 2 PB 50mm extensions
$100 10 KL 3/8" X 5/8" compression fittings
$50 XSPC raystorm CPU water block
$108 DD GTX480 water block
$180 Two ST D5 pumps
$53 BP D5 pump top
$50 BP D5 pump top 250mm reservoir upgrade
$50 RH 250mm metal reservoir cover
$23 BP inline flow meter
$15 XSPC inline water temperature sensor
$90 6 corsair 120mm SP fans
$18 3 120mm fan filters
$127 Monstra 360mm radiator
$25 KL radiator mount
$28 2 BP 120mm fan to reservoir mounts
$50 2 radiator fan shrouds
$15 6' of 3/8" X 5/8" norprene tubing
$12 2 reservoir black lights
these are the water cooling upgrades added to the system.
the total for the build is currently at $3,422
now for the upgrades and replacement parts.
$168 8 BP soft 90 3-way fittings
$30 6 120mm fan shrouds
$96 Two KL radiator mounts
$58 2 BP 1/4 turn valves
$15 3 120mm fan filters
$16 2 BP 50mm extensions
$40 4 male to male rotary fittings
total for the upgrades $638
replacement parts
$220 FX9590 CPU
$180 2 KL D5 strong pumps at 24volts
total for replacement parts $400
so, after a little math, the new cost on this build will be, $4,212 total out the door, some assembly required.
this system is just used as a internet computer, so no heavy processing, or intense graphical needs for this system.
Legend
BP=bitspower
KL=koolance
ST=swiftech
AC=alphacool
RH=red harbinger
DD=danger dan
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is online now
post #2 of 211 (permalink) Old 11-01-2016, 06:16 PM
LuckyImperial's Avatar
Rep: 59 (Unique: 46)
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113374
the full system specs. are
motherboard, is a sabertooth 990fx R2.0
memory, 8G of corsair DDR3 duel channel 1600Mhz
video card, asus GTX480.
any other suggestions for the CPU?
If you have a Sabertooth just get an 8320 and OC it. You'll get just as many GHz and for a bit cheaper.
It's Asus C6H, not CH6; Fighting the wars that matter.
Ryzen R7 1700X
Asus Crosshair VI Hero
XFX 5700 XT
GSKill TridentZ 3200MHz C14
Samsung 970 Evo
Seasonic Prime 650W Titanium
XSPC Raystorm
Alphacool NexXxos XT45 Full Copper 280mm
XSPC D5 Tank Reservior V3
AlphaCool Eisblock Aurora Plexi GPX-A 5700 XT Reference
SwiftTech MCP655TM D5 Vario
AlphaCool Nexxxos ST30 360mm rad
Corsair Graphite 780T
Operating System
Windows 10 64bit
Benq GW2750
Keyboard
Logitech G710+
Mouse
Logitech G402
Mouse
Logitech G240 Soft
Audio
Astro A10
LuckyImperial is offline
post #3 of 211 (permalink) Old 11-01-2016, 07:31 PM - Thread Starter
this is a simple build as far as the water cooling goes, it is a single 360mm monstra radiator, cooling the CPU, and video card.
at stock speeds, this system runs cool, but I would like to avoid overclocking the hardware on this rig.
I am considering doing a upgrade to the water cooling as well, because I have to drain the system anyway to change out the CPU.
I have been considering, adding another 360mm monstra radiator to the water loop. this way I could clock the hardware a little at some point, without the system getting to hot.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #4 of 211 (permalink) Old 11-01-2016, 07:39 PM
The 8320 is going to run just as hot as the 8370 at 4.3GHz, if not less considering you won't be using stock voltage stepping if you do the OC right.
Plus, the heat output at 4.3GHz on Vishera won't be too bad. Maybe 70w idle, 170W loaded with both processors.
Just trying to save you some money man. 8320's are binned very well.
Ryzen R7 1700X
XFX 5700 XT
Samsung 970 Evo
XSPC Raystorm
Operating System
Windows 10 64bit
Benq GW2750
Keyboard
Logitech G710+
Mouse
Logitech G402
Mouse
Logitech G240 Soft
Audio
Astro A10
post #5 of 211 (permalink) Old 11-05-2016, 10:02 AM - Thread Starter
ok, so I ended up with the FX9590 CPU for this build. I also got a second monstra 360mm radiator for the build. when it all gets here I will take the loop apart and install the new CPU and radiator for this build.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #6 of 211 (permalink) Old 11-05-2016, 05:31 PM - Thread Starter
ok, so when I first did the lighting for this rig, I used the contact Velcro. I stuck one piece at each end of the light, and the other side I stuck to the case. this worked for about 3 months before the lights came loose the first time, and now 4 years later, it lasts about 5 min, before the light comes loose from the Velcro.
any suggestions on what to use to secure the lighting to the case?
I have a total 2 X 12", and 2 X 18", light strips on the build now, and I would like to be able to remove and replace the lights as they go out.
http://imgur.com/a/onsIK
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #7 of 211 (permalink) Old 11-06-2016, 12:07 AM - Thread Starter
ok, so how am I going to mount all of this hardware onto the case?
the new monstra 360mm radiator, will be mounted off the back of the case by two koolance 120mm radiator mounts.
http://www.performance-pcs.com/koolance-radiator-mounting-bracket-with-quick-release.html
the reservoir pump combo will be mounted off the back of the PC case, between the koolance radiator mounts, and the second pump will be mounted to the back of the PC case below the reservoir pump combo.
I will only have three of the fans with shrouds on the new radiator for now. the fans controller I have is a 35W per channel. so, I am only using two of the three fan channels, to power the 12 fans on the build now. the third channel will power all 6 of the fans on the new radiator.
the two radiators will be in a parallel configuration with each other, and the components will stay in the parallel configuration there in now.
my flow rates on the water loop, should increase from the 6.2LPM it is now, to a 9+LPM flow rate with the new setup. thumb.gif
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #8 of 211 (permalink) Old 11-06-2016, 09:25 AM - Thread Starter
ok, so if I had to rebuild this rig from scratch I would use 2 X 480mm radiators, instead of the 360mm radiators that I did use. the reason that I would use 480mm radiators is because, 2 X 480mm radiators is enough space to cool a CPU, and video card, while overclocked, and under a heavy load. while a system with 2 X 360mm radiators on it, if the system is overclocked, and under a heavy load, the water will heat up. so, for me the ideal conditions on a water loop, is being able to have a 1C to 2C delta T, while the system is under a heavy load. this system when finished, will be able to do that, as long as I do not overclock any of the hardware. tongue.gif
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #9 of 211 (permalink) Old 11-07-2016, 01:17 AM - Thread Starter
the current build.
$400 PC case
$30 Asus DVD drive
$25 3.5" FP USB hub
$150 FX8350 CPU
$16 2 AC T-fittings
$53 BP D5 pump top
replacement parts
$220 FX9590 CPU
$90 ST D5 pump
total for replacement parts $310
so, after a little math, the new cost on this build will be, $4,122 total out the door, some assembly required. biggrin.gif
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
post #10 of 211 (permalink) Old 11-07-2016, 03:58 AM - Thread Starter
