Water-cooling CPU and x2 gpu - Page 2 - Overclock.net - An Overclocking Community
post #11 of 16 (permalink) Old 01-29-2019, 01:07 PM
9 Cans of Ravioli
The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about
The Pook's Avatar
Quote: Originally Posted by EKJake View Post
Out of curiosity, what case was it for? Not sure if it's trying to account for spacing of something or if it's just having a moment.
I picked the Fractal Design Meshify S2 so that shouldn't be an issue I wouldn't think, the case is huge. Maybe since it's a new case it's just recommending the small radiators so it doesn't recommend something too big? But for both the top/front/bottom radiators it recommended the SE's and even at the bottom for the "expert mode" configuration it didn't show anything but SE's.
I just tried it with a Lian LI PC-011 and it suggests SEs and PEs, guess it is from my case selection.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.47%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
GeIL 16GB DDR4 3600
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Phanteks P400S Glacier White
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50
Audio
FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #12 of 16 (permalink) Old 01-29-2019, 01:15 PM
EKWB Forum Rep
EKJake Level 1
EKJake's Avatar
Quote: Originally Posted by The Pook View Post
I picked the Fractal Design Meshify S2 so that shouldn't be an issue I wouldn't think, the case is huge. Maybe since it's a new case it's just recommending the small radiators so it doesn't recommend something too big? But for both the top and bottom radiators it recommended the SE's and even at the bottom for the "expert mode" configuration it didn't show anything but SE's.
Yep. That's definitely just the configurator getting itself confused. Thanks for the info. I'll pass this along.
EKWB Forum Rep
EKJake is offline
post #13 of 16 (permalink) Old 02-01-2019, 03:01 AM
ttnuagmada Level 1
ttnuagmada's Avatar
A Single pump is OK if you're fine with running it at 100%, and even then you aren't going to do much better than .6-.7 GPM.
ttnuagmada is offline
post #14 of 16 (permalink) Old 02-01-2019, 11:35 AM
Water Cooling "Wet Head"
rjb64 Level 1
rjb64's Avatar
Not necessary....I run my D5 Vario at around 70% - (Max) 75%....2800 - 3000 RPM.(4300 RPM is 100%)....temps are perfect for a 9900K at 5 - 5.1 Ghz and 2 x 1080Ti's at 2066 Mhz Boost......no need at all for a 2nd pump or separate loops.....Ive been runing this single loop / single pump arrangement since 2014 (prior CPU 3930K at 4.9 Ghz and SLi 780Ti's)......
the pumps also pushing liquid thru 480*360*240 Rads as well as an EK Terminal Block for the GPU's....
9900K 5Ghz w EK Velocity / XSPC Photon Rez - Vario Pump Combo
MXIE w 32GB Platinum 3200
GTX 1080Ti SLi w FC EK Blocks / AX 1200i
Samsung 512G M.2 NVMe / Samsung 512G 860 Pro / Samsung 256G 860 Pro / WD 4 TB Red
Corsair 900D / 480*360*240 Rads - Dell Alienware 3440*1440p 120Hz
Timespy: 18.613K https://www.3dmark.com/spy/5538409
Firestrike Ex: 23.772K https://www.3dmark.com/fs/17562471
rjb64 is offline
post #15 of 16 (permalink) Old 02-01-2019, 11:58 AM
Packet Pusher
Renegade5399 is an unknown quantity at this point Renegade5399 is an unknown quantity at this point Renegade5399 is an unknown quantity at this point
Renegade5399's Avatar
Old school watercooler here.
I can attest to the "single pump is all ya need" point. It really is. A single D5 will do the job, no issue. All I run are these and...HOLY JEEZ THEY ARE $90 NOW??!!! Why, back in my day it was known as a DangerDen D5 and it cost about $50. Dang.
Your issue is going to be proper radiator sizing. You gotta get them watts outta there! So do your research on the heat load generated and get enough of and the right size rads. Take the load rating of the rads published and subtract 25. That should help account for any real world conditions they don't have in the testing lab. For example, my 7900x delidded is a nightmare even on a 360mm rad. At load there is just straight heat blowing out of it and after an hour or so the rad starts to get warm to the touch. In my case, I probably need a bigger and/or more efficient rad.
Next is a proper case and fan/rad mounting and orientation. If all you're doing is dumping heat into the case, then you're gonna have a bad time.
How you plumb is preference. Hard or soft tubing, barbs and clamps or compression fittings. Up to you.
Actual blocks, just ask here. We all have experience with one block or another.
My Sauce Is Much 13373|2 Than Yours
What's in your hardware wallet?
[Gigabyte Aorus 1080 Ti Owner's Club]
Project Blackout
(24 items)
i9 7900X Delidded
ASUS TUF X299 Mark 1
EVGA GeForce RTX 2080 Ti XC BLACK EDITION GAMING
G.SKILL Trident Z Royal Series 16GB - Samsung B-die DDR4 4000
G.SKILL TridentZ RGB Series 16GB - Samsung B-die DDR4 4000
4x 1TB Western Digital Black
2x 480GB Kingston HyperX Savage SSD
2x ADATA Ultimate SU800 1TB 3D NAND
Intel 660p Series M.2 2280 1TB PCI-Express 3.0 x4
INTEL® RAID ADAPTER RSP3DD080F
2x 2TB Western Digital Green
CORSAIR HX Series HX1000
Custom Water Cooling Setup
Bitspower MonoBlock ASX299TUF RGB-Nickel
Thermaltake Core X71 Tempered Glass Edition Black
Operating System
Winders 10 Pro 64bit
Acer GN276HL 27"
HP EliteDisplay E222 22"
Keyboard
Corsair K95 RGB PLATINUM - Cherry MX Speed - Gunmetal
Mouse
HP Omen Reactor
Mousepad
Corsair Gaming MM800 RGB Polaris
Audio
Sades SA926 Gaming Headset
Renegade5399 is offline
post #16 of 16 (permalink) Old 02-01-2019, 01:08 PM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Dual pumps do make getting air out of rads.... a lot faster micro bubbles have no where to hide
Temp wise probably only 2-3c better than one pump depending on how large and complex the rads are.
Also what is hit first from the pump
Most would hit the gpu's first then cpu block.
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
