Phanteks Enthoo elite Discussion - Page 24 - Overclock.net - An Overclocking Community
post #231 of 232 (permalink) Old 06-29-2019, 09:14 AM
Zergoras's Avatar
Rep: 0
Im going to optimize my build with some 90 degree fittings and stuff so that the tubes fit a bit better. I need to drill two holes in the big midplate, how do you recommand doing that without damaging the plate?
Im also thinking about putting in one more radiator and maybe one thicker one at the bottom. Did any of you put a 360mm rad on the side panel? Im just wondering if im able to place my reservoir next to it.
I have one 30mm 480mm rad on the bottom and one on the top. Do you think it would help my temperatures a bit if im going to upgrade to a thicker one (60mm)at the bottom? Would adding a 30mm 360mm rad improve it even more? The side one would be a no brainer if it would fit. Im not wanting to put a rad in the front because of the temps rising inside the case. Im right now using a 1080ti and a i7 7820X. I have a temp delta under full load around 12k (room to water temp). Going to upgrade soon to a 2080ti and maybe a Ryzen 3950X.
Zergoras is offline
post #232 of 232 (permalink) Old 07-21-2019, 03:27 AM
Zergoras's Avatar
Rep: 0
My tuning is done, way better than the last one but still not perfect. Next time maybe hard tubes.
Zergoras is offline
