D5 + 5 Radiators? - Overclock.net - An Overclocking Community
D5 + 5 Radiators?
post #1 of 63 (permalink) Old 01-02-2017, 05:24 PM - Thread Starter
0451's Avatar
Rep: 45 (Unique: 40)
Thoughts on whether an EK D5 can handle 5 rads in an Evolv ATX? Only other restrictions will be an EK Supremacy EVO and GPU waterblock.
EK CE280
EK SE360
HWL GTR 280
Alphacool 140x30
Alphacool 140x45
Smallblock Power
(10 items)
Core i7 10700K
MSI Z490 Unify
2080ti K|NGP|N
Patriot Viper Steel 4400
Samsung 960 Pro
EVGA 1200 P2
5 Radiators
2 Pumps
Phanteks Enthoo Evolv ATX TG
Samsung CF791 34"
0451 is offline
post #2 of 63 (permalink) Old 01-02-2017, 05:53 PM
Overclock Failed...
billbartuska's Avatar
Rep: 1249 (Unique: 969)
Doesn't look promising...........
https://www.overclock.net/images/smil...lame-small.gif5 GHz Overclock Club https://www.overclock.net/images/smil...lame-small.gifMisinformation is available from a variety of other sources. Misinformation is just like real information but wrong
....and enough power to shoot the speaker cones through the walls.
billbartuska is offline
post #3 of 63 (permalink) Old 01-02-2017, 08:56 PM
I don't even like Linux
cmpxchg8b's Avatar
Rep: 96 (Unique: 73)
Should be alright. I'm running one D5 in a loop with CPU waterblock, four GPU waterblocks, and four 480 mm radiators, all in series.
cmpxchg8b is offline
post #4 of 63 (permalink) Old 01-02-2017, 09:04 PM - Thread Starter
0451's Avatar
Sweet
Do you have enough thermal headroom to overclock?
Smallblock Power
(10 items)
Core i7 10700K
MSI Z490 Unify
2080ti K|NGP|N
Samsung 960 Pro
EVGA 1200 P2
5 Radiators
2 Pumps
Samsung CF791 34"
0451 is offline
post #5 of 63 (permalink) Old 01-03-2017, 06:59 AM
cmpxchg8b's Avatar
@0451 I get around 15-20 C delta T. This is high but this is compute rig so the typical scenario is 100% load. CPU overclocking (4790K) is thermally limited because it is running intense AVX/FMA code. I don't overclock GPUs because their power delivery is already stressed by this mode, and I want them to last. Those are Titan Blacks and they get harder to replace.
post #6 of 63 (permalink) Old 01-03-2017, 07:36 AM
Overclock Failed...
Like I said, you're going to have a Delta T of 20°c plus.
post #7 of 63 (permalink) Old 01-03-2017, 09:36 AM
Linux Lobbyist
Revan654's Avatar
Rep: 71 (Unique: 53)
My single D5 pump can handle four 560 rads. However their the lease restriction Radiators made in the 60mm range.
I also have MonoBlock & GPU Block.
I did add a second D5 recently just to be on the safe side.
Current Build: Project Frost
Gaming Rig Build: Project Ice Dragon
Revan654 is offline
post #8 of 63 (permalink) Old 01-03-2017, 12:31 PM - Thread Starter
0451's Avatar
So if I add a 2nd pump, can I add the 2nd pump next to it:
Pump 1 out -> 1" tube -> pump 2 in
Or should the pumps be on opposite sides of the loop?
Smallblock Power
(10 items)
Core i7 10700K
MSI Z490 Unify
2080ti K|NGP|N
Samsung 960 Pro
EVGA 1200 P2
5 Radiators
2 Pumps
Samsung CF791 34"
0451 is offline
post #9 of 63 (permalink) Old 01-03-2017, 01:03 PM
Overclock Failed...
Since the flow rate anywhere in a loop is exactly the same it doesn't matter where you put a second pump.
post #10 of 63 (permalink) Old 01-03-2017, 01:36 PM
Covfefe
Wihglah's Avatar
Rep: 84 (Unique: 75)
If you add 2 pumps in series you will (almost) double the pressure in the tube immediately after the 2nd pump. The restrictions will step down this pressure by a fraction of the pressure before the restriction at each step.
If you space out the pumps the pressure will have a lower maximum and hence smaller pressure drops through each component so a higher minimum. The minimum pressure will determine the flow rate of the system.
Putting the pumps in Parallel will (almost) double the flow rate whilst maintaining the original pressure.
Normally the pressure drop through a water-cooling loop makes this point moot since it's pretty low, but with an immensely complex loop with very low flow, it could be important.
One way around the issue is to mount identical components in parallel.
Ro'Ghaf II
Oldness
(14 items)
Intel 9900k
Some crappy 4 phase rubbish from Asus that was way overpriced.
EVGA 980ti ACX2 SC+
G.Skill Trident Z RGB 4266 16Gb
Samsung 970 Evo
Corsair AX860i
EK Supremacy Evo
Cooler Master Haf Stacker 935
Haf Stacker 915R
Operating System
Windows 10 Pro
Asus ROG Swift
Keyboard
DuckyShine 6 YOTR
Mouse
Logitech G502
IvyBridge 3770K
Asus P8Z77-V Pro
560Ti Direct CU II
Geil DDR3
Western Digital
Western Digital VelociRaptor 10K
Optical Drive
liteOn Bluray Burner
OCZ 1000W
EK Supreme HF Copper / Plexi & Vapochill Chiller
Lian Li
Operating System
Windows 7
LG 21"
Keyboard
Logitech G15
Mouse
Logitech
Wihglah is offline
