Help - EK Supremacy Jet Plate I7-3770K - Overclock.net - An Overclocking Community
post #1 of 6 (permalink) Old 01-11-2019, 08:05 AM - Thread Starter
Rep: 0
Hello community, I'd like to have your opinion On the user manual EK Supremacy - it does write this Jet J2 - Optimized 1mm for LGA-1155/1156 CPU And the jet3 for LGA-2011 The one installed by default - J1 - 0.8mm so in principle according to the user manual I should install the J2 but I came across this picture on the EK website https://www.ekwb.com/news/ek-suprema...-for-lga-2011/ Do you think I should install the J3 or install the J2 as specified in the user manual?
I'm lost...
SpMod is offline
post #2 of 6 (permalink) Old 01-11-2019, 09:26 AM
Overclocker in training
ThrashZone's Avatar
Rep: 71 (Unique: 55)
Hi,
It's just thinner no other difference than the preinstalled jet plate.
Thinner would only flex a little more not sure that would help or not
Movement doesn't sould like a good thing
Movement sounds ripe for ware against plastic parts it fits in
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #3 of 6 (permalink) Old 01-15-2019, 09:52 AM
Typo Elemental
Simmons572's Avatar
Moved the thread to the watercooling section. Hopefully someone can help you out here.
AMD Threadripper 1900x
Asus Prime X399-A
EVGA 1080 Classified
Samsung 960 Evo
Intel 750 Series 400GB U.2
Samsung 850 Pro 512 GB
Seasonic 1050w 80+ Gold
Corsair Air 740
Operating System
Windows 10 Pro
i5 6600k
Asus Z170i Pro Gaming
Sapphire R9 Nano
Kingston FURY 16GB (2 x 8GB) DDR4-2400
Samsung 950 Pro 512 GB
Athena AP-MFATX40 400W Flex-ATX
be quiet! ​PURE ROCK ​SLIM
Lian-Li PC-TU 100B
Operating System
Windows 10 Pro
ViewSonic XG2401
Keyboard
MK Disco RGB TKL (KBT Brown)
Mouse
Razer Mamba TE
Mouse
Razer Firefly Cloth
Audio
Beyerdynam​ic DT 770 ​Pro 80 ohm
Audio
Antlion Audio ModMic 4 w/ Mute
Audio
Schiit Fulla 2
Other
Noctua NF-A9x14 (x2)
Other
Fractal Design FD-FAN-SSR2-92
Other
Fractal Design FD-FAN-SSR2-60 (x2)
Other
Fractal Design GP12-WT
i7 6800k
Xeon e5-1620 V3
EVGA Micro 2
Asus GTX 780
Sapphire Fury X
Sapphire RX 480
Kingston - FURY 8GB (2 x 4GB) DDR4-2400
ADATA - XPG Z1 8GB (2 x 4GB) DDR4-2400
SanDisk - SSD PLUS 240GB
Kingston - SSDNow V200
Corsair HX850i
be quiet! - PURE ROCK
Thermaltake Core V21
Operating System
Windows 10 Pro
Simmons572 is offline
post #4 of 6 (permalink) Old 01-16-2019, 12:47 AM
Rarestbreed's Avatar
Rep: 0
Use the J2, which is 115x. You're confusing yourself over nothing.
Case: Corsair 900D. CPU: [email protected] MB: Asus Rog Max XI Formula. RAM: Corsair Vengeance 3000mhz. GPU: GTX 1070 EVGA FTW 2. Drives: 2X Sam 960 Evo 500gb, 2x Sam 850pro 256gb, Sandisk Ultra 11 960Gb, Lacie 4tb external drive (USB type C.) PSU: Corsair RM 1000i.
Watercooling: HWL Nemesis GTX 420/54mm (push only.) Alphacool UT60 420/60mm (push only.) Res: EK X4 250 (R2.0.) Blocks: Cuplex Kryos Next w/Vision. EK Full cover GPU block, EK/ ASUS Crosschill 3. Pump: EK D5.
Aquaero 6 Pro.
Rarestbreed is offline
post #5 of 6 (permalink) Old 01-16-2019, 01:31 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
The jet plate controls the bow of the block. That's it. Is has nothing to do with the actual waterjet.
Just take the recommended plate. Or test them both if you want to, but don't expect huge gains from it.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #6 of 6 (permalink) Old 01-17-2019, 12:42 PM
ThrashZone's Avatar
Hi,
lol I don't see copper or plexi bowing even a little
Only item that bows is the razor blade jet plate
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
