Barrowch FBFT03 Flow Meter vs Unbranded FBFT03 Flow Meter - Page 3 - Overclock.net - An Overclocking Community
post #21 of 27 (permalink) Old 02-11-2019, 12:57 AM - Thread Starter
Zammin's Avatar
Rep: 12 (Unique: 6)
Quote: Originally Posted by ChiTownButcher View Post
Just wanted to check in how these are working out.
Today I installed the flow meter in a temporary test loop and it's working fine. Looks great, doesn't make any noise that I can hear. Pretty happy with it so far.
Primary System Specs: Lian Li PC-O11 DX - ROG Maximus XI Formula - Watercooled Intel 9900k (4.9Ghz) - Watercooled RTX 2080 Ti FE - G.Skill Trident Z RGB 3200Mhz CL16 32GB - Corsair RM1000i PSU - Samsung 970 EVO 2TB NVME SSD
Secondary System Specs: Fractal Design Define S2 - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC - G.Skill Trident Z RGB 3200Mhz CL16 16GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
post #22 of 27 (permalink) Old 02-11-2019, 03:41 AM
Ashcroft's Avatar
Rep: 86 (Unique: 69)
They are undoubtedly the same thing
Ashcroft is offline
post #23 of 27 (permalink) Old 02-11-2019, 05:55 AM - Thread Starter
Zammin's Avatar
Rep: 12 (Unique: 6)
Yep, figured as much. Just reviving the thread because someone wanted me to update it when I'd had a chance to use the device.
Zammin is offline
post #24 of 27 (permalink) Old 03-08-2019, 10:04 AM
Overclocked
scracy's Avatar
Rep: 116 (Unique: 83)
Just looked at one of these myself however my only concern is the use of aluminium inside the unit and not copper.
ROG Maximus X Formula, Intel Core [email protected]/4.8Ghz Cache 1.344V (OCCT Load) (OCCT Stable), Corsair Dominator Platinum ROG Edition [email protected], EVGA GTX1070 SLI, Samsung 960 Pro x2 (Raid 0) (O/S), Samsung 850 Pro x4 (Raid 0) (Data)
ROG THOR 850W PSU, EK Custom Loop 2x PE-360 Radiators, Corsair ML120 Pro Fans, Phanteks Evolv X, Creative Soundblaster Z, Woo Audio WA7D, Sennheiser HD660S, ROG PG279Q 2560x1440 165Hz IPS Monitor, Windows 10 Pro Build 1809.
scracy is offline
post #25 of 27 (permalink) Old 03-08-2019, 12:25 PM
Section31's Avatar
Rep: 7 (Unique: 7)
I had one for one year and it worked well. The vendor was nice and gave me two of them. In fact I may reinstall it down the road. I got an d5 next to replace it but its virtual flow rate is not working (known bug according to aquacomputer).
Section31 is offline
post #26 of 27 (permalink) Old 03-08-2019, 04:34 PM - Thread Starter
Zammin's Avatar
Rep: 12 (Unique: 6)
I a lot of people seem to misunderstand this, the only part of it that is aluminium is the face plate. The rest is all acetal (POM). There is no aluminium internally.
Zammin is offline
post #27 of 27 (permalink) Old 03-08-2019, 08:18 PM
Overclocked
scracy's Avatar
Yeah I eventually found a product sheet on this thing and you are correct
scracy is offline
