i7 5820k Overheating with a H115i - Overclock.net - An Overclocking Community
post #1 of 18 (permalink) Old 01-18-2019, 11:00 AM - Thread Starter
Rep: 0
Hello all
I have an i7 5820k in stock configuration, It used to be overclocked but high temperatures became an issue so i returned it to default settings. However my temperatures still climb into the 80s and high 70s when under a light load. I can't stress test it at all with programs as the temps immediately spike into the 90s .I got my h115i in 2016 and have generally had high temps in the 70s for most of its life.
I've replaced the thermal paste at least 6 times trying different methods and different pastes which never helped. I recently changed cases to improve airflow which has not helped at all.
Currently I have a push pull configuration to maximize airflow over the radiator but that has not helped either. Even with the pump in performance mode and the fans at 100% my CPU temps still climb into the high 70s and occasionally the 80s depending on the game. With the h115i temps getting into the low 50s.
My pump is always running in performance to keep idle temps around 55 C with the h115i temp reading about 38 c. around 3150 RPM
All other temps in my case are reading in the mid to low 30s at idle.
I opened the side of my case while it was on to poke around and the head of the radiator where the hoses enter was burning hot to the touch.
I think I need a new cooling solution? unless I've done something wrong.
Reddwarf45 is offline
post #2 of 18 (permalink) Old 01-18-2019, 06:01 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
If water temps are high then it's not a mounting issue because heat is making it into the water. So you can stop remounting
Push pull does nothing on the H115i, the fins aren't dense enough for there to be a benefit.
Do you have the problem on other coolers? Could be a badly concave/convex IHS, though unless you have insanely high ambients you're probably looking at an RMA. Even on an OCed 9900K with my pump and fans on low my water temp rarely tops 40c.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #3 of 18 (permalink) Old 01-18-2019, 07:16 PM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
30 months is about all these aio's are good for
Fortunately 5 year warranty so start an rma of the 115
Get a nice air cooler the rma will last about 3-4 weeks likely.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #4 of 18 (permalink) Old 01-20-2019, 07:04 PM - Thread Starter
Rep: 0
I'm just a little hesitant to go with corsair again in case I have the same problem. I have been trying to find a decent other brand but nothing I look at gives me a definitive answer as to thermal performance.
Should I just stick with Corsair?
post #5 of 18 (permalink) Old 01-20-2019, 07:18 PM
white owl's Avatar
Rep: 136 (Unique: 103)
They all use the same components with a few exceptions. None of them make CLCs they just put them together and add crap like rgb and a body kit.
RMA that one or use an air cooler if you want something that will last. Or build a loop, D5s can run for over 5 years, usually 8 to 10.
Quote: Originally Posted by SpeedyVT
If you're not doing extreme things to parts for the sake of extreme things regardless of the part you're not a real overclocker.
Quote: Originally Posted by doyll View Post
The key is generally not which brands are good but which specific products are. Motherboards and GPUs are perfect examples of companies having everything from golden to garbage function/quality.
Hot n Bothered
(12 items)
4790k 4.7Ghz
Asus Sabertooth Z97 MkII 2
EVGA GTX 1080 SC
16gb G.Skill Sniper 2400Mhz
2x Kingston v300 120gb RAID 0
WD Blue
Seasonic 620w M12 II EVO
Cooler Master 212 Evo
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
I have pretty lights.
white owl is offline
post #6 of 18 (permalink) Old 01-20-2019, 07:23 PM
Retired Staff
JedixJarf's Avatar
Rep: 305 (Unique: 244)
JedixJarf is offline
post #7 of 18 (permalink) Old 01-20-2019, 07:30 PM
white owl's Avatar
Quote: Originally Posted by JedixJarf View Post
I'm still wanting to see some performance figures on it. Also, out of stock.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #8 of 18 (permalink) Old 01-20-2019, 07:32 PM
Retired Staff
JedixJarf's Avatar
I'd be surpised if the numbers weren't relatively the same as any other custom loop with a 280, and yeah, i don't think they have been stocked yet (didnt they first show it at CES last week?). Neat idea if you want real loop performance in a AIO-ish form factor.
post #9 of 18 (permalink) Old 01-20-2019, 07:34 PM
white owl's Avatar
I was hoping it was on par with a loop and yes they were just recently announced.
It's crazy how much better a custom loop's 360 is compared to an AIOs performance of the same size.
Hot n Bothered
(12 items)
4790k 4.7Ghz
EVGA GTX 1080 SC
WD Blue
Corsair 450D
Operating System
Windows 10
Nixeus EDG27
Other
post #10 of 18 (permalink) Old 01-21-2019, 02:43 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
Performance should be great. Rad, pump and block have a proven track record of great performance. Unfortunately, the pump also has a reliability track record, and it isn't good - https://www.overclock.net/forum/61-w...-problems.html
AC initially said it would be a D5 in there, then opted for the 755 to cut down cost. Maybe having the 755 mated with a top and housing specifically made for it will help. But what if it doesn't? Will AC continue to use "not our problem" as a customer service model? If so, that's a big issue.
ciarlatano is offline
