Installation Time - Overclock.net - An Overclocking Community
Installation Time
post #1 of 39 (permalink) Old 01-12-2019, 07:02 AM - Thread Starter
decapitator's Avatar
Rep: 83 (Unique: 73)
Installation Time
So I have all the hardware I think I need right now, gonna install everything today. Can anyone help iron out a few things, like what is the order of operations?
-cleaning, besides the radiator should I clean any other components? What should I clean with? hot water
-Where should I use the 4x 90 degree adapters I have?
-Installing the tubes, do you put the fittings on the components then attach the tubing or make the tubing measurements attach the fittings then screw on?
I was messing around with the tubing and fittings and it was really hard to put the tube on the end of the fitting, and impossible to get it off, had to cut it off, that makes me worried about attaching the fitting to the block first and having to push that hard to get tube all the way on the barb.
-any other tips.
Hardware
Lian li pc 011 air
360 rad
D5 Photon 270 Reservoir/Pump Combo
XSPC Raystorm Pro block
thanks in advance
decapitator is offline
post #2 of 39 (permalink) Old 01-12-2019, 07:22 AM
Overclocker in training
ThrashZone's Avatar
Rep: 186 (Unique: 111)
Hi,
I always wet the tubing and fittings before assembly makes things easier to fasten.
Flush everything with distilled water.
Radiators are usually the filthiest fill half way and shake
Drain into a white plastic bowl and repeat till nothing is in the water
After assembly fill with distilled water and run it for a couple days.. and drain it all out
Then fill with what ever coolant... you've bought to use.
i9-9940x With Optimus SigV2 and Heatkiller VRM copper-plexi water block
ASUS x299 Rampage VI Apex
Titan Xp with copper-plexi Water Block
Trident Z 3600C16 4x8gb's b-die default timings 16-16-16-36 F4-3600C16Q-32GTZKK
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
D5 pump reservoir combo/ GTX280/ VRM block/ GTX280/ D5 top/ CPU block/ GPU block/ Mora 360/ repeat.
MO-RA3 360 PRO stainless steel (25022)
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
10900k batch # X016E724 with Optimus Foundation water block
z490 ASUS Maximus XII Apex
Trident-Z 3600c16 4x8gb kit 16-16-16-36 F4-3600C16Q-32GTZSW
Samsung 970 evo 500gb
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
D5 reservior combo/ 240GTX/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Mora 360LT black 25000
Keyboard
Logitech G710+
Mouse
Red Dragon Perdition
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
D5 reservior combo/ 240GTX/ Koolance VRM block/ 240GTX/ D5 Top/ CPU block/ Gpu block/ Mora 360LT/ back to reservoir
Operating System
AOC G2460PG 24"G-Sync 144Hz
Keyboard
Logitech G710+
Mouse
Audio
ThrashZone is offline
post #3 of 39 (permalink) Old 01-12-2019, 07:27 AM - Thread Starter
Why do this?
post #4 of 39 (permalink) Old 01-12-2019, 07:32 AM
broodro0ster's Avatar
Rep: 9 (Unique: 8)
Quote: Originally Posted by decapitator View Post
Why do this?
An extra flush :-) There will always coming more dirt out of the rads once you have them in use.
Personally I started using the Blitz part 1 kit. Even after flushing my rads 10 times, running my loop for 8 months with 5 flushes, there was still dirt coming out the rads with Blitz part 1.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #5 of 39 (permalink) Old 01-12-2019, 07:35 AM
ThrashZone's Avatar
Hi,
To flush out anything missed in prior cleaning.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #6 of 39 (permalink) Old 01-12-2019, 08:24 AM - Thread Starter
Ok i'll do my leak test with distilled water.
From my diagram when do you think the best place to use the 90's would be? The radiator is set back deeper than the motherboard so I was thinking everywhere but on the rad.
post #7 of 39 (permalink) Old 01-12-2019, 08:28 AM
ThrashZone's Avatar
Hi,
I wouldn't use a 90 if you don't actually need one.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200p2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000P2
Keyboard
Logitech G710+
Mouse
X99 Sabertooth
Optical Drive
LG Blu-Ray WH16NS40
EVGA 1000-P2
Operating System
Keyboard
Logitech G710+
Mouse
Audio
post #8 of 39 (permalink) Old 01-12-2019, 02:53 PM - Thread Starter
I'm about to start cleaning everything, I have some distilled water. Is there anything I should mix with it?
post #9 of 39 (permalink) Old 01-12-2019, 03:12 PM
High Clocker
bmgjet's Avatar
Rep: 192 (Unique: 166)
I always flush radiators on there own.
Heat up the distilled water will help a lot since there is always flux and solder left inside the rads and a bit of heat helps losen that stuff.
So with a new loop id.
Boil 500ml distilled water. Let it cool a bit down to 40-50C.
Tip into radiator so its half full and shake the hell out of it. Repeat 2 - 3 times.
Assemble loop on bench, Flow order being, res - pump - cpu / gpu blocks, radiators. Flush for a hour with distilled water. Changing water twice.
Will end up with some bits in the res, you always do. So disassemble that and clean it.
Assemble loop in pc as will be used in correct flow order with just distilled water.
Leak test it, Drain then fill with your coolant choice if no leaks are found.
Then as yearly maintance.
I drain loop. Hook pump up in revurse flow. Fush with distilled water intill there is no more colour left in the coolant.
Flip pump back around the right way and refill with new coolant.
SLI Voodoo 2 - > GeForce4 MX 420 -> GF 6600GT -> GF 6800GT -> GF 8800Ultra -> AMD 4870 -> AMD 4890 -> CF AMD 5820 -> CF AMD 6850 -> CF AMD 7970 -> SLI GF 680 -> SLI GF 780 -> CF AMD 290X -> GF 980ti -> SLI GF 980ti -> GF 1080ti -> SLI GF 1080ti -> <- RTX 2080ti (DOA/Refunded)
AMD 8120
FX 8350
7970 CFX
680 SLI
bmgjet is offline
post #10 of 39 (permalink) Old 01-12-2019, 03:31 PM - Thread Starter
Alright Imma do most of that.
On a side note, how do I daisy chain rgb fans? They all get their own power obvi but I chain the rgb cable?
