What pumps are better than the Phobya DC12-400 - Overclock.net - An Overclocking Community
post #1 of 15 (permalink) Old 01-09-2019, 05:33 PM - Thread Starter
Rep: 18 (Unique: 16)
I currently have the Phobya DC12-400 12Volt Pump, is there a better option?
Looking for some ideas of pumps that can give me better than 800 l/h flowrate. Any ideas?
https://www.aquatuning.us/water-cool...00-12volt-pump
Technical specifications:
Color: Black
Casing material: Plastic
Outer dimensions: (L x W x H): 75 x 66 x 54mm
Connection thread size: G1/4"
Power connector: 3-Pin
Nominal operating voltage: DC 12V
Starting voltage: DC 8V
Power consumption: 18W
Current draw: 1.8A
Max. pressure head: 4m
Flow rate: 800 l/h
Lifespan: 50.000hrs
Noise emission: below 25 db
Been here since 2007. I love OCN
The OCN Loud Rig Club
Ryzen
(15 items)
Ryzen 7 1700x
Crosshair VI Hero
MSI 1080Ti Duke OC 11gb
Adata DDR4 2800 XPG Flame 16GB x 1
Corsair Vengeance DDR4 3000 16gb
1 SSD and 6 HDD's
EVGA 1000w Supernova
XSPC CPU block - Phobya pump - Lightech Water Tower - 2 340mm rads.
Thermaltake v71
Operating System
W 10 Pro 64
Samsung 22'' 2253BW - LG 23'' IPS
Keyboard
Microsoft Natural
Mouse
Logi MX518
Mouse
Aluminum Dell XPS
Audio
Behringer 192 USB mixer to Presonus Eris E5 studio monitors
porschedrifter is offline
post #2 of 15 (permalink) Old 01-10-2019, 12:25 AM
broodro0ster's Avatar
Rep: 2 (Unique: 2)
A D5 pump gives more than 800l/h. But flowrate doesn't say everything. Headpressure is important as well since it's needed to overcome the flow restriction of the blocks.
In a low restriction loop, you will get the best flowrate with a D5. In a high restriction loop, a DDC will perform better.
I have a high restriction loop and I'm using a D5 because it's more silent than a DDC and it still performs good enough. I would only choose a D5 of DDC. They are the best pumps for watercooling PC's.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #3 of 15 (permalink) Old 01-10-2019, 12:33 AM
Anzial's Avatar
Rep: 4 (Unique: 4)
I would also add D5 is very resilient, can last a long time, DDC is a bit more finicky and requires additional cooling (heatsinks)
Anzial is offline
post #4 of 15 (permalink) Old 01-10-2019, 07:18 AM - Thread Starter
Thanks for the reply. I have the phobya now it has a 4m head pressure but I'm looking for something with a better flow rate without losing the head pressure for sure. I'll look into the types you mentioned. This one is slightly audible at max speed when properly dampened, quieter would be a good thing.
Ryzen
(15 items)
Ryzen 7 1700x
Crosshair VI Hero
1 SSD and 6 HDD's
Thermaltake v71
Operating System
W 10 Pro 64
Keyboard
Microsoft Natural
Mouse
Logi MX518
Mouse
Aluminum Dell XPS
Audio
post #5 of 15 (permalink) Old 01-10-2019, 08:03 AM
Rep: 2 (Unique: 2)
The D5 has 4.7m of headpressure and 1500l of flow. A full speed it's audible tho. I run mine around 3500-4000rpm. Temps are only 0.5°C higher at this speed. With a good damper (Shoggy sandwhich) you can probably get it quiter, but my case is too small to add dampers.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
post #6 of 15 (permalink) Old 01-10-2019, 02:07 PM
Rarestbreed's Avatar
Rep: 0
I think D5s must have a bit of lottery on noise as I never hear mine and it runs flat-out 24/7. Even if I open my case and stick my ear down towards it I can't hear it. The only way I know mine is working is to touch the top of it. I have no dampening and it is screwed into a flimsy radiator/fan support. Mine is just an EK with plexi top.
Case: Corsair 900D. CPU: [email protected] MB: Asus Rog Max XI Formula. RAM: Corsair Vengeance 3000mhz. GPU: GTX 1070 EVGA FTW 2. SSD: 2X Sam 960 Evo 500gb, 2x Sam 850pro 256gb, Sandisk Ultra 11 960Gb. PSU: Corsair RM 1000i.
Watercooling: EK CE 420/45mm (Push/pull.) Alphacool UT60 420/60mm (push only.) Res: EK X4 250 (R2.0.) Blocks: Cuplex Kryos Next w/Vision. EK Full cover GPU block, EK/ ASUS Crosschill 3. Pump: EK D5.
Aquaero 6 Pro.
Rarestbreed is offline
post #7 of 15 (permalink) Old 01-10-2019, 03:35 PM
roaming in his fishtank
poisson21's Avatar
Rep: 9 (Unique: 7)
The DDC i own is also really silent (a 3.25 DDC at 4000 rpm) and on an external radiator, 1m away from my feet , and i didn't hear it at all, i have to touch it to know it spin.
The only concern for many D5 and DDC is how you mount them and how much vibration is transmitted to the case.
poisson21 is offline
post #8 of 15 (permalink) Old 01-11-2019, 05:31 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 374 (Unique: 259)
As much as I know this will be met with the usual "yeah, but if you XYZ", I am still going to go ahead and point out that the statement is incorrect, that essentially anyone who has used a D5 and DDC will confirm that DDC are louder, and that dB doesn't even tell the whole story since the tonality of a DDC is far more invasive than that of a D5.
ciarlatano is offline
post #9 of 15 (permalink) Old 01-11-2019, 06:23 AM
apw63's Avatar
Rep: 63 (Unique: 54)
One thing to think about. D5 pumps are mostly cooled by your loop, the heat generated goes in to your loop. DDC pumps are air cooled. If using DDC pumps I would suggest using a heat sink on them, EK make a nice housing. I’ve used it and it works great to keep the pump cool.
Also noise is subjective, what is noisy for me is not for you. My dual D5s I can barely hear. The pumps are isolated from the case. The dual DDC pumps I had where noticeable when sitting at my desk, across the room not really noticeable, the DDC pumps where also isolated from the case.
My System
ASUS ROG Swift PG278Q Owner's club
Asus Maximus X Formula, 8700K, Corsair Dominator Platinum ROC 3200 16GbB, Asus ROC STRIX 1080 Ti OC version.
apw63 is offline
post #10 of 15 (permalink) Old 01-11-2019, 06:49 AM
Retired Staff
JedixJarf's Avatar
Rep: 304 (Unique: 243)
This^. My D5 is almost silent as well, and has been running fine for the past 5 years or so.
JedixJarf is offline
