What pumps are better than the Phobya DC12-400 - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 01-11-2019, 10:05 AM
roaming in his fishtank
poisson21's Avatar
Rep: 9 (Unique: 7)
Quote: Originally Posted by ciarlatano View Post
As much as I know this will be met with the usual "yeah, but if you XYZ", I am still going to go ahead and point out that the statement is incorrect, that essentially anyone who has used a D5 and DDC will confirm that DDC are louder, and that dB doesn't even tell the whole story since the tonality of a DDC is far more invasive than that of a D5.
If i'm not wrong the mcp350 is a ddc 3.1 and the mcp355 is a ddc 3.2, and i know that the 3.25 is said to be a bit quieter (but not how much) and i speak only on my experience with the 3.25.
Never owning a d5 i can't state a comparison and (for now) i can't find any sound review of the 3.25.
edit: the only document i found is this one https://hw-lab.com/summary-of-laing-ddc-pumps.html/3 and it confuse me comparing it to your graph because in it the mcp35x go up to ~47db while in the one i found they say max 32 db ??
edit2: i found why the difference ,in the graph it's the mcp35X (didn't know it exist my bad) and it is said to be louder than all the others ddc, but by this much ??
poisson21 is offline
post #12 of 15 (permalink) Old 01-16-2019, 07:47 AM - Thread Starter
Rep: 18 (Unique: 16)
Thanks for all the replies guys
Been here since 2007. I love OCN
The OCN Loud Rig Club
Ryzen
(15 items)
Ryzen 7 1700x
Crosshair VI Hero
MSI 1080Ti Duke OC 11gb
Adata DDR4 2800 XPG Flame 16GB x 1
Corsair Vengeance DDR4 3000 16gb
1 SSD and 6 HDD's
EVGA 1000w Supernova
XSPC CPU block - Phobya pump - Lightech Water Tower - 2 340mm rads.
Thermaltake v71
Operating System
W 10 Pro 64
Samsung 22'' 2253BW - LG 23'' IPS
Keyboard
Microsoft Natural
Mouse
Logi MX518
Mouse
Aluminum Dell XPS
Audio
Behringer 192 USB mixer to Presonus Eris E5 studio monitors
porschedrifter is offline
post #13 of 15 (permalink) Old 01-16-2019, 08:17 AM
ORL
H20 only!
ORL's Avatar
Rep: 18 (Unique: 17)
Just hopping in here really quick.
I have been using DDC pumps for probably over 15 years now in water cooling builds. Never once, and I mean NEVER have I ever needed a heat sink on the pump. 2 of the original three pumps I have are still in operation and have been in many builds. Only one pump has failed and it was no fault of its own, it was my fault in a physical damage situation. The idea of those pumps requiring a heat sink is ludicrous. The pumps do run a bit hotter than some other pumps, but its by design and does not effect the performance.
With that said, there are heat sinks out there for these pumps, and honestly its about style. Not functionality. If anyone ever tells you that your DDC pump requires a heatsink, roll your eyes and walk away.
ORL is offline
post #14 of 15 (permalink) Old 01-22-2019, 06:20 AM
News Fiend
ryan92084's Avatar
Its true they don't need heatsinks but in a very low restriction loop running full tilt they can put out a fair amount of heat so some airflow at minimum is recommended. Them needing sinks notion came about way back when because people were putting pads under them for sound dampening which either melted the pad or killed the pump.
Meh '12
Ryzen 2600x
ASUS Crosshair VII Hero
XFX Fury X
G.SKILL TridentZ Series 16GB (2 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 F4-3200C14D-16GTZSW
SAMSUNG 970 PRO M.2 2280 512GB PCIe Gen3. X4, NVMe
Samsung 850 Pro-Series
Seagate 4TB Enterprise NAS SATA (ST4000VN0001)
WD Black 1TB Performance Desktop Hard Drive WD1003FZEX
SEASONIC PLATINUM-860 860W RT
Black Ice Nemesis 360GTS Radiator x2
Monsoon MMRS Reservoir + D5 pump + mountings
XSPC Raystorm Neo Metal
EKWB Fury X
Monsoon Free Center 1/2ID 3/4OD fittings + Rotaries + plug + Temp probe
BeQuiet SilentWings 3 High Speed PWM x 9
Lian Li PC-O11 Dynamic
Operating System
Windows 10 Pro
LG 27" IPS 27UK650
Keyboard
Massdrop CTRL
Mouse
Logitech g403
Mousepad
HAYATE KOU FX SOFT NINJA Black L
Audio
Blue Yeti Black
Audio
Massdrop x AKG K7XX
Other
LIAN LI O11D-1X ,Riser Cable and cover bracket for PC-O11D
i5 3570k
Z77x-UD5H
Zotac 670 GTX AMP!
G.Skill f3-2400c10D-16gtx
Samsung 850 Pro 128GB
Optical Drive
Some old thing
Seasonic platinum 860w
Custom water
Customized Thermaltake Armor
Operating System
Win 10 pro
Dell U2413
Keyboard
Ducky Shine
Mouse
Logi G502
ryan92084 is offline
post #15 of 15 (permalink) Old 02-26-2019, 11:08 AM
mvermef's Avatar
Rep: 0
I have had a DDC mp355 running since 2010, its seen 1 loop disintegrate due to galvanic corrosion (cause of stupid), cleaned it and put it back into current loop but lately it started to drop CPU signal so I am replacing it shortly already have a D5 ready to go in but finding the time is complete different story. At first I thought it was the PSU tripping out but finally had 1 instance after the reboot halted at the post screen with missing cpu fan speed, went into bios magically fixing itself. So figured it was only a matter of time. On top of that the flow in the res looks low.
mvermef is offline
