flow direction and order for new loop - Page 3 - Overclock.net - An Overclocking Community
post #21 of 24 (permalink) Old 06-13-2018, 11:13 AM
H₂O Aficionado
Slaughtahouse's Avatar
Rep: 117 (Unique: 94)
Quote: Originally Posted by tiny_voices View Post
https://www.ebay.com/itm/G1-4-110mm-...53.m2749.l2648 this is my pump/res. I should have no problem draining/filling with this setup, right?
As far as I can tell, that pump / combo as three inlets. Two in the reservoir & one in the pump. So yes, you do have an additional inlet to open to bleed air.
Think about it logically. In your diagram below, your reservoir & pump are at the bottom of the case. To fill it, you will have to pump the water UP to your reservoir. The issue with that since air is lighter than water, air will always rise. So it will be a bit difficult to bleed those rads as air will eventually get trapped in there.
The easiest way around this is to introduce a fill port at the highest point (top of the case). Not only will this allow you to bleed your loop easily, but it will also allow you to fill it easily.
Don't want to modify your case? Your best bet is to start filling your loop as best you can. Once there is a decent amount of water in the system, close off the port you are using to fill (one of the inlets in the res) and flip your PC over to get those air bubbles out of those rads and into your res. This is very tedious and time consuming.
You always want to get the air into your reservoir vs any other component as you can open your reservoir cap and just allow the air to release.
Unfortunately, there isn't an idea solution for your setup as you're mounting radiators at the top of the case. If you rads are lower, or if your reservoir is at the highest point, it will be easy to fill. However, that is rarely practical.
To give an idea of how to have a setup without needing a fill port, check out this photo of my rig. Whenever I need to fill my loop, I take off the cap of the reservoir and place in a spare piece of tubing into the reservoir. The tubing sticks out of a reservoir (albeit on a tight angle as its very tight in my case) and I essentially have a straw running into my reservoir. I then place a funnel into the tubing, pour water into the funnel, and run the pump. Since my res is my highest point, its pretty quick to bleed.
Spoiler!
Is this achievable in your configuration? Probably not but just because it's not natively supported doesn't mean you can achieve the same methodology. Just need to get creative
I mention all of this because again, in my opinion, is the most crucial aspect to designing a loop configuration. It will make your life a hell of a lot easier if you can fill, bleed, and empty your loop with ease.
-=]░▒▓███ [Official] NVIDIA GTX 780 Owner's Club ███▓▒░[=-
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC EX 360 Radiator
XSPC Raystorm CPU Block
XSPC Titan/780 GPU Block
EK-XRES 100 Revo D5 - Acetal
XSPC D5 Pump
Fractal Design Meshify C
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Razer Death Adder 2013
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
Bose Companion III's
i7 3930K
Asus Sabertooth X79
Geforce GTX 780 EVGA SC 3GB + XSPC Waterblock
Patriot Viper 3 16GB (4 x 4GB) DDR3 2133
SAMSUNG 840 Series 250GB
Corsair AX850
XIGMATEK Dark Knight II Night Hawk Edition
XSPC 360mm radiator, Raystorm CPU block, D5 pump
Corsair Vengeance Series C70 Military Green (Custom paint)
Operating System
Windows 10
QNIX QX2710 27" 100hz
Samsung 2233RZ 22" 120hz
Keyboard
Logitech g710+
Mouse
Razer DeathAdder 3.5G
Mouse
Mouse Rug
Audio
Bose Companion III's Speakers
Audio
Sennheiser HD 558 Headphones
Audio
Sennheiser HD 6XX Headphones
Slaughtahouse is offline
post #22 of 24 (permalink) Old 06-13-2018, 11:15 AM - Thread Starter
Linux Lobbyist
tiny_voices's Avatar
Rep: 0
Thanks for the help!
I'm looking at alternative mounting options for sure but without removing the drive cage, its not going to be easy to get the res above the rads. I may add a fill pot up top though.
tiny_voices is offline
post #23 of 24 (permalink) Old 06-13-2018, 11:24 AM
H₂O Aficionado
I don't know if such a product exists, but if there is radiator has more than two inlets, just purpose one of the inlets as a fill / bleed port. That will solve all of the bleeding concerns that I have.
Edit: http://www.xs-pc.com/radiators-ex-se...iport-radiator
Something like this will make your life much easier. Just saying
Stridsfordon 90
(20 items)
M1 Abrams
(18 items)
Asus G53
(0 items)
Intel 3930K
Asus Sabertooth X79
GTX 780 SC
Patriot Black Viper
Samsung 840 SSD
WD Black 7200 RPM
Corsair AX 850
XSPC D5 Pump
Operating System
Windows 10
QNIX 27"
Keyboard
Logitech G710+
Mouse
Mousepad
Mouse Rug
Audio
Sennheiser HD 6XX
Audio
i7 3930K
Asus Sabertooth X79
Corsair AX850
Operating System
Windows 10
Keyboard
Logitech g710+
Mouse
Mouse
Mouse Rug
Audio
Audio
Audio
post #24 of 24 (permalink) Old 06-13-2018, 07:26 PM
drewafx's Avatar
Rep: 5 (Unique: 5)
Filling is non-issue as long as reservoir is full of water and feeding pump w/o air bubbles.
Draining on the other hand is a pain if you have your drain port somewhere in between and no top port that can be freed.
So I'd recommend separating the pump/res combo into 2 -> pump bottom mounted to chassis with vibration dampening material, and reservoir that can be placed higher than radiator temporarily.
By temporarily, I mean longer tube so you can have it on top of your case while filling, and out of the chassis when draining (with case upside down and reservoir in the sink).
This could be achieved if you give some slack on the tubes running res -> pump, pump -> gpu, and return line into reservoir. Simply mount after filling is done. Dismount when draining.
drewafx is offline
Tags
Budget , custom , loop , Watercooling
