flow direction and order for new loop - Overclock.net - An Overclocking Community
post #1 of 24 (permalink) Old 06-12-2018, 10:50 AM - Thread Starter
Linux Lobbyist
tiny_voices's Avatar
Rep: 0
I'm going to be doing a custom loop with ebay/knockoff parts. I have done loops before but I have not done a "budget loop" before. Id like some input as to what direction I should run everything and if my pump will be fine for all my items in the loop.
Here is the pump: https://www.ebay.com/itm/G1-4-110mm-...53.m2749.l2649
This will be powering the loop through (not in order) CPU block, GPU block, mobo southbridge block, mobo chipset block, and two rads (120 and 240).
Here is a picture of my case with all the components but no res/pump. How would you draw the lines for tubing? I'm using soft tubing and the top 240mm rad can be run in either direction and the pump/res can be mounted where you like.
Thanks for the help!
EDIT: Here are the other components in the loop:
some fittings: https://www.ebay.com/itm/XSPC-G1-4-t...53.m2749.l2649
CPU block: https://www.ebay.com/itm/CPU-Water-C...53.m2749.l2648
GPU block: https://www.ebay.com/itm/Dual-waterw...53.m2749.l2648
chipset block: https://www.ebay.com/itm/Acrylic-Tra...53.m2749.l2649
Southbridge block: https://www.ebay.com/itm/North-South...53.m2749.l2649
also have heatsinks for the GPU memory and VRMs
The build is an EVGA x58 Classified 3, 4.2ghz (hoping to go higher) i7 950, gtx 1060, 8gb ddr3, and some HDDs and SSDs.
tiny_voices is offline
post #2 of 24 (permalink) Old 06-12-2018, 11:07 AM
Custom Loop Snob
Poisoner's Avatar
Rep: 111 (Unique: 96)
Loop order doesn't matter, just make it look pretty or uses the least amount of tubing. The water temp will equalize after some time has passed.
Poisoner is offline
post #3 of 24 (permalink) Old 06-12-2018, 11:09 AM - Thread Starter
Linux Lobbyist
Rep: 0
Yeah my plan is to use as little tubing as possible for a cleaner look. I also have some left over 90s and 45s so hopefully that will help too. My main concern is if my pump will be powerful enough to run the loop through all these blocks.
post #4 of 24 (permalink) Old 06-12-2018, 11:14 AM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Put the gpu then cpu block first in line from the pump and it should be just fine
Add a inline filter to the first block inlet and it won't get blocked with crap.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #5 of 24 (permalink) Old 06-12-2018, 11:25 AM - Thread Starter
Linux Lobbyist
Rep: 0
Quote: Originally Posted by ThrashZone View Post
Hi,
Was thinking about this butdon't know if the pump/res will fit there or not.
post #6 of 24 (permalink) Old 06-12-2018, 02:56 PM
Perennial Noob
jvillaveces's Avatar
Rep: 20 (Unique: 13)
Unless you're using HDDs, that bracket looks like a good location for the pump and res. The only thing you need to ensure is that the pump is fed directly from the res and below it. Other than that, loop order doesn't matter -- what you are showing looks ok, assumin the port locations cooperate. As for filters, their main effect seems to be to restrict flow, I would advise to clean your rads thoroughly before installing and keep the filter away from the loop.
Esmeralda
(25 items)
Eldorado
(23 items)
Overkill HTPC
(18 items)
Intel Core i7-6850K
RAMPAGE V EDITION 10
NVIDIA TITAN X (Pascal)
Corsair Dominator Platinum Special Edition Blackout
Samsung 960 Pro M.2
Samsung 850 Pro
Samsung 850 Pro
Samsung 850 Pro
Samsung 850 Pro
Seasonic SS-1200XP3 PLATINUM
EK-FC GeForce GTX FE Copper/Plexi Water Block (For GeForce 1060/1070/1080/1080Ti/TitanX Pascal and Titan Xp) -Nickel/Plexi Change
EK-FB ASUS R5-E10 Monoblock RGB Edition
Aquacomputer D5 Pump Mechanics USB with Aquabus (x2)
EKWB EK-XTOP Revo D5, Plexi (x2)
Watercool Heatkiller Tube 150
Black Ice SR2 420 radiator
Alphacool X-flow Nexxxos 420 radiator
Noctua SSO2 Bearing Fan NF-A14 iPPC-2000 PWM (x6)
Aquacomputer Aquaero 6 Pro
HexGear R80 Black
Operating System
Windows 10 Pro 64 bit
Asus ROG Swift 24
Keyboard
Razer Blackwidow Ultimate (Green)
Mouse
Corsair Sabre RGB 10,000 DPI
i7 4790k
Asus Z97-Deluxe
EVGA GeForce GTX980 Ti SC ACX2.0
Corsair Dominator Platinum 2133 MHz
Samsung 850 Pro
Optical Drive
Asus DRW-24B1ST
Corsair AX 1200i
EK Supremacy EVO nickel-plexi
Monsoon Free Center compression fittings (gold)
PrimoChill PrimoFlex Advanced LRT crystal clear
EK-FC Titan X - Nickel (x2)
Alphacool 140mm
Aquaero 6 Pro
Alphacool Nexxxos XT45 280 mm
Black Ice GTS 280 x 60
aquacomputer d5 pump mechanics with usb and aquabus interface (x2)
Bitspower Dual D5 Mod Top - POM Version
Bitspower D5 / MCP655 Pump Mod Top S Model - Acetal
Bitspower Water Tank Z-Multi 150 Inline Reservoir (true brass version)
Corsair 760T
Operating System
Windows 10 Pro x64
Keyboard
Razer Ultimate
core i5 6500
Asus Maximus VIII Gene
EVGA GeForce GTX 980 Ti 6GB SC+ GAMING ACX 2.0+
Corsair Vengeance LPX 16GB (4 x 4GB) DDR4 DRAM 2133MHz C13
Samsung 950 PRO -Series 256GB PCIe NVMe - M.2 Internal SSD 2-Inch MZ-V5P256BW
Optical Drive
Pioneer Electronics Internal Blu-Ray Writer (BDR-2209)
Seasonic 1050 Watt Gold
EK Coolstream SE 240
EK Coolstream SE120
Swiftech MCP655 PWM
EK-XRES 100 Revo D5 Pump Top/Reservoir - Acetal
EK-FB ASUS M8G Monoblock - Nickel
EK-FC Titan X/GTX980 Ti Waterblock - Nickel
Monsoon Free Center Hardline Compression Fittings, 1/2" x 5/8"
Monsoon PETG Hardline Tube 1/2 x 5/8
EK-Vardar F4-120 (2200rpm) High Performance Liquid Cooling Fan
Steiger Dynamics LEET Chassis
Operating System
Windows 10 Home
jvillaveces is offline
post #7 of 24 (permalink) Old 06-12-2018, 08:58 PM
drewafx's Avatar
Rep: 5 (Unique: 5)
I'd do parallel loop through 2 radiators and NB SB. Theoretically parallel reduce head pressure loss.
Pump out to GPU
GPU outlet split to rad 1 rad 2 then gathers into CPU inlet (this would be equivalent of large single radiator)
CPU outlet split to NB & SB, pump can have 2 inlets for return line from NB and SB (this would be equivalent of single NB SB block)
Might be worth if you're worried about single pump head pressure loss, might not be worth extra fittings & tube if it works serial just fine.
drewafx is offline
post #8 of 24 (permalink) Old 06-13-2018, 04:38 AM
ThrashZone's Avatar
Hi,
I'd image the size of the gpu would depend on if the pump/ res comb would fit
This is the filter I picked up it is not bad on flow
Two different screens I use the smallest screen personally
http://koolance.com/ins-fltr03-inline-coolant-filter
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #9 of 24 (permalink) Old 06-13-2018, 04:47 AM
toolmaker03's Avatar
Rep: 84 (Unique: 64)
Hi,
if you ever find that the screen in that filter is to small I use screens from my local pipe shop. they are in between the sizes that koolance provides with the filters.
https://imgur.com/a/F8qbquq
https://www.overclock.net/forum/rigbu...tle=AMD+AM3%2B
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #10 of 24 (permalink) Old 06-13-2018, 05:03 AM
ThrashZone's Avatar
Hi,
Thanks just installed the smallest a few days ago seems perfect size but I'll see in a couple months how much stuff it picks up
Thanks for pointing them out
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
Tags
Budget , custom , loop , Watercooling
