EK EVO 140 ER Fan. Fluctuating Power Issue w/ Aquaero 6 - Page 2 - Overclock.net - An Overclocking Community
post #11 of 12 (permalink) Old 01-07-2018, 10:50 AM - Thread Starter
Linux Lobbyist
NYSE's Avatar
Rep: 8 (Unique: 7)
The fix was to modify the Splitty9.
I ran the 4 pin input from the aquaero to the output of the Splitty9, 1 fan on the RPM labeled header and the other 3 you have to cut the 3 pin on each header.
Resolved the EK EVO issue with the aquaero
NYSE is offline
post #12 of 12 (permalink) Old 03-01-2019, 09:44 AM
Tetrapyloctomist
Aenra's Avatar
Rep: 17 (Unique: 16)
Apologies for the /necro, but if anyone can shed some light here;
- Am assuming that by "3rd pin" you meant removing the tach header? 'Cause the other way round, it would be the 12v?
- Assuming i'm right in the first question, i'm missing something very central here.. why would there be an "active" tach pin on each and every fan header? Doesn't make sense.. the Splitty (if jumper sits correctly) is a simple fan hub; meaning that in said mode, it only 'reads' one tach, rest of the headers only have three pins active: Gd, 12V and Pulse (pwm). There shouldn't be a need to cut or mask anything.. Right?
Pride, honour and purity.
Aenra is offline
