Distilled water and biocide - Overclock.net - An Overclocking Community
post #1 of 14 (permalink) Old 08-08-2017, 02:18 PM - Thread Starter
redserv's Avatar
Rep: 0
Hi guys, I just built my first hard tubing watercooled pc. However I will like to run distilled water and drops of biocide in my loop. Will this cause corrosion or algae problems?
My fittings are mostly barrow and monsoon ev2
I have an EK CPU and GPU waterblocks ok
, see pic below
redserv is offline
post #2 of 14 (permalink) Old 08-08-2017, 03:37 PM
Phazeshifta's Avatar
Rep: 22 (Unique: 22)
Will it cause corrosion and algae problems? No...
Biocide is meant to have the complete opposite effect of what you are asking. That's why it's put into systems to start with.
PhazeS3 - CL S3 Gunmetal/Black - Fatal1ty X370 ITX - Ryzen 1700 @ 3.95 Ghz - 16 GB Trident.Z C14 3200 - EVGA 1080 ti FTW3 - EKWB DDC pump - Hardware Labs Nemesis Radiators - All Barrow fittings - Cablemod Cabling - Barrow RGB kit
Phazeshifta is offline
post #3 of 14 (permalink) Old 08-08-2017, 03:40 PM - Thread Starter
redserv's Avatar
Rep: 0
Hey Phaz thank you for your help on this. What about adding a kill could along with biocide, will that be too much?
redserv is offline
post #4 of 14 (permalink) Old 08-08-2017, 03:53 PM
From my understanding, a kill coil should not be used with biocide. In fact, most of the reading I've done lately says a kill coil should not be used at all as it adds another metal to your loop, which may or may not add to the chance of galvanic corrosion.
Just stick with biocide, do regular maintenance such as flushing and replacing the distilled water and your loop should be good for quite some time.
post #5 of 14 (permalink) Old 08-08-2017, 04:46 PM - Thread Starter
redserv's Avatar
Rep: 0
Thanks very much for the advice, I am using this, see pic, I used like 5 drops on my new build, hope that's not too much.
redserv is offline
post #6 of 14 (permalink) Old 08-08-2017, 05:00 PM
jura11's Avatar
Rep: 104 (Unique: 68)
Hi there
You shouldn't use Kill coil with nickel plated waterblocks what I know
And if you are looking to save money have look on clear coolant like is EK Clear or Mayhems X1
Hope this helps
Thanks, Jura
jura11 is online now
post #7 of 14 (permalink) Old 08-08-2017, 05:03 PM - Thread Starter
redserv's Avatar
Rep: 0
Hi jura thanks for your input, I really will like to stick to distilled water as it's not easily available in the Caribbean islands.
redserv is offline
post #8 of 14 (permalink) Old 08-08-2017, 05:10 PM
jura11's Avatar
Hi there
In yours case switching to normal coolants like is EK or Mayhems doesn't make sense as getting there these coolants will be almost impossible for good price
And distilled water is easily available everywhere
And sorry there, didn't know you are in Caribbean islands there
Thanks, Jura
post #9 of 14 (permalink) Old 08-08-2017, 05:21 PM - Thread Starter
redserv's Avatar
Rep: 0
Hey jura thanks again for your help, appreciate the feedback and thoughts.
redserv is offline
post #10 of 14 (permalink) Old 08-08-2017, 08:57 PM
RX7-2nr's Avatar
Rep: 175 (Unique: 159)
I always use plain distilled water and biocide. A corrosion inhibitor is good to have in the system as well.
Silver coils are so old school, I'm not sure why people are even still using them. There are far better ways to control biological growth.
Easy Automatic Shutdown Script for Overheating CPU (water pump failure)
XSPC Photon 270 mounting plate for the Corsair 750D
AMD
(7 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Raystorm CPU, Aquacomputer Vega GPU, XSPC EX-360 & EX-240
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
