Distilled water and biocide - Page 2 - Overclock.net - An Overclocking Community
post #11 of 14 (permalink) Old 08-10-2017, 12:52 PM
StillClock1's Avatar
Rep: 7 (Unique: 6)
Since you've gathered all the experts in one place, I thought this would be a good spot to ask a slightly related question:
I'm rinsing my rads and blocks with distilled water prior to my build, but the build is going a bit slower than expected. Is there any harm in doing the distilled water rinse too early (like 1-2 weeks before filling the loop?). Also, I'm seeing a little fogging on my cpu monoblock after just a distilled water rinse, is that anything to be worried about? It's a tab bit foggier than it was in this picture, picture is a coupel days old now.
Hidden Overkill: Strix Z270e Motherboard | i7 7700k | 16 GB 2133MHz HyperX Fury | ROG 1080Ti Poseidon | 360mm + 480mm Black Ice Nemesis Radiators | Custom Case | 3x Dell Ultrasharp U2412M Monitors | Samsung 960 512 GB | HTC Vive
StillClock1 is offline
post #12 of 14 (permalink) Old 08-10-2017, 08:42 PM
RX7-2nr's Avatar
Rep: 175 (Unique: 159)
The fogging is probably just residual moisture inside the coolant channels as long as it's not etching or staining of some kind on the inside.
I would rinse it well before filling it off it's been sitting for a while.
Easy Automatic Shutdown Script for Overheating CPU (water pump failure)
XSPC Photon 270 mounting plate for the Corsair 750D
AMD
(7 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Raystorm CPU, Aquacomputer Vega GPU, XSPC EX-360 & EX-240
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
post #13 of 14 (permalink) Old 08-11-2017, 06:46 AM
Rep: 7 (Unique: 6)
Understood, it will sit for about 1.5 weeks before I fill the loop I think.
The blocks are already attached, which makes them difficult to remove and wash. What would you recommend? Is the harm significant if I don't re-rinse them, or should I bite the bullet and re-apply the paste/whatnot.
post #14 of 14 (permalink) Old 03-20-2020, 06:29 PM
Rep: 0
How many drops of biocide will I need? (with distilled water).
Hyper_WiZ is offline
