flow direction and order for new loop - Page 2 - Overclock.net - An Overclocking Community
post #11 of 24 (permalink) Old 06-13-2018, 06:09 AM
Iconoclast
Blameless's Avatar
Rep: 3135 (Unique: 1869)
Waste of parts, effort, and added restriction to watercool the ICH10R southbridge when almost any small passive sink will be more than sufficient.
If everything is cleaned properly before assembly, you shouldn't need a filter in the loop. Might be useful for catching flakes of nickel or chrome from a bad plating job, but I'd avoid such iffy components in the first place.
...rightful liberty is unobstructed action according to our will within limits drawn around us by the equal rights of others. I do not add 'within the limits of the law,' because law is often but the tyrant's will, and always so when it violates the right of an individual. -- Thomas Jefferson
Blameless is offline
post #12 of 24 (permalink) Old 06-13-2018, 06:13 AM
Overclocker in training
ThrashZone's Avatar
Rep: 81 (Unique: 60)
Hi,
Well op is shopping on ebay so all products seem a tad on the iffy side
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #13 of 24 (permalink) Old 06-13-2018, 07:11 AM - Thread Starter
Linux Lobbyist
tiny_voices's Avatar
Rep: 0
If I don't need to cool the southbridge then I will skip it for now. I have some adhesive heatsinks I could throw on there.
tiny_voices is offline
post #14 of 24 (permalink) Old 06-13-2018, 07:24 AM - Thread Starter
Linux Lobbyist
Rep: 0
Quote: Originally Posted by jvillaveces View Post
Unless you're using HDDs, that bracket looks like a good location for the pump and res. The only thing you need to ensure is that the pump is fed directly from the res and below it. Other than that, loop order doesn't matter -- what you are showing looks ok, assumin the port locations cooperate. As for filters, their main effect seems to be to restrict flow, I would advise to clean your rads thoroughly before installing and keep the filter away from the loop.
Unfortunately I am using several HDDs and cannot ditch the bay.
post #15 of 24 (permalink) Old 06-13-2018, 10:51 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 407 (Unique: 273)
Did your board not come with the Classified heat sinks on the NB and SB?
ciarlatano is offline
post #16 of 24 (permalink) Old 06-13-2018, 10:58 AM - Thread Starter
Linux Lobbyist
Rep: 0
Has the large heatsink on the x58 chipset and then the smaller one on the southbridge but its all connected via heatpipes. So, if i'm cooling the chipset i have to figure something out for the southbridge.
post #17 of 24 (permalink) Old 06-13-2018, 11:23 AM
Iconoclast
Blameless's Avatar
Honestly, the thing doesn't even need a heatsink.
It's rated to operate at up to 109C and only puts out 4.5W of heat at maximum load, with more typical power consumption/dissipation in the 2-3W range. The motherboard PCB itself will provide all the cooling it needs the overwhelming majority of the time and most heatsinks attached to it on most boards are either redundant, or are actually extra cooling for the IOH/MCH, not the SB itself.
https://www.intel.com/content/dam/do...guidelines.pdf -- page 10, for reference.
If you want some extra peace of mind, the adhesive heatsinks you mention should be plenty.
post #18 of 24 (permalink) Old 06-13-2018, 11:29 AM - Thread Starter
Linux Lobbyist
Rep: 0
Alright, with that info, I'll stick to just putting a block on the x58 chipset and an adhesive heatsink on the SB. Thanks!
Because this is a watercooled PC I do want to ditch the huge x58 heatsink. Lol
FWIW my board is the e760 variant.
post #19 of 24 (permalink) Old 06-13-2018, 11:32 AM
H₂O Aficionado
Slaughtahouse's Avatar
Rep: 117 (Unique: 94)
Flow direction isn't that crucial as you really just want to make sure there isn't so much restriction that the water can't make it back to the pump. As well, it doesn't matter if your radiator comes before or after a component that generates heat. As your coolant will hit equilibrium rather quickly.
What you need to consider, and maybe I missed it in one of the comments, is where & how you will fill and empty your loop. This is the only crucial item you need to address in terms of layout . Having your reservoir or fill port feeding directly into your pump will typically solve this.
This will ensure while you are bleeding the system, you always have a way of introducing water into the pump. The rest is up to you. As you mentioned, you are trying to reduce the amount of tubing runs as possible. So in which ever way that works out, is fine. Just keep in mind the following:
• How am I going to be filling the loop?
• How will I be draining the loop?
• How will I be bleeding the loop?
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC EX 360 Radiator
XSPC Raystorm CPU Block
XSPC Titan/780 GPU Block
EK-XRES 100 Revo D5 - Acetal
XSPC D5 Pump
Fractal Design Meshify C
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Razer Death Adder 2013
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
Bose Companion III's
i7 3930K
Asus Sabertooth X79
Geforce GTX 780 EVGA SC 3GB + XSPC Waterblock
Patriot Viper 3 16GB (4 x 4GB) DDR3 2133
SAMSUNG 840 Series 250GB
Corsair AX850
XIGMATEK Dark Knight II Night Hawk Edition
XSPC 360mm radiator, Raystorm CPU block, D5 pump
Corsair Vengeance Series C70 Military Green (Custom paint)
Operating System
Windows 10
QNIX QX2710 27" 100hz
Samsung 2233RZ 22" 120hz
Keyboard
Logitech g710+
Mouse
Razer DeathAdder 3.5G
Mouse
Mouse Rug
Audio
Bose Companion III's Speakers
Audio
Sennheiser HD 558 Headphones
Audio
Sennheiser HD 6XX Headphones
Slaughtahouse is offline
post #20 of 24 (permalink) Old 06-13-2018, 11:46 AM - Thread Starter
Linux Lobbyist
Rep: 0
https://www.ebay.com/itm/G1-4-110mm-...53.m2749.l2648 this is my pump/res. I should have no problem draining/filling with this setup, right?
Tags
Budget , custom , loop , Watercooling
