Uv? - Overclock.net - An Overclocking Community
Uv?
post #1 of 26 (permalink) Old 07-20-2018, 11:29 AM - Thread Starter
HITTI's Avatar
Rep: 17 (Unique: 17)
Uv?
I bought this uv light strip thinking it was 12 ft long but it's not look in the picture and my mayhems green UV coolant mixture isnt glowing either.
Win10 x64 Pro, Acer XB240H, Corsair Obsidian 750D Black,DEMCifilter Corsair Obsidian 750D Dust Filter Kit,Delidded i7-3770K OC'[email protected], F3-12800CL8D-8GBXM, MSI GeForce GTX 960 2GD5, ASRock Z75 Pro3, EVGA SuperNOVA 750 G2 PSU, EK-KIT L240, 2 x NF-A14-FLX Fans, 2 x NF-F12 iPPC 2000, 2 x Samsung 840 Pro 128GB RAID 0 32KB strip, WD Re WD1003FBYZ 1TB,2TB HGST/Hitachi (HUA723020ALA641), Samsung SH-S223L. Schiit Magni3 & Modi3 and V-Moda M-100 Masters.
HITTI is offline
post #2 of 26 (permalink) Old 07-20-2018, 11:40 AM
I have noticed this with my own build, I have CCFL that really light up my green antifreeze, but I also have UV LED's on my build, that do not seem to get the antifreeze to glow as well as the CCFL does. so my answer to this question, is that it is the type of lighting being used that is causing the issue.
https://www.overclock.net/forum/61-w...ooled-rig.html
now that is supposed to be all black lighting or UV lighting, but as you can see when compared to the CCFL, the LED black lights or UV lights, look almost blue.
AMD AM3+
TEC Power
(21 items)
FX9590
Asus Sabertooth 990FX
GTX580
Samsung 1600
Intel 520 SSD 120Gigs
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
OCZ 1250W, TT 600W, PowerMax 4 X 500W
9 X TEC's 250W 15A 24V
Standard Water cooling to cool the TEC's 6 X 360mm radiators
19 X CPU water blocks
2 X GTX580 GPU water blocks
6 X water pumps
3 X CPU air coolers
Coustom PC case inside a vacuum chamber
Operating System
Windows 7
Dell 30" ultra sharp
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
toolmaker03 is offline
post #3 of 26 (permalink) Old 07-20-2018, 02:18 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 451 (Unique: 298)
LEDs produce far less UV reaction than other sources. Some mfg have stated that "UV" is the color designation and that the bulbs are not UV emitting.
ciarlatano is offline
post #4 of 26 (permalink) Old 07-20-2018, 05:19 PM
gamefoo21's Avatar
Rep: 0
Yup it takes rather expensive LEDs to push up into the UV spectrum and then they age themselves. I have a very expensive flashlight with 6 UV LEDs of two different wavelengths leak detection. Most UV LEDs are purple colour.
CCFL is actually the most efficient means of UV light production.
gamefoo21 is offline
post #5 of 26 (permalink) Old 07-20-2018, 05:47 PM
High Clocker
bmgjet's Avatar
Rep: 191 (Unique: 165)
You need a UV CCFL lamp.
UV LEDs are a scam since UV is just a colour for them unless your paying $60 for a UV LED cob which is still only 1/4 the strenth of a cheap CCFL.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #6 of 26 (permalink) Old 07-20-2018, 06:57 PM
atomicus's Avatar
Rep: 61 (Unique: 41)
Is there actually a good quality UV CCFL option for PC use? The cheap ones are notoriously unreliable, hence LEDs have jumped in, but they're not proper UV.
I don't think I'd even mind paying a lot for one, as long as it did the job properly! LED's generally aren't much good, although the Darkside ones worked out OK for me... I definitely got a good UV reaction from the Mayhems fluid I used, but it faded by a good 50% or so within a couple of weeks. I think the UV component of the fluid itself does break down though, so you'll never get that same 'wow' factor you get when it first reacts. So regardless if LED UV ages or not, you'll still see some degradation in the effect even with a top quality CCFL.
atomicus is offline
post #7 of 26 (permalink) Old 07-21-2018, 02:19 AM - Thread Starter
HITTI's Avatar
Thanks guys I'm buying some CCFL's.
Also the rep button is gone so I can't give you guys a rep so what the hell?
HITTI is offline
post #8 of 26 (permalink) Old 07-21-2018, 02:35 AM - Thread Starter
HITTI's Avatar
HITTI is offline
post #9 of 26 (permalink) Old 07-21-2018, 02:47 AM
Rep: 0
Uv?
UV wave length matters. Mayhems XT-1 Nuke UV green highlighted by single 365nm 500mW UV LED (tiny Nitecore Tube keychain flashlight):
napych is offline
post #10 of 26 (permalink) Old 07-22-2018, 05:38 AM
I have the same CCFL lighting and the controllers that come with them are very cheap and can cause the lights to pop. I would suggest a better controller for those lights. I use a fan/CCFL controller with my setup. there are lots of good options for controlling those lights.
http://www.performance-pcs.com/g-van...er-silver.html
now, if you decide to get one of these controllers, the reason they are so cheap, is that there is a manufacture defect with these controllers. the circuit board will ground to the frame of the controller, so removing the metal mounting screws, and replacing them with plastic screws, then adding plastic washers will fix the issue with this controller.
AMD AM3+
TEC Power
(21 items)
FX9590
GTX580
Samsung 1600
Optical Drive
DVD
Enermax 1350
water cooled
Asus 27"
Keyboard
microsoft ergo
Mouse
RAT 9
Mousepad
steel series
Audio
ZX 7
3930K
DX79SR
GTX580
G skill 2133Mhz
Intel 3700
Optical Drive
Asus
6 X water pumps
3 X CPU air coolers
Operating System
Windows 7
Keyboard
Blackwidow
Mouse
RAT 9
Mouse
Gaming Pad
Audio
2.1 sound
Audio
G930 head set
Intel i7 3930K
Intel DX79SR
GTX580
G-Skill
Intel 3700
Optical Drive
Asus DVD
1250W
Water Cooled
H2OQPower
Operating System
Win7
Asus
Keyboard
Razer
Mouse
R.A.T.9
