cleaning out the loop - Overclock.net - An Overclocking Community
post #1 of 4 (permalink) Old 02-06-2017, 07:15 AM - Thread Starter
latprod's Avatar
Rep: 5 (Unique: 5)
Hey guys, been trying to find info on here and other places, but there seem to be so much conflicting information that I am not sure what to do.
The Problem is my temps are not very good atm, and I havent cleaned the loop in a loooong time, so I am guessing I need to do that...
But how thorough do I have to be?
Some people suggest to take apart everything, soak all the different blocks in lemonjuice/bleach/vinegar, change the tubes etcetera.
I could do any of those things, But I really do not want to remove the two GPU blocks I have and reattach them, as I'm afraid I will screw something up.
Is it doable to just flush the loop after draining it with some kind of cleaner?
Any recommendations would be appreciated.
This is what happens when you find a stranger in the Alps!
latprod is offline
post #2 of 4 (permalink) Old 02-06-2017, 09:03 AM
qbical's Avatar
Rep: 20 (Unique: 19)
As thorough as you want. Assuming you do not have a bunch of junk built-up inside your blocks, you can probably just run some distilled water and primochill system prep thru it. Unfortunately I have no idea what is actually in it though in terms of chemical composition. Sometimes just water flushes alone is all you need. I personally have not used the lemon juice or vin solutions yet. Most of what I have read is that the lemon-juice is last resort.
Again though, I do not use these cleaning solutions so others might have more info on that. Be careful if you have any acrylic as well. I will be sharing your pain here shortly as I need to do a flush and clean on my system coming up here. If i were you, I would bite the bullet and pull everything block apart to make sure they are not stuffed with crap. Especially if it has been over a year. What kind of tubing are you using?
Some Swiftech HydrX might help in your next loop.
"Instead of shooting at where I was, you should have shot at where I was going to be"
qbical is offline
post #3 of 4 (permalink) Old 02-06-2017, 11:54 PM - Thread Starter
latprod's Avatar
Rep: 5 (Unique: 5)
Hey man thanks for your answer! Well, I changed my cooling liquid without cleaning anything about 6 months ago, but it's been running without cleaning for about 2 years. Which is more than it should, I guess wink.gif
I am using standarad durelene tubing throughout. So... I am guessing I should take a apart every single thing and clean every part of the loop then. Sigh.
what's the deal with Swiftech HydrX ? Is it considered top notch?
latprod is offline
post #4 of 4 (permalink) Old 02-13-2017, 08:47 AM
qbical's Avatar
Sorry for the late response. If you are using regular old tubing from the hardware store there most likely is going to be some plasticizer (sp?) in a block.
I just suggested the Swiftech stuff since it has been around forever and is usually recommended on this board. I have had a bottle for a long time, but have not used it yet. I planned to this time though. I am going to drain my loop, clean out what looks like mold and then run warm soapy distilled water thru it for a bit. It will prob take a few flushes to clean out.
I am on my third different coolant and they just do not last very long for me, so going straight distilled H2O with a little additive this time.
good luck with your cleaning
qbical is offline
