How much to fill reservoir? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 03-24-2017, 11:04 AM - Thread Starter
Tomahok2's Avatar
Rep: 1 (Unique: 1)
Thanks for the comment, makes me feel a lot better (As others have said the same). I kept my inlet and outlet on the default positions. The fill port is on the top (Left) and then the loop runs through the right (Bottom) side. The inlet is the upper fitting and the outlet to the pump is the lower fitting.
Tomahok2 is offline
post #12 of 16 (permalink) Old 03-24-2017, 11:06 AM - Thread Starter
Tomahok2's Avatar
Rep: 1 (Unique: 1)
BTW, I have tried rotating the case to get rid of the bubble, but I will just give it time and see what happens as thermals are quite good. I have been gone from home for the last few days, so my pc has been off, I will turn it back on and see what happens when I get back.
Tomahok2 is offline
post #13 of 16 (permalink) Old 03-27-2017, 06:58 PM
RET 0
Paul17041993's Avatar
Location: 'stralia, whereh teh weahter canneh dehcide whet et wahnts te beh.
Rep: 99 (Unique: 78)
In general you try to keep as little air in the loop as possible, any air encourages corrosion and growth, but a little bit of bubbles in a reservoir is perfectly fine provided it stays there. Over time the bubbles will 'grow' due to the water evaporating, if this becomes an issue you can simply add an air trap (commonly the top-up line/hose) and top it up every now and then.
Generally this is why reservoirs are usually mounted vertically as it simplifies air management.
Paul17041993 is offline
post #14 of 16 (permalink) Old 03-27-2017, 10:01 PM
Ashcroft's Avatar
Rep: 92 (Unique: 72)
I'm not a fan of full to the brim reservoirs. I like a high level but an easily visible coolant level.
A human eye should be able to spot any leak, fast or slow, quicker than any machinery.
Ashcroft is offline
post #15 of 16 (permalink) Old 03-21-2019, 12:23 PM
Rep: 0
Dan
It can be worthing thinking of the ervior as a cup of teas, the larger the amount of liquid, the longer it takes to disipate the heat. With that said, I am going for a full reservior to start with this time. If I find it difficult to cool at higher temperatures then removing some liquid is one option to fix it.
dannyonekenobi is offline
post #16 of 16 (permalink) Old 03-25-2019, 05:28 AM
vvv850's Avatar
Rep: 28 (Unique: 18)
The amount of liquid doesn't affect the cooling capacity, it affects the thermal inertia: How fast it cools or warms up. The maximum temps aren't affected by the quantity of liquid, just how fast it gets there.
vvv850 is offline
