Phanteks Enthoo elite Discussion - Page 23 - Overclock.net - An Overclocking Community
post #221 of 234 (permalink) Old 02-01-2019, 02:40 AM
d0mini's Avatar
Rep: 65 (Unique: 60)
Well, judging from your previous build, the final product will be awesome and look significantly better than my attempts!
One thing I forgot to mention – the build I posted is the only one I've found that has a radiator in the front and on the side. You can't do it with the standard configuration; I had to flip the side radiator bracket so the fan mounts were on the side closest to the motherboard. As you can probably see, this creates issues with routing cables through there, as they are very close to the fans.
This may also be the first Enthoo Elite build to have been posted online that uses a Mini-ITX motherboard in the main motherboard area I have yet to upgrade my core hardware since my NCASE M1 days... it'll happen soon...™.
That being said, the issue with cable management will only get worse with a bigger board, as I won't be able to route the motherboard and CPU cables through the motherboard cutout. I'll climb that wall when I get to it though!
Intel Devil's Canyon Owners Club
"i can still turn the computer on, it just catches on fire when i do...", from this wonderful thread.
[email protected], 1.36v (4.5GHz uncore)
Maximus VII Impact
MSI 980 Ti Gaming 6G
Corsair Dominator Platinum 16gb 2133 CL9
2x 840 EVO 500GB
Toshiba XG3 1TB (M.2 NVMe SSD)
MX 500 2TB
EVGA G2 850 PSU
EK Supremacy Evo & VGA
11x ML 120 PRO fans
5x Gentle Typhoons 1850rpm intake, 1x GT 1450rpm exhaust
PE-240; XT45 120; SR-2 360 multiport; XSPC RX 360; 2 x XSPC RX 480 rads
Corsair Commander Pro
Aquaero 6 LT; Splitty 9; Hubby7
2 x Ek Xres 140 pump/res
Phanteks Enthoo Elite
Operating System
windows 10
Acer Predator XB271HU
Keyboard
Corsair Strafe RGB
Mouse
Logitech G Pro Wireless
Mouse
MX Master AMZ
Mousepad
XXL neoprene mousemat goodness
Audio
Sennheiser HD 650
Audio
Senheisser Game Zero SE
Audio
Bose companion 20
Audio
GSX 1000
Audio
SMSL M6
[email protected], 1.23v (4.5GHz uncore)
Maximus VII Impact
2x 840 EVO 500GB
Corsair SF 450
2x Gentle Typhoons 1850rpm exhaust
PE-240 radiator
EK-DDC 3.2 PWM
M1 NCASE reservoir
NCASE M1
Operating System
windows 10
Acer Predator XB270HU
Keyboard
Corsair Strafe RGB
Mouse
Logitech G502
Mousepad
Audio
Sennheiser HD 650
Audio
Bose companion 20
d0mini is offline
post #222 of 234 (permalink) Old 02-01-2019, 02:43 PM
KCDC's Avatar
Rep: 27 (Unique: 23)
Thanks! I decided not to do rigid tubing this time around and went the the stealthier black ZMT tubing which is a delight to work with. I was thinking of doing other rad configs, but this one allows shorter tube runs and looks cleaner to me. Getting closer to a final look, hopefully this weekend! That ITX must look so tiny in the main mobo spot in this case.
ZMT watercool setup -- Phanteks Enthoo Elite -- hwlabs gtr 420 x 2 -- -- xspc tx360 crossflow -- noctua A14 PWM x9 -- 9900x -- x299 TUF Mk1
Corsair Hydro X XC9 -- 64gb 3200 tridentZ Royal CL14 -- AX1500i -- 2x 7600p on hyper m.2 VROC 4TB -- EK ZMT Tubing -- Ek Fittings -- dual Aorus Waterforce xtreme 2080ti -- asus PG279UZ monitors x3 7680x1440 surround
Bertha5.5
(21 items)
9900x
X2399 TUF Mk1
Aorus 2080ti Waterforce Xtreme
TridentZ Royal 3200 CL14
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
XSPC TX360 Crossflow
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Noctua NF-P12 PWM redux x3
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Corsair K95 RGB Platinum
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #223 of 234 (permalink) Old 02-19-2019, 05:53 PM
KCDC's Avatar
Wondering if any Elite owners here has vertically mounted two GPUs? If so, did you have to use a Phanteks branded PCIe riser cable? Are all premium riser cables the same as far as their mounting goes? When comparing the Phanteks premium to other brands, it looks a little different. I ask because they're impossible to find in stock and want to make sure I can order any premium riser (3M, TT, etc) and that it will install properly in the vertical mounting cage.
Bertha5.5
(21 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
post #224 of 234 (permalink) Old 03-04-2019, 08:16 PM
Rep: 0
Sent from my iPhone using Tapatalk
Boooooost is offline
post #225 of 234 (permalink) Old 04-07-2019, 08:01 PM
Rep: 0
I am debating between this or the Corsair 1000D. Would love to hear your opinion on which one you would choose
erikbarone is offline
post #226 of 234 (permalink) Old 04-07-2019, 09:20 PM
NewUser16's Avatar
Rep: 48 (Unique: 32)
I don't know quality build of Phanteks cases, especially this one, but I know for sure, Corsairs 900D and this 1000D series cases quality is poor, at least to my liking, very thin skin, the construction wobbles so its not the most sturdy case.
NewUser16 is offline
post #227 of 234 (permalink) Old 04-08-2019, 04:43 AM
doyll's Avatar
Rep: 1674 (Unique: 931)
Phanteks Elite is infitiely better built then any Corsiar case .. like the difference between a Rolls Royce and a Yugo.
doyll is online now
post #228 of 234 (permalink) Old 04-22-2019, 09:23 AM
Daitro's Avatar
Rep: 2 (Unique: 2)
Does anyone know if Phanteks has ceased production of this case? Doesn't seem to be in stock anywhere.
Disregard. Direct messaged them on Facebook and they promptly responded to say there's more coming in May.
X79
(18 items)
X58
(15 items)
Intel Core i7 3960X @ 4.5GHz
ASUS RAMPAGE IV EXTREME
EVGA TITAN X SC
Corsair Dominator Platinum CMD64GX3M8A2133C9 64GB
2*Corsair Force GT 240GB RAID0
Western Digital Velociraptor 1TB
Western Digital Velicioraptor 600GB [Games Drive]
7*Hitachi Deskstar 7K4000 RAID50
Optical Drive
Panasonic Slot-load BD-MLT U235AS
Corsair AX1200i
Corsair H100i
Lian Li PC-V2120X
Operating System
Windows 7 64bit Ultimate
NEC PA271W
Keyboard
Ducky DK8000S
Mouse
SteelSeries Rival
Mouse
Corsair Vengeance MM200 Extended Mouse Pad
Other
LSI MegaRAID SAS 9271-8i
i7 975XE
EVGA Classified SLI E760
ATI HD6990
Corsair Dominator GT 24GB
Intel X-25E SSD
Western Digital Caviar Black
Western Digital Caviar Green
Optical Drive
Panasonic Slot-load
Silverstone ST1500
Corsair H100
Lian-Li 2120X
Operating System
Windows 7 Ultimate 64bit
NEC PA271W
Keyboard
Ducky Shine 9800S & XArmor U9BL Plus
Mouse
Razer DeathAdder / Razer Mamba
Daitro is offline
post #229 of 234 (permalink) Old 05-02-2019, 07:27 AM
deanorthk's Avatar
Rep: 0
Not talking about the build quality of those two case, I think the 1000D and the Elite serve different purpose, and two very different WC path.
On my side, I have chosen the 1000D, mainly because I'll have a mini itx and a Eatx setup, and I can drop enough radiator inside while still getting fresh air moving in without going through a radiator (because of the dual line of fans you can put on the front)
So two very very different tower, if you don't need dual setup, and money is not an object, I think the Elite is of better quality overall.
deanorthk is offline
post #230 of 234 (permalink) Old 06-13-2019, 12:18 AM
KCDC's Avatar
Starting to get somewhere happy with my build, still finishing wiring and led layout, some wires still showing. Added a Commander Pro to the mix, keeps my fans nicely humming off water temp. No more rpm spikes! Couldn't help but add their addressable LEDs to the mix for some fun. This case really is a pleasure to work with. Playing with more LED profiles now that I have a hang of iCue. Might get new pcie and 24 pin cables, I can't get these cablemods to straighten out. 80% there, enough to finally post a pic or two.
Bertha5.5
(21 items)
9900x
X2399 TUF Mk1
VROC 7600P x2
Ax1500i
HWL GTR 420 x2
EK ZMT 10/16
Corsair XC9
Corsair XD5
EK 10/16 Fittings
Noctua A14 PWM x9
Enthoo Elite
Operating System
Win 10 Pro 64
Asus PG279QZ x3
Keyboard
Mouse
Corsair Nightsword
Mousepad
Corsair MM800
KCDC is offline
