Cheap watercool additives/protectors - Page 2 - Overclock.net - An Overclocking Community
Old 12-12-2018, 04:15 PM
OutlawNeedsHelp Level 1
OutlawNeedsHelp's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
PTNuke I've read is not compatible with EK nickle plated water blocks
All copper or other nickle manufactures might be okay.
Huh, didn't know about that
I've used EK blocks, distilled water, PTNuke, and a silver coil for years and never had a real problem.
The nickel blocks I've noticed just became a little stained/copper colored but you can get that off. Not that big a deal imo
Main
(14 items)
[Intel] Core i7 7700k
[ASUS] Maximus IX Formula
[Zotac] RTX 2080 AMP
[Corsair] 16Gb Vengeance LPX 3000MHz
[Crucial] BX100 25Gb
[Samsung] 860 EVO 500Gb
[Seagate] Barracuda 3Tb
[Corsair] AXi 860
[EK] EK Supremacy Evo
[Corsair] Obsidian 750D
Operating System
Win10 64bit
[ASUS] PB287Q 4k
Keyboard
[Corsair] Vengeance K70 Blue
Mouse
[Corsair] M65
OutlawNeedsHelp is offline
Old 12-12-2018, 07:20 PM
Ashcroft Level 1
Ashcroft's Avatar
Hi,
Its not recommended for any Nickel blocks. EK blocks are no different to any others. Watercool and Aquacomputer have now said exactly what EK has been saying for years.
Quote: Originally Posted by Watercool-Jakob View Post
As already pointed out, the reason for this kind of corrosion is simply the PT Nuke. It basically is a copper salt, turning the whole fluid into a mild acid, which attacks nickel plating. Please drain and flush the loop. The block itself is safe to use, the discolorization will not effect it's cooling performance. But for future usage, we STRONGLY advise against ANY biocide additives - they all come with a lot of risks, and aren't that necessary, in our experience. We DO, however, recommend using a corrosion inhibitor. All major brands (EK Cryofuel, Innovatek protect and rebrands, Aquacomputer double protect, all major ready-to-use colored or opaque fluids) have biocidal abbilities integrated, rendering the risky biocide-only additives completey unneccessary.
https://www.overclock.net/forum/27454761-post2912.html
Ashcroft is offline
Old 12-12-2018, 07:33 PM
AllenG Level 1
AllenG's Avatar
Distilled water and Redline Waterwetter added at the ratio they say on the bottle has kept me solid for years. Unless you put contaminated water in, i've never seen it grow anything. Keeps corrosion from occurring while reducing the surface tension of the water and making it slippery... it actually makes the water flow quieter though the blocks. I rarely change coolant or drain the loops, maybe once every 5 years once they're together. Last rig i built in 08 has had it's water changed twice in it's life.
i7 990x @ 4.69GHz
Asus Rampage III Extreme
EVGA GTX780 FTW ACX 2.0 3GB
12 GB Samsung DDR3L @ 2100Mhz
Samsung 840 Pro 256gb Raid0 On LSI 9207
Samsung 840 Pro 512gb
PSN across 10Gb Fiber
Optical Drive
Sony Optiarc DVDRW
Corsair 850HX
DTek Fuzion V2 CPU Block w/ Quad Insert
Laing D5 pump {2MT}
2 x Black Ice Pro 240 Radiators {2MT}
EK Full Cover RIIIE Nickel/Acetal Block
Lian Li PC-A10B
Operating System
Windows 8.1 Enterprise X64
Monoprice 27in WQHD IPS
Keyboard
Das Keyboard Model S
Audio
Creative X-Fi Fatal1ty Platinum
Other
LSI 9207-8i SAS6G Raid Controller
Other
Intel XF SR 10Gb Fiber Adapter
Pentium G3258 @ 4.5GHZ
MSI PC Mate Z97
EVGA GTX 970 SC ACX2.0 4GB
8GB Mushkin Blackline DDR3 2133
256 GB Plextor M6 SSD
WD Black 640GB Raid0
Optical Drive
Sony Optiarc DVDRW
Seasonic S12II 620W
Corsair H50
Old Antec
Operating System
Windows 10 Enterprise x64
Changhong 42in 1080p TV
Keyboard
HP Wireless Keyboard & Thumb tracker
Mouse
Audio
Creative Sound Blaster X-Fi Fatality
Intel Xeon x5687 @ 3.6GHZ
Supermicro X8DT6-F
EVGA GT630 2GB
EVGA GT630 1GB
24GB Hynix DDR3 1333 2R-X4 ECC
Samsung 850 Evo 500GB
Seasonic S12II 620W
Intel LGA1366 HDX Cooler for Extreme Edition CPU
CM Stacker
Operating System
Windows 7 Pro x64
Qnix QX2410R DP
AllenG is offline
Old 12-12-2018, 08:59 PM
Programmer
BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about
BradleyW's Avatar
I just clean all my equipment with distilled water and assemble it. For coolant I use Mayhems X1 clear. Been running the same cooling equipment for around 4 years without issues.
BradleyW is offline
Old 12-12-2018, 10:07 PM
RX7-2nr is an unknown quantity at this point RX7-2nr is an unknown quantity at this point
RX7-2nr's Avatar
I think I'm going to go with dexcool next because I want orange coolant. Mayhems orange dye clogged my system up. All the orange particles stuck together and I've flakes of it all through my system. I used their dark blue dye for years and never had this problem.
How to unlock AMD Official Overclock mode in Catalyst
Easy Automatic Shutdown for Overheating CPU (water pump failure)
XSPC Photon 270 mounting plate for the Corsair 750D
AMD
(6 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
Old 12-12-2018, 10:59 PM
Zammin
Zammin's Avatar
Check out Mayhems Biocide+ (not extreme) and Inhibitor+. Can treat a LOT of fluid, and doesn't cost too much. Safe for all metals and compatible with dyes. Hope it helps.
System Specs: Lian Li PC-011 Dynamic - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC (2050-2063Mhz) - G. Skill Trident Z RGB 3200Mhz 32GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
Old 12-13-2018, 04:15 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Thanks for confirming
So what is the answer/ recommended mixture in your opinion to people that just want to use distilled water and something else to not get algae/....?
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
Old 12-13-2018, 04:23 AM
Jspinks020
Just go get some Glychol/glycerol...and well some of the seals don't like some of that stuff. More like o-rings that the glychol doesn't dissolve and stuff and caught in the block.
Jspinks020 is offline
Old 12-14-2018, 09:02 AM
ThrashZone's Avatar
Hi,
Like to here what
@CptSpig and @Jpmboy use seeing they use soft tubing
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
Old 12-14-2018, 12:17 PM
Maximum OCN
CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about CptSpig has a spectacular aura about
CptSpig's Avatar
Hi,
Like to here what
I use Koolance 702 Liquid Coolant, High-Performance, UV Blue for my chiller warranty. I believe JP uses distilled water and Red Line WaterWetter. I use that stuff in my car and it's great!
X299 RIG
(19 items)
X99 RIG
(17 items)
i9-7980XE
ASUS ROG RAMPAGE VI APEX LGA2066 DDR4 M.2 X299 EATX Motherboard
Nvidia TITAN Xp
G.SKILL TridentZ Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3600 (PC4 28800) Model F4-3600C16Q-32GTZKK
Samsung SSD 960 EVO NVMe M.2 500GB
Samsung SSD 850 Pro 2.5" SATAIII 512 GB
Corsair AX1500i Digital ATX Power Supply
EKWB EK-FC Titan X Pascal - Acetal+Nickel
EXC-800 Portable 800W Recirculating Liquid Chiller
Phobya G-Changer Xtreme NOVA 1080 radiator 60mm - Full Copper
CPU-390I Water Block, Nickel Top
EK-XRES 140 DDC 3.2 PWM Elite
PrimoChill Praxis Wet bench
Operating System
Windows 10 Pro 64 bit
ASUS ROG Swift PG279Q Gaming Monitor - 27" 2K WQHD (2560 x 1440) IPS, overclockable 165Hz, G-SYNC
Keyboard
Corsair Gaming K70 RGB Mechanical Gaming Keyboard — Cherry MX Red
Mouse
M65 PRO RGB FPS Gaming Mouse — Black
Mouse
SteelSeries QcK XXL
Audio
Corsair Vengeance 2100 wireless
i7-6950X Processor
MSI X99A GODLIKE GAMING CARBON
Nvidia TITAN X Pascal
Corsair Dominator Platinum Series 32GB (4 x 8GB) DDR4 DRAM 3200MHz C16 Memory Kit
Samsung SSD 850 PRO 2.5" SATA III 512GB
EVGA SuperNOVA 1000 G2 Power Supply
EK-XLC Predator 360 (incl. QDC) with DDC3.2 PWM pump upgrade with EK-DDC Heatsink Housing - Black
Koolance EXC-800 Portable 800W Recirculating Liquid Chiller
Operating System
Keyboard
Mouse
Mouse
SteelSeries QcK XXL
Audio
CptSpig is offline
