Cheap watercool additives/protectors - Overclock.net - An Overclocking Community
post #1 of 68 (permalink) Old 12-12-2018, 10:41 AM - Thread Starter
dante`afk's Avatar
Rep: 8 (Unique: 8)
Currently using DazMode protector, but fingering I can't spend every time $10 per 2ltrs whenever I need to drain my system to change/add something.
Is there anything cheap I can use that is as effective with pure distilled water?
Thanks
i9 9900k 5.3ghz - evga z390 dark - corsair ax1200i
16 GB g.skill tridentZ 4600 CL 17 - 2080Ti RTX 2160/8000
960PRO 512GB NVMe - 960EVO 512GB NVMe - SanDisk Ultra II 960GB - WD caviar black 3x 4tb
Lian Li O11 - ASUS ROG PG279Q Gsync @ 165hz - 2x Qnix2710 @ 120hz - klipsch promedia 2.1
http://beta.speedtest.net/result/6850164303.png
dante`afk is offline
post #2 of 68 (permalink) Old 12-12-2018, 11:24 AM
Inelastic's Avatar
Rep: 54 (Unique: 49)
PTNuke is a biocide that's really cheap. I'm not sure about corrosion inhibitors since I've never looked that up.
Inelastic is offline
post #3 of 68 (permalink) Old 12-12-2018, 11:27 AM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
Quote: Originally Posted by dante`afk View Post
but fingering
( ͡° ͜ʖ ͡°)
PTNuke.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #4 of 68 (permalink) Old 12-12-2018, 12:28 PM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
Just drain your fluid and catch in a container. Then run it through a coffee filter and reuse it.
That's how I do it and it's fine.
Changing to new fluid is only needed once a year.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #5 of 68 (permalink) Old 12-12-2018, 12:46 PM
neojack's Avatar
Rep: 3 (Unique: 3)
neojack
i know it's controversial, but i use prestone (only the one with ethylene glycol, NOT propylene glycol) at a 50/50 mix with DISTILLED water (not "filterred osmozed equals distilled")
1 gallon is like 16$CAD at wallmart
I am into WC since 5 years, 3 PCs at home used 24/7
before doing that, i used osmozed water + dazmode additive (1 bottle per loop) + silver coil (genuine one from maheims)
results : LOTS of problems of salt deposits around the fittings, green corrosion om the waterblocks, etc. i had to dismount and clean everything once a year, with a toothbrush and vinegar. for each PC. it takes a full week end for each one, each year ! such a pain in the ace.
now after 6 months with prestone, i had to modify stuff on one PC, so I removed the GPU waterblocks : NOTHING , PRISTINE state, even in the smallests fins, not even tarnishing. The copper shinned.
disclaimer : wear gloves AND protective glasses. If you use pieces of cloth to manage the spills (you should), wash them separately from your regular laundry, twice.
Also open the window to get fresh air.
this stuff is a violent poison, and it's sweet. so close your door and do not let pets or toddlers get inside.
wash your hands and face after you are done.
tells your familly or pleople that live with you about what you're doing so they will take care not to touch those clothes or bottles
PS : the dazmode additive IS ethylene glycol (just read the label), just at an higher price. also a small bottle won't get you a 50/50 concentration that kills bacteria.
PPS : do NOT use prestone with propylene glycol. this stuf is used as food additive. so the bacteria likes it.
neojack is offline
post #6 of 68 (permalink) Old 12-12-2018, 12:53 PM
9 Cans of Ravioli
The Pook's Avatar
Quote: Originally Posted by neojack View Post
PPS : do NOT use prestone with propylene glycol. this stuf is actually sugar and used as food additive. so the bacteria likes it.
What? No. Sucrose is not in propylene glycol. PG has a sweet taste, but it's not from sugar.
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Toshiba X300 5TB
Corsair H115i Pro
Operating System
Acer XF270HU
Dell E2311H
Keyboard
Mouse
Logitech G502
Audio
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Dierka K1 120GB
Operating System
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
EVGA GTX 950 2GB
Operating System
Windows XP x86 SP3
Keyboard
Mouse
Logitech M512
The Pook is offline
post #7 of 68 (permalink) Old 12-12-2018, 01:09 PM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
50-50 is a little potent isn't it
Dang it's not a car lol
Last I read it's actually good at 20% antifreeze and even that seems high to me seems 10% would be fine.
Type of I have no idea
Like to use Peak for a bluish and prestone green for well greenish
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #8 of 68 (permalink) Old 12-12-2018, 01:20 PM
neojack's Avatar
Rep: 3 (Unique: 3)
i know but i was tired of cleaning loops.
this solution eliminate all bacteria/algae/corrosion problems , and it's cheap. that's what OP asked for.
maybe 10-20-30% is enough, i don't know
i only tested the 50/50 mix so i report the results
also, it's the mix used in AIO watercooling systems, so i guess it's efficient.
about propylene glycol, ok maybe it's not equivalent to sugar (i edited my first post), but it's not toxic, so it won't kill bacteria/algae.
neojack is offline
post #9 of 68 (permalink) Old 12-12-2018, 01:31 PM
Just hangin' out
Arctucas's Avatar
Rep: 33 (Unique: 32)
PTNuke (benzalkonium chloride) and distilled water.
PC
(14 items)
9900K
eVGA Z390 DARK
eVGA RTX2080 FTW3 ULTRA
GSKILL F4-4500C19D-16GTZKKE
SAMSUNG 960EVO
Optical Drive
TSSTCORP SH-223L
CORSAIR AX1200
LIANG D5, XPSC DUAL BAY RESERVOIR, HEATKILLER IV PRO NICKEL, THERMOCHILL PA140.3, AEROCOOL 140MM SHARK FANS
THERMALTAKE XASER VI
Operating System
W7 U X64 SP1
LG 32GK650F
Keyboard
LOGITECH
Mouse
LOGITECH
Audio
Z-5500
Arctucas is offline
post #10 of 68 (permalink) Old 12-12-2018, 02:20 PM
ThrashZone's Avatar
Hi,
PTNuke I've read is not compatible with EK nickle plated water blocks
All copper or other nickle manufactures might be okay.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
