Recommendations for a custom loop for a quiet extreme rig (Core i7-9900K + GeForce RTX 2080 Ti) - Page 9 - Overclock.net - An Overclocking Community
post #81 of 103 (permalink) Old 01-18-2019, 11:27 AM
boli's Avatar
Rep: 0
Quote: Originally Posted by lb_felipe View Post
I get you. Actually I would choose HWL BI SR2 360 (since I chosen NF-A12x25 PWM first than rads), but I can find it nowhere for sale. So, the locical choice then is SR2 420 keeping the fans, but I really am thinking of swap them for be quiet! Silent Wings 3 140 High Speed PWM. My choice for A12x25 (this specific SKU) is because the told marables about noise profiles even with turbulence to be push or pull on rads. It is like more a sound choice than a performance choice. What do you think about?
I heard/read good things about the Silent Wings 3, but (sadly) have no experience with it. I've been using Noctua fans for years, as well as their CPU air coolers before I started with water…
I also have A14 (actcually A15). I like it, but, if I will pick an 140mm fan, I will stick with SW3 (sounds matters and everybody says it is superior than Noctuas 140 mm in this matter considering static pressure by sound bearing etc).
Now you have me wondering if I should replace the A14s with SW3s. But I think I will wait until Noctua releases the NF-A12x25 design in 140 mm size, hopefully this year (I think they only said that it wouldn't be 2018, or so I read). The A14s are totally fine for me at ~800 rpm.
Thanks. Your conclusion?
The bottom 3 rows in this picture seem the most relevant: As expected the 140 mm fans have better airflow before and after the radiator, at significantly lower speeds, which makes them seem superior. Unfortunately there are no sound measurements, only the mention that the NF-A12x25 are indeed very quiet. Does that make up for the higher speed? I don't know. Haven't found any other conclusive reviews vs 140mm fans either. I sort of want to try.
Do you recommend I purchase a flow meter rather than a flow sensor?
Honestly, I don't know the difference and may have used both terms interchangeably. I only know (have) this one and like it. It does its job and I can't hear it.
boli is offline
post #82 of 103 (permalink) Old 01-25-2019, 04:15 PM - Thread Starter
Rep: 6 (Unique: 6)
Thank you, @boli .
I'm still wondering if I'll be happier with something simpler. In addition, several components are not in stock.
So I'm very interested in Alphacool's solution. They say the pump is extremely quiet. In addition, comes with the praised SW3.
I would like to ask you the following question.
Which fittings among these should I acquire in order to use the quick release of the Eisbaer Extreme and attach it to the ROG Maximus XI Formula's CrossChill EK III?
Implying that the length of the hoses is sufficient for the looping (with the radiator on top, I think so, since one of the legs of the pair of hoses, thanks to the quick disconnect, would be split in half, forming three legs).
https://www.alphacool.com/shop/fitti...se-connectors/
lb_felipe is offline
post #83 of 103 (permalink) Old 01-28-2019, 12:43 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
Do you meant he VPP755 pump? Read the thread in this forum about this pump. You don't want this thing in your PC.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #84 of 103 (permalink) Old 01-28-2019, 01:37 PM - Thread Starter
Rep: 6 (Unique: 6)
I read it. The reports say it is not reliable, but aC says it is a new revision with fixes. I am very lazy so I was wanting to skip yhe hedache of buying so much components and building them. The main problem is to find everything in stock. i hate to buy partical hardwrae to be waiting for available the rest, which, several times, does not happen, forcing us to buy a item that does not match so good as the original planned.
Just Performance PCs sends to Brazil. It is very difficult. I'm going crazy with this. Would it be easier if I travel to the America, buy everthing there and bring to the Brazil?
post #85 of 103 (permalink) Old 01-28-2019, 02:50 PM
GAN77's Avatar
Rep: 2 (Unique: 2)
Good fan. But he needs a transition frame. The round frame of the fan leads to a loss of airflow.
GAN77 is offline
post #86 of 103 (permalink) Old 01-28-2019, 05:27 PM - Thread Starter
Rep: 6 (Unique: 6)
I think it is because of that the NF-A12x25 performs so well on 140mm rads when of using NA-FMA1.
post #87 of 103 (permalink) Old 01-28-2019, 06:06 PM - Thread Starter
Rep: 6 (Unique: 6)
Some questions:
Is 2 liters of coolant enough?
https://www.mayhems.net/collections/x1-pre-mix-5ltr
That is the same stuff as this?
https://www.mayhems.net/collections/.../x1-clear-1ltr
If so, is wothwhile buyng 5 ltr instead of 2 ltr?
Is 3 meters of hoses enough for my intended loop?
This is the hose: https://www.primochill.com/collectio...-crystal-clear
post #88 of 103 (permalink) Old 02-06-2019, 03:37 PM - Thread Starter
Rep: 6 (Unique: 6)
Guys, almost nothing is available.
Lian Li PC 3000
Several Aqua Computer's
Heatkiller IV for Strix
HWL SR2 120mm fan radiators (however I would use adaptor on 140mm fan rads)
etc
i think it is very dificult to build a dream rig with released products in different seasons because always one or another get out of stok throughr EVER all stores.
I wish keep this thread to get help for build an extreme rig, without non-sense expensive bs, then going to get answares for my noob questions.
To start, I get told D5 (from Laing or whatever other brand name is) pumps are the quietest. However, what is the most suitable top to leave it very quiet? I relaly don't care if the flow rate is restrict if it give me low noise with good sound (no hum, fuss, whine etc).
post #89 of 103 (permalink) Old 02-18-2019, 12:29 PM - Thread Starter
Rep: 6 (Unique: 6)
Does the HWL SR2 radiators come with stop fittings for their ports?
post #90 of 103 (permalink) Old 02-18-2019, 03:45 PM
roaming in his fishtank
poisson21's Avatar
Rep: 9 (Unique: 7)
Yes, with 6 of them, letting 2 open for in and out.
poisson21 is offline
