Water-cooling CPU and x2 gpu - Overclock.net - An Overclocking Community
post #1 of 16 (permalink) Old 01-18-2019, 11:33 PM - Thread Starter
4LC4PON3 is an unknown quantity at this point 4LC4PON3 is an unknown quantity at this point
4LC4PON3's Avatar
My buddy is building a threadripper gaming PC using x2 Vega 64 and is in need of help.
I know zero about water-cooling and were confused on what to buy.
He wants to water-cooling the CPU and both GPUs.
He knows it will be costly but isn't worried about price as much.
Any help is appreciated.
AMD
(16 items)
8350
Asus sabertooth 990fx
7970
Gskill ripjaws 8gb 1600
500GB WD green
Intel 300 series 120gb ssd
Optical Drive
LG M-Disc
Corsair 750w TX
lepa LPALV12-BK CPU cooler
CM masterbox 5 lite
Operating System
Windows 10 Home
Asus 23 vh232h
Keyboard
Logitech k360
Mouse
Logitech m100
Mouse
Steel series (world of warcraft)
Audio
GX Gaming 2.1 (Onboard Audio)
4LC4PON3 is offline
post #2 of 16 (permalink) Old 01-19-2019, 12:00 PM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
What case ?
Two loops are usually best
Single loop would usually need a dual D5 pump and ek is the only manufacture that makes a dual D5 about all ek is good for lol
Hardware labs radiators are usually considered the best
Most people shop at performance pc with OCN55 discount code they also periodically have holiday codes to use as well up to 15% off for non close out or discounted items.
http://www.performance-pcs.com/
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #3 of 16 (permalink) Old 01-19-2019, 02:38 PM
Water Cooling "Wet Head"
rjb64 Level 1
rjb64's Avatar
For the last 4 yrs Ive been cooling 2 GPU's and a CPU with a single loop single pump rez....great performance great temps.....
Presently an OC'd 9900K and Sli 1080Ti's.....
No need for 2 loops and / or 2 pumps provided you have ample radiator....Im using an XSPC Rez / Pump (Vario D5) wit 480*360*240 .....check out my build here....along with my Temps (last picture)
https://www.overclock.net/forum/61-w...enovation.html
9900K 5Ghz w EK Velocity / XSPC Photon Rez - Vario Pump Combo
MXIE w 32GB Platinum 3200
GTX 1080Ti SLi w FC EK Blocks / AX 1200i
Samsung 512G M.2 NVMe / Samsung 512G 860 Pro / Samsung 256G 860 Pro / WD 4 TB Red
Corsair 900D / 480*360*240 Rads - Dell Alienware 3440*1440p 120Hz
Timespy: 18.613K https://www.3dmark.com/spy/5538409
Firestrike Ex: 23.772K https://www.3dmark.com/fs/17562471
rjb64 is offline
post #4 of 16 (permalink) Old 01-19-2019, 06:44 PM - Thread Starter
4LC4PON3's Avatar
The case is this one. If you could please provide links to the hardware needed that would be much help if possible.
Remember he needs a pump, radiator, CPU block and res.
He is not worried about the money he just really wants good stuff for his money
https://m.newegg.com/products/N82E16811129240
AMD
(16 items)
8350
7970
500GB WD green
Optical Drive
LG M-Disc
Corsair 750w TX
CM masterbox 5 lite
Operating System
Windows 10 Home
Asus 23 vh232h
Keyboard
Logitech k360
Mouse
Logitech m100
Mouse
Audio
4LC4PON3 is offline
post #5 of 16 (permalink) Old 01-19-2019, 07:20 PM
I don't even like Linux
cmpxchg8b is an unknown quantity at this point cmpxchg8b is an unknown quantity at this point
cmpxchg8b's Avatar
Research research research.
And single loop with one pump is fine.
cmpxchg8b is offline
post #6 of 16 (permalink) Old 01-19-2019, 07:32 PM
J7SC
...I just finished a Threadripper 2950x build w/ 2 2080 TIs, all water-cooled, in a Core P5 case. For the CPU, the best block is the Watercool Heatkiller IV TR. As you may have already noticed, there are basically two schools of thought: single loop for CPU / GPUs, or separate loops. Both have pros and cons, but for my money, every custom loop I have ever build consists of separate loops > but it does require more space and equipment (i.e. extra pump, extra reservoir unless you go for a dual res one), and I am not sure that would all fit in the Antec case which you listed ...on the other hand, that case should have excellent airflow ! If your friend does go for a single loop, he should use at least two rads, the biggest he can fit inside that particular case...speaking of that case, check out his vid (and the unique res combo)
J7SC is offline
post #7 of 16 (permalink) Old 01-19-2019, 11:39 PM
andrewmp6 Level 1
andrewmp6's Avatar
Which vega cards tho ?
andrewmp6 is offline
post #8 of 16 (permalink) Old 01-29-2019, 12:45 PM
EKWB Forum Rep
EKJake Level 1
EKJake's Avatar
If you haven't purchased anything yet, we have a configurator tool that can help you plan out what all is needed parts wise.
EKWB Forum Rep
EKJake is offline
post #9 of 16 (permalink) Old 01-29-2019, 12:52 PM
9 Cans of Ravioli
The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about The Pook has a spectacular aura about
The Pook's Avatar
I was playing around with the configuratior a few days ago and couldn't figure out why no matter what "purpose" you choose (silence/silence+overclocking/overclocking) it only ever recommends SE radiators. Aren't SEs for slow fans aimed at silence?
Just curious. I blew my PC part budget for the year already so I likely won't be buying anything anyway
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.47%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
GeIL 16GB DDR4 3600
Mushkin Pilot NVMe 1TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Phanteks P400S Glacier White
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Mousepad
X-Ray XL 26" x 14"
Audio
SMSL SA50
Audio
FiiO E10K
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
Audio
Monoprice Modern Retro
Audio
AudioSource LS100
Audio
Polk Audio PSW111
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #10 of 16 (permalink) Old 01-29-2019, 01:03 PM
EKWB Forum Rep
EKJake Level 1
EKJake's Avatar
Out of curiosity, what case was it for? Not sure if it's trying to account for spacing of something or if it's just having a moment.
EKWB Forum Rep
EKJake is offline
