H110i radiator bent - Overclock.net - An Overclocking Community
H110i radiator bent
post #1 of 5 (permalink) Old 09-04-2018, 05:17 PM - Thread Starter
Linux Lobbyist
Rep: 0
H110i radiator bent
I just got a H110i and found a nasty dent in a section of it. I'm wondering if this is ok to run, or should I bother getting a replacement. Thanks!
Commando2255 is offline
post #2 of 5 (permalink) Old 09-04-2018, 05:29 PM
Linux Lobbyist
Rep: 0
Absolutely fine. The fins on water cooling radiators are much more fragile than the ones on air coolers in order to create more surface area for cooling, thus they bend incredibly easily, you could even bend them with a fingernail. That small dent should make very little difference in cooling performance but if it bothers you, just take a very small flat head screwdriver and straighten them.
TheTwoForks is offline
post #3 of 5 (permalink) Old 09-05-2018, 01:41 AM
Zammin's Avatar
Rep: 29 (Unique: 10)
if its just a couple of bent fins you can straighten them out with something like the plastic knife thing that comes in iFixit tools kits, or really anything thin and flat that you can wedge in there. It won't hurt anything. However, if you bought this new and can take it back to the store for a replacement then I would do that, as it's clearly damaged (even if only a little) and that's unacceptable for a brand new product.
Corsair can be a pain to deal with when it comes to RMAs, sometimes they will try to make you foot the bill for shipping the product to Taiwan. That's why I mentioned taking it back to the store rather than requesting RMA.
In any case it's easily fixable so if it's a great deal of trouble to get it replaced then you may just want to straighten the fins yourself.
Best of luck.
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #4 of 5 (permalink) Old 09-05-2018, 06:00 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 422 (Unique: 282)
You can straighten the fins out if it makes you feel better, but it won't have any affect on performance. It's not worth the time or effort to return and replace, and 99% of them out of the box will have some small fin bends.
ciarlatano is offline
post #5 of 5 (permalink) Old 09-08-2018, 02:11 AM
poah's Avatar
Rep: 6 (Unique: 5)
I'd have sent it back. While you won't have any problems with it you don't really want a damaged rad when it shouldn't be.
poah is offline
