Phanteks Enthoo elite Discussion - Page 25 - Overclock.net - An Overclocking Community
post #241 of 251 (permalink) Old 03-01-2020, 10:10 AM
doyll's Avatar
Rep: 1682 (Unique: 933)
Quote: Originally Posted by pRedatoR1976 View Post
Hello everyone.
First I have to excuse my bad english, I have to use google translate.
Here is my System:
Hardware:
I9-9900K
32 GB G.Skill TridentZ
Asus Maximus XI Extreme
Asus RTX 2080Ti O11G
Samsung SSD 960 EVO 1TB NVMe
Samsung SSD 860 EVO 1TB SATA
Samsung SSD 860 EVO 2TB SATA
Corsair RMX850
Done:
Congratulations on a very well done build. It is obvious you put a lot of thought and planning into it.
doyll is offline
post #242 of 251 (permalink) Old 03-15-2020, 12:18 PM
sultanofswing's Avatar
Rep: 1 (Unique: 1)
Just bought the Gray Elite, Cannot wait for it to show up.
sultanofswing is online now
post #243 of 251 (permalink) Old 03-23-2020, 11:41 PM
Rep: 1 (Unique: 1)
Not sure I am happy with this case over my 0-11XL right now.
Went from 3 360mm radiators in the 0-11XL to
the same 3 360mm radiators plus a 480mm radiator and Water temp at idle seems to have went up nearly 2 degrees at the same ambient.
Opening the side door drops the temp right at a degree, I think the bottom chamber is trapping a lot of heat and not working efficiently.
480 at the bottom is push/pull with 8 artic P12's (these fans actually perform very well)
Front 360 same artic P12's but only in pull
Bottom 360 same artic P12's in push mode under the midplate (this is what I think may be causing the issue)
Top 360 with 3 Noctua NF-P12x25's in pull mode.
All fans are running at 1500RPM at idle as the noise there is not bad at all.
I am going to do some testing this weekend by removing the bottom 360 that is in the same chamber as the 480 and see if this relieves some of the excess heat.
Case needs a better way to exhaust the bottom chamber.
post #244 of 251 (permalink) Old 03-29-2020, 06:53 AM
trawetSluaP's Avatar
Rep: 0
I put a fan either end of the bottom chamber (front and back) to help direct the heat out of the back which seems to help.
Case: Enthoo Elite, CPU: i9-7900X Motherboard: Rampage VI Extreme
RAM: Dominator Platinum 32GB, GPU: EVGA 2080 Ti FTW3 & 2080 FE
Storage: 960 Pro 512GB, 2 x 840 Evo 250GB, PSU: EVGA SuperNOVA 1200 P2
Monitor PG279Q, MX27AQ
Custom Watercooling Loop + Aquaero 6 XT
trawetSluaP is offline
post #245 of 251 (permalink) Old 03-29-2020, 07:05 AM
doyll's Avatar
Same loop sequence of components, waterblock and temp sensor loop as 011 loop was?
doyll is offline
post #246 of 251 (permalink) Old 03-29-2020, 11:27 AM
Rep: 1 (Unique: 1)
Only thing that changed between the 2 was obviously the case and I added a 480 Radiator. Yesterday I took one of the 360's out and moved the 480 to the front and moved the other 360 that was up front to the bottom chamber.
This gave me more room to be able to add a exhaust fan at the back behind the 360 in the bottom chamber.
I'm not sure but just from the case swap the room ambient has went up 1.5 degrees, Nothing as far as components has changed.
Here is a quick little drawing of how I currently have it setup.
post #247 of 251 (permalink) Old 03-29-2020, 02:23 PM
doyll's Avatar
So you added 480 rad as intake when in your other case you had more exhaust vent area. 011 has 9x 120mm fan vents plus rear venting, so your 2x 360mm rads were 6x vents in and similar area out.
By adding 480m rad you have extremely unbalanced your airflow setup. 10x 120mm intakes need 10x 120mm exhaust vents. You only have 2x exhaust vents. What you have is 10x 120mm fans trying to push air into a case that is only letting 2 vents of air out. End result is you only have 2x vent of airflow trying to get into your case though your 10x 120mm vent areas on your radiators. Airflow is like water. Think of it as a van with 12 open windows sunk in a pond. All water flowing into van mush also flow out of van. So if you have 10 windows with propellors trying to push water into van and only 2 windows letting water out, the van will only flow as much water in as can flow out those 2 windows. Same with our case with 3 rads on 10 vents with 13 fans trying to push air into your case. Your can can only flow as much air as your 2 exhaust 2 vents can flow out of case. You need to have as much exhaust vent area in sq mm as you have intake vent area.
Try turning off the fan on on radiator and I'm pretty sure your temps will go down.
Better yet, switch the fan on top radiator to be exhaust instead of intake. Then you will have closer to an even amount of intake area as you have exhaust airflow area in your case.
doyll is offline
post #248 of 251 (permalink) Old 03-29-2020, 02:41 PM
Rep: 1 (Unique: 1)
All my fans on my 0-11XL were intakes, I used no Exhaust fans at all. 3 360mm Radiators all as intakes.
I did a lot of testing when I had everything in the 0-11XL and the best setup was all intakes and no exhaust.
post #249 of 251 (permalink) Old 03-29-2020, 03:16 PM
doyll's Avatar
Honestly I don't care.
The simple truth is you had more exhaust vent area to let the air out that your 3x 360 rads fans were trying to push in.
Now you have more fans trying to push more air in, but they can't because there is less exhaust vent area to let air out. It's like a bucket with a few holes in the bottom. You can scoop it full of water very quickly, but it takes much longer for the water to leak out the small holes before you can put more water in. Trying to add water faster than it leaks out an it run over, not through the bucket. Tou can only flow as much air into intake as is flowing out of it. You have 10 intake vents with fans pushing into your radiators in your case with only 2 exhaust vents to let air out of case .. you can only flow as much air in through the radiators as is flowing out those 2 exhaust vents. It's an equal and opposite rule .. what flow in must also flow out. If more cannot flow out (2x vents of exhaust airflow) then that's all that can flow in (same 2x vents of intake airflow). All you are doing is spreading that amount your 2x exhaust vents can flow to 10 intakes, so each intake can only flow about 1/5th as much air as it could. I'll say it one last time, our setup can only flow 2x vents worth of air through all 3 of your radiators. So either use less radiators so you have more empty exhaust vents or use one radiator as exhaust so case can flow more air in and out.
doyll is offline
post #250 of 251 (permalink) Old 03-29-2020, 03:22 PM
Rep: 1 (Unique: 1)
Well i'm testing the tops as exhaust right now. They are NF-A12x25's, I have them set to a higher speed than the rest of the intakes and will report back with results.
I understand what you are saying but from my point of view the 0-11XL had less openings for air to escape the chassis IMHO.
I have all the PCI-E slot covers removed from this Elite so it should not have a problem getting air out of the chassis.
