PrimoChill VUE Coolant Users Club - Overclock.net - An Overclocking Community
post #1 of 849 (permalink) Old 11-15-2017, 11:11 AM - Thread Starter
Totally Tubular
MNMadman's Avatar
Rep: 50 (Unique: 41)
This is the thread for all things VUE!
MAKE SURE YOU READ ALL TABS (ONCE YOU CLICK ON A COLOR) FOR FULL INFORMATION ON VUE COOLANT
!!! WARNING !!!
DO NOT USE WITH ALUMINUM COOLING LOOP PARTS
!!! WARNING !!!
They have already shipped the first few waves of pre-orders. The next wave is expected to ship on January 15th 2018. Four colors still aren't available at all, and as of January 10th there is no ETA on those.
NOTE: VUE is a show coolant. PrimoChill recommends it not be run more than eight consecutive hours. If you run your system 24/7, avoid using VUE. This coolant requires lots of rest (they recommend overnight) for best results.
STEPS FOR BEST RESULTS (NEW LOOP WITH NO PREVIOUS COOLANT):
1. Run PrimoChill SysPrep treatment using recommended methods.
2. Fill loop with PrimoChill VUE coolant.
3. Enjoy your VUE Coolant Experience™.
STEPS FOR BEST RESULTS (EXISTING LOOP):
1. Drain previous coolant.
2. Make sure each component is thoroughly hand washed and dried.
3. Run PrimoChill System Reboot treatment using recommended methods. Follow steps on System Reboot Instructions tab closely. Method 2 is preferred, as it gives a higher concentration of System Reboot for better cleaning.
4. Fill loop with PrimoChill VUE coolant.
5. Enjoy your VUE Coolant Experience™.
FAILURE TO FOLLOW THE ABOVE STEPS CAN RESULT IN UNDESIRED VUE PERFORMANCE.
Post your experiences and questions/comments in this thread! Pics and video encouraged! We love loop-filling porn here ... especially the slow-motion kind!
Previous Project: Heatripper Threadkiller Build Log
Previous Project: TT-Green Build Log (external link)
Previous Project: RED Glare Build Log (external link)
AMD Ryzen R7 2700X (1826SUS)
ASUS ROG Crosshair VII Hero (Wi-Fi)
NVIDIA TITAN Xp COLLECTORS EDITION (Jedi Order)
G.Skill Trident Z F4-3200C14D-16GTZRX
Samsung 960 Pro 2TB NVMe
Corsair HX1000i 1000W ATX
EKWB EK-Supremacy EVO AMD RGB Nickel-Plexi
Watercool Heatkiller IV for TITAN X and GTX 1080Ti - ACRYL Ni-Bl w/ eBC Backplate
Watercool WCP D5-VARIO Pump with Heatkiller D5-TOP
Watercool Heatkiller Tube 150 w/ MultiPort Top
Watercool MO-RA3 360 LT Radiator - White
Barrow G1/4" Thread 3/8" ID 5/8" OD Compression Fitting - Black
Koolance QD3 Quick Disconnect No-Spill Coupling w/ 10mm x 16mm Compression Fitting - Black
PrimoChill PrimoFlex Advanced LRT 10/16mm Tubing - Crystal Clear
Mayhems Pastel Coolant - Yellow
Be Quiet Silent Wings 3 120mm PWM High Speed Fans (9)
PrimoChill Praxis WetBench - White/Black
Operating System
Windows 10 Pro 1803 64-bit
Acer XB270HU bprz 1440p 144Hz G-Sync Gaming Monitor
Keyboard
Logitech G Pro RGB USB
Mouse
Mousepad
Logitech G440 Hard Gaming Mouse Mat
Audio
Logitech G633 7.1 RGB USB Headset
MNMadman is offline
post #2 of 849 (permalink) Old 11-15-2017, 11:25 AM
Paopawdecarabao's Avatar
Rep: 3 (Unique: 3)
nice I wanted to try it but just got the pastel. Wanted to see other users experience before trying this one out
Paopawdecarabao is offline
post #3 of 849 (permalink) Old 11-15-2017, 11:34 AM - Thread Starter
Totally Tubular
MNMadman's Avatar
My next build will be in February, and I'll be using VUE in that. I plan on really testing out the longevity, keeping it in for as long as possible -- hopefully a year (at which point I'll likely build a new system).
Operating System
Keyboard
Mouse
Mousepad
Audio
MNMadman is offline
post #4 of 849 (permalink) Old 11-15-2017, 11:43 AM
STG3 VET
Juggalo23451's Avatar
Rep: 1174 (Unique: 756)
I am seeing that if you use red it turns darker over time, but how much darker are we talking about. What causes it, heat as an example??
<div class="post-sig post-sig-limit shazam usersig-click"><div class="reparse-sig-lineheight"><p><a href="https://www.overclock.net/water-cooling/913181-water-cooling-guide-noobs.html#post11984918">Water cooling guide for noobs,parts,setup install case suggestions,etc</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/962044-upgrade-time-update-2-3-18-a.html">Case labs TH10/ build log (2 gtx 590s) water cooling oh my</a></p><span></span><p><a href="https://www.overclock.net/water-cooling/528648-heatkiller-club.html">Founder of the Heatkiller Club</a></p><span></span><p><span>W</span><a href="https://www.overclock.net/water-cooling/601449-water-cooling-cases.html">ater cooling case suggestions</a></p></div></div>
Juggalo23451 is offline
post #5 of 849 (permalink) Old 11-15-2017, 11:48 AM
Rep: 3 (Unique: 3)
I would try the purple VUE once my gmk laser keycap arrives next year.
post #6 of 849 (permalink) Old 11-15-2017, 01:10 PM
Phazeshifta's Avatar
Rep: 22 (Unique: 22)
My sterling silver Vue will be here Friday.
Pics coming this weekend!
PhazeS3 - CL S3 Gunmetal/Black - Fatal1ty X370 ITX - Ryzen 1700 @ 3.95 Ghz - 16 GB Trident.Z C14 3200 - EVGA 1080 ti FTW3 - EKWB DDC pump - Hardware Labs Nemesis Radiators - All Barrow fittings - Cablemod Cabling - Barrow RGB kit
Phazeshifta is offline
post #7 of 849 (permalink) Old 11-15-2017, 01:11 PM - Thread Starter
Totally Tubular
MNMadman's Avatar
I would think that as long as you have enough radiator space to handle the heat from your components, then the coolant wouldn't get warm enough to cause color change. That may be a wrong assumption though, as I don't know what VUE's safe operating temps are -- it's not in the info available on the site.
Is this in a new loop or a loop with previous coolant in it? The site says VUE has a high attraction to dyes and will leach them out of loop components, and they highly recommend using their System Reboot on loops that had dyed coolant in them.
Operating System
Keyboard
Mouse
Mousepad
Audio
MNMadman is offline
post #8 of 849 (permalink) Old 11-15-2017, 01:12 PM - Thread Starter
Totally Tubular
MNMadman's Avatar
Yeah, the Candy Purple SX is likely what I'll be using for my new build.
Operating System
Keyboard
Mouse
Mousepad
Audio
MNMadman is offline
post #9 of 849 (permalink) Old 11-15-2017, 02:16 PM
STG3 VET
I contacted them asking about this. They said to make sure your loop is clean, not to have high heat 24/7, and the color will change a small %
post #10 of 849 (permalink) Old 11-15-2017, 02:19 PM
Linux Lobbyist
surfinchina's Avatar
Rep: 13 (Unique: 11)
I ordered the silver also but really wanted to see what the grey looks like.
Mine shipped yesterday but it's the other side of the world...
Seriously, this thread will be great to see what the different colours look like in a real loop!
My name is Peter and I overclock.
CAD Hackintosh rigs:
Gigabyte Aorus X299 Gaming 9....i9-7900x @ 4.8GHz....32Gb G.Skill trident RGB....Radeon Vega Frontier Edition.... EK custom loop
backup Asus X99 Sabertooth...Xeon 2690 12 core @2.4...R9 390x...EK custom loop ditto memory... Fractal Design Define S.
My VUE on Youtube Sterling Silver
surfinchina is offline
