Recommendations for a custom loop for a quiet extreme rig (Core i7-9900K + GeForce RTX 2080 Ti) - Page 3 - Overclock.net - An Overclocking Community
post #21 of 99 (permalink) Old 01-04-2019, 06:33 AM - Thread Starter
Rep: 5 (Unique: 5)
Quote: Originally Posted by ThrashZone View Post
Hi,
I'd make sure that set of memory is on this apps list
https://benzhaomin.github.io/bdiefinder/
Yes. I had checked befor composing the list. That is the following SKU: F4-4000C18Q-32GTZ
Anyway thanks for the input. Feel free to criticize and suggest out.
lb_felipe is offline
post #22 of 99 (permalink) Old 01-04-2019, 06:52 AM
Overclocker in training
ThrashZone's Avatar
Rep: 33 (Unique: 25)
Hi,
Pretty pricey storage and I suppose os drives you have there hope you actually need all that
Intel optane and 2tb 970's
Which is the os drive intel optane ?
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #23 of 99 (permalink) Old 01-04-2019, 06:59 AM - Thread Starter
Rep: 5 (Unique: 5)
Quote: Originally Posted by broodro0ster View Post
If you don't want to cool the 2080TI, you don't need to of course.
But if you go overkill, you might as well watercool it :-) And you card will max out boostclocks on water. And you don't need to afraid of leaks with softtubing. It's a lot more secure than hardtubing.
The Lian Li V3000 is a super nice case. Put 1 rad in the bottom and 1 in the top, so they both get fresh air. A second radiator doesn't a lot of extra cooling if you feed it with warm air from the first radiator, so that's why the V3000 is excellent for watercooling. I flipped my top exhaust to intake on my Define R6 and I got a lot better temps, but the airflow dropped a bit because I have 6 intakes now and 1 exhaust. I always found the Caselabs cases too big, but the V3000 looks perfect!
Bitspower fittings are fine. You can't go wrong with them.
The SR2 radiators that your updated list are also very good for low fan speeds. Just make sure they fit because they are 60mm thick. Other than that, good choice.
And I see you're going to do dual pump, nice!
I have 1 more suggestion for you and that's Aquaero 6 LT and a water sensor. The Aquaero allows you too cool the loop by watertemp or Delta T. This means that the fans will only spin once the water gets warm. I have one and I don't use fan curves, I a target of 8°C Delta T and the controller choses the fan speed to keep this delta. Under idle my fans are spinning super slow and depending on the heat dumped into the loop the controller accelerates the fans to keep this delta.
Other than that, I have no more comments. You'll have a super nice system!
Thanks.
Watercool still have no stock for GPU WB. I will just build everythin once (I hate rebuilding). However is worth to wait for. Overkill without GPU block is indeed unballanced.
I hope V3000 does the job. It's precisely because of that I chosen it. I will able to use ten fans and even so keep four of them in open air doing the air flow inside the case.
I am torn between these two brands, BP and Barrow.
I wish someone states if V3000 supports two SR2 (bottom and top). Otherwise, i will set to a couple of 360GTS and drop the Noctua adaptors.
Dual pump for the win! Only EK makes this product? A pair of sandwichs is the way to assemble that EK dual pump, or just one is enough?
"Aquaero 6 LT and a water sensor". Recorded. I will include those in the list. What water sensor do you suggest? Aqua Computer too?
Nice to know how your loop works under monitoring and fan speeds. Go quietly.
post #24 of 99 (permalink) Old 01-04-2019, 07:06 AM - Thread Starter
Rep: 5 (Unique: 5)
Hi,
Hi friend. I actually don't need. I just want to spend some bitcoins on a super nice computer. haha
I just want to d oeverythinh as hamoprniouous way. Nothing unbalanced or incongruous. Once I will spend so much for watercooling, chassis, monitor etc, storage must be in line with others products of the list.
I pretend (false cognate in Portuguese, sorry) intend to 905P as OS drive and pair of 970 EVO as mass storage (totalling 4 TB of free storage).
post #25 of 99 (permalink) Old 01-04-2019, 07:16 AM
broodro0ster's Avatar
Rep: 0
Quote: Originally Posted by lb_felipe View Post
Thanks.
This sensor is super accurate: https://shop.aquacomputer.de/product...oducts_id=3774
I have one before and after my radiators, so I know how much the liquid warms up inside the components, but for just controlling by delta T or watertemp, 1 sensor is enough.
I think you'll need 2 Shoggy sandwiches for the pumps. 1 sandwich under each pump.
And why 360GTS and not a 420GTS? Or are they too wide?
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #26 of 99 (permalink) Old 01-04-2019, 07:21 AM - Thread Starter
Rep: 5 (Unique: 5)
List was updated to include sensors:
1 x Intel Core i9-9900K
1 x GIGABYTE Z390 AORUS XTREME
1 x G.SKILL Trident Z DDR4 32GB (8GBx4) 4000MHz 18-19-19-39 1.35v
1 x ASUS ROG Strix GeForce RTX 2080 Ti OC
1 x Intel Optane SSD 905P 1.5TB AIC
2 x Samsung 970 EVO 2TB
1 x Lian Li PC – V3000
1 x Seasonic PRIME Ultra 1000 Titanium
1 x Watercool HEATKILLER IV PRO (INTEL processor) BLACK COPPER
1 x Watercool HEATKILLER IV for ASUS RTX 2080 Ti STRIX - ACRYL Ni-Bl RGB
1 x Watercool HEATKILLER Tube 200
1 x EKWB EK-XTOP Revo Dual D5 PWM Serial - (incl. 2x pump)
2 x Aqua Computer Shoggy Sandwich black edition
1 x Aqua Computer aquaero 6 LT
1 x Aqua Computer Calitemp
2 x Hardware Labs Black Ice SR2 420 MP
10 x Noctua NF-A12x25 PWM
3 x Noctua NA-SFMA1
8 x Bitspower G1/4" Black Sparkle Compression Fitting CC3 Ultimate For ID 3/8" OD 5/8" Tube
4 x Bitspower G1/4" Black Sparkle Triple Rotary 90-Degree Compression Fitting CC3 Ultimate For ID 3/8" OD5/8" Tube
1 x PrimoFlex Advanced LRT Flexible Tubing - 3/8in.ID x 5/8in.OD - Retail Bundle (10ft pack) - Crystal Clear
1 x Mayhems X1 Clear 1 Ltr Premixed
1 x Thermal Grizzly Kryonaut
1 x ZOWIE CELERITAS II
1 x ZOWIE FK2
1 x ZOWIE G-SR
1 x Razer Wolverine Ultimate
1 x Logitech 4K Pro Webcam
1 x ASUS ROG Swift PG27UQ
1 x beyerdynamic Team TYGR
2 x Genelec G Three
1 x Genelec F Two
1 x Genelec 9000A
1 x Blue Jeans Cable LC-1
1 x Blue Jeans Cable MSA-1
post #27 of 99 (permalink) Old 01-04-2019, 07:25 AM - Thread Starter
Rep: 5 (Unique: 5)
Already done, friend.
You have reason. The availability of 480GTS is OK, so should I go with 420GTS or 480GTS (forget 360GTS)?
V3000 officially supports just triple on top, right? Bottom supports quad, by what I got out.
I still am very lost. :/
post #28 of 99 (permalink) Old 01-04-2019, 07:34 AM - Thread Starter
Rep: 5 (Unique: 5)
I am here again... Okay, I put aquero on the list but how I expand it to acommodate more fans?
post #29 of 99 (permalink) Old 01-04-2019, 07:44 AM
Rep: 0
The checked it and the with of a 420 GTS is the same as the 420 SR-2. A 480mm isn't supported by default because they are no screw holes. I've found a modder on youtube that used 2x 480 rads, but made his own adapters.
So I'd get 2x rads. Lian Li specified that's your rads can be up to 85mm thick, so the SR2 fits as well. It's up to you now :-)
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #30 of 99 (permalink) Old 01-04-2019, 07:46 AM
Rep: 0
I used PWM splitters that came with my fans. The Aquaero handles up to 36W per fan channel. 3 fans draw about 6W full speed.
You can also get a Splitty if you prefer that.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
