[Please Help] Is my water cooler working fine? - Overclock.net - An Overclocking Community
post #1 of 7 (permalink) Old 09-01-2018, 12:56 PM - Thread Starter
Linux Lobbyist
Rep: 0
Sorry guys Im new to OC and water cooling.
I recently bought corsair h110i v2 AIO but feel skeptical about the performance.
I was expecting water cooling can further reduce the temp by 10-15 degree.
However compare to my air cooler, the water cooler can only do well in idle condition but not in full load condition.
My build is AMD 1950X, aorus x399 gaming7, corsair h110i v2
[email protected]: 32C (10C lower than air cooler)
[email protected]: 64C (2-4C lower than air cooler)
For more detail such as water pump, coolant temp pls refer to the attached photo
Under OC 4GHz, I actually stop prime95 after a few second therefore 7x C is not the real result
I observe that the water coolant hv huge temp gap with my CPU under stress condition, does it mean my water cooler is not working well?
I have double check the thermal paste and screw it tight to the CPU.
Please help!
Thanks so much
askpatrickgor is offline
post #2 of 7 (permalink) Old 09-01-2018, 02:10 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1260 (Unique: 687)
I'm surprised it handles Threadripper at all, to be honest. Does the base of the H110i even cover the entire IHS of Threadripper?
AIOs aren't gonna outperform a good air cooler anyway ... not sure where you got the "10-15c better" idea from. High end air coolers usually beat AIOs by a few degrees with less noise.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Raijintek Morpheus II
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU 27" 1440p
LG 24UD58 24" 4K
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mouse
Glorious Model D
Audio
Klipsch PowerGate + FiiO E10K
Audio
Micca RB42
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Dierya DK63-BT 60% (Outemu Blue)
Mouse
Logitech G603 Wireless
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #3 of 7 (permalink) Old 09-01-2018, 06:07 PM
Shooting down fallacies
ciarlatano's Avatar
Rep: 422 (Unique: 282)
Yup.
ciarlatano is offline
post #4 of 7 (permalink) Old 09-01-2018, 06:16 PM
Totally Tubular
MNMadman's Avatar
Rep: 50 (Unique: 41)
Quote: Originally Posted by askpatrickgor View Post
Snip
You made a poor choice in cooler for the Threadripper.
It is important that the base plate of the cooler completely cover the heat spreader of the CPU. The Corsair doesn't, so it cannot apply its full cooling potential.
And AIO coolers generally only perform as well as the good air coolers, sometimes slightly better and sometimes slightly worse. The difference won't be anywhere near 10-15C. A good air cooler that completely covered the heat spreader of the Threadripper CPU would outperform that Corsair.
The 10-15C difference under load would only be seen with real (expensive) liquid cooling. An AIO doesn't qualify.
Previous Project: Heatripper Threadkiller Build Log
Previous Project: TT-Green Build Log (external link)
Previous Project: RED Glare Build Log (external link)
AMD Ryzen R7 2700X (1826SUS)
ASUS ROG Crosshair VII Hero (Wi-Fi)
NVIDIA TITAN Xp COLLECTORS EDITION (Jedi Order)
G.Skill Trident Z F4-3200C14D-16GTZRX
Samsung 960 Pro 2TB NVMe
Corsair HX1000i 1000W ATX
EKWB EK-Supremacy EVO AMD RGB Nickel-Plexi
Watercool Heatkiller IV for TITAN X and GTX 1080Ti - ACRYL Ni-Bl w/ eBC Backplate
Watercool WCP D5-VARIO Pump with Heatkiller D5-TOP
Watercool Heatkiller Tube 150 w/ MultiPort Top
Watercool MO-RA3 360 LT Radiator - White
Barrow G1/4" Thread 3/8" ID 5/8" OD Compression Fitting - Black
Koolance QD3 Quick Disconnect No-Spill Coupling w/ 10mm x 16mm Compression Fitting - Black
PrimoChill PrimoFlex Advanced LRT 10/16mm Tubing - Crystal Clear
Mayhems Pastel Coolant - Yellow
Be Quiet Silent Wings 3 120mm PWM High Speed Fans (9)
PrimoChill Praxis WetBench - White/Black
Operating System
Windows 10 Pro 1803 64-bit
Acer XB270HU bprz 1440p 144Hz G-Sync Gaming Monitor
Keyboard
Logitech G Pro RGB USB
Mouse
Mousepad
Logitech G440 Hard Gaming Mouse Mat
Audio
Logitech G633 7.1 RGB USB Headset
MNMadman is offline
post #5 of 7 (permalink) Old 09-02-2018, 01:18 AM - Thread Starter
Linux Lobbyist
Rep: 0
Guys thanks for all the reply.
I made a typo, should be H100i v2.
So disappointed as it is listed from the AMD website and can support TR
https://www.amd.com/en/thermal-solutions-threadripper
Yes I do know the cold plate wont completely cover the CPU.
Only enermax one does but so many people complain it will die after one year so at the end I choose corsair.
My air cooler wont completely cover the CPU as well but can do a good job therefore I though this AIO maybe the same.
My biggest misconception is I though AIO can perform better than air cooling.
Just curious why people still choose AIO?
As the water pump is more noisy compare to air cooling under stress condition, do they just want the RGB ?
post #6 of 7 (permalink) Old 09-03-2018, 12:08 AM
Old School Overclocker
c5pilot's Avatar
Rep: 24 (Unique: 19)
Well, since you already realize you maybe didn't make the BEST investment, you can at least look at it this way... Your temps under load aren't all that bad provided the temps can remain in that range for an extended period. I think the saddest part is that you didn't lower the noise level over air. That's the other half of water cooling... lower temps/less noise... when done right.
I'd say, save up some money to build a custom loop and sell the AIO if you can while it's still "new". Or as eBayers claim, "Brand new except opened the box to test". Yeah, right.
c5pilot is offline
post #7 of 7 (permalink) Old 09-03-2018, 01:02 AM
PC Enthusiast
Ashura's Avatar
Rep: 47 (Unique: 35)
It does support TR & is keeping it cool. AMD does not claim top level cooling & or silence.
People choose AIO mainly for looks & the fact that it does not block any of your motherboard components.
The problems I have with the big aircoolers is that they block Ram slots, & are too close to the 1st PCIe slot, which can make it quite difficult to remove your GPU.
And can also make it difficult to remove your CPU power connection.
But I choose air coolers simply for their high quality components, good performance, low noise levels, cheaper price & most importantly, reliability.
May I know which air cooler are you referring to? , I suggest you try re-seating the cooler with appropriate TIM application. No need to over tighten it.
https://www.gamersnexus.net/guides/3...ds-benchmarked
PolaRyz
(15 items)
Venomous FX
(14 items)
AMD Ryzen R7 1700x
Asus Crosshair VI Hero
Asus GTX 1060 6Gb
Hyper X Predator 3000Mhz 32gb
Crucial MX100 256 GB
Seagate ST1000DM003
Toshiba DC01ACA300
SeaSonic S12G 750w 80+ Gold
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
LG 23MP68VQ
LG 23MP68VQ
Mouse
Logitech G402 Hyperion Fury
Mouse
Steelseries Qck Mass
AMD FX 8350
MSI 990FXA Gaming
XFX R9 290 DD
G.Skill RipjawsX 16GB [4x4GB] 1600MHz CL9 @1.5v
Seagate ST1000DM003
Phanteks TC14PE
Phanteks Enthoo Pro
Operating System
Windows 10 Pro x64
Dell ST2420L
AOC e2243Fwk 21.5"
Mouse
Razer Deathadder Chroma
Mouse
SteelSeries QcK Mass
Ashura is online now
Tags
1950x , help me , Overclock , temperature
