Tricky question please help - Page 2 - Overclock.net - An Overclocking Community
Old 01-19-2019, 03:49 PM
broodro0ster's Avatar
Rep: 0
Maybe he had some alu parts in his loop? That's looks pretty bad.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
Old 01-19-2019, 07:22 PM - Thread Starter
VolatilXplosion's Avatar
Rep: 0
Bad enough not to use? How many of you would still use this block? I attached a picticure again after cleaning pic was taken ***. I don't think there is even any gigabyte auros xtreme waterblocks n e more even if i wanted to replace it. So i mandatory NEED to just run 2 loops and see how it holds up over time? Boi this watercooling is tricky lol
VolatilXplosion is offline
Old 01-20-2019, 10:06 AM
Disclaimer, this is not something I have experienced, so take all this with a grain of salt.
I would probably use it and not do a second loop if I didn't need it for cooling capacity due to added cost, you might as well buy a new block at that point. And I would definitely use an anti-corrosive.
An inline filter sounds like cheap insurance and will give you a place to monitor for issues.
Looking on ebay I wonder about something like this:
https://www.ebay.com/itm/Acrylic-PC-...9401:rk:1:pf:0
Clear fluid and a clear filter and you could see if it was collecting debris without draining the system. I have never used a filter, but since you are worried about the GPU block introducing debris I would install it where the fluid exits that, I assume they would normally be on the pump intake.
Quote:I'm gonna throw in my 2 cents. Not because I'm an expert but because I have a keyboard.
bfromcolo is offline
Old 01-20-2019, 11:48 AM
Overclocker in training
ThrashZone's Avatar
Rep: 31
Hi,
Colored fluid stains a lot
Clear is better get colored hoses if you want color.
Seeing the block I'd put the filter on it's outlet seems the best placement.
Separate loops would contain what ever happens to the block and it's easier to deal with instead of draining the entire system just for issues or maybe issues with the gpu block.
Concentrate or premixed fluid both would have all the stuff that stops growth....
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
Old 01-20-2019, 07:26 PM
Water Cooling "Wet Head"
rjb64's Avatar
Rep: 1
Quote: Originally Posted by ThrashZone View Post
Hi,
Great advice.....clear coolant all the way!!! For just the reason pointed out by thrasher...
9900K 5Ghz w EK Velocity / XSPC Photon Rez - Vario Pump Combo
MXIE w 32GB Platinum 3200
GTX 1080Ti SLi w FC EK Blocks / AX 1200i
Samsung 512G M.2 NVMe / Samsung 512G 860 Pro / Samsung 256G 860 Pro / WD 4 TB Red
Corsair 900D / 480*360*240 Rads - Dell Alienware 3440*1440p 120Hz
Timespy: 18.613K https://www.3dmark.com/spy/5538409
Firestrike Ex: 23.772K https://www.3dmark.com/fs/17562471
rjb64 is offline
Old 01-21-2019, 12:31 AM - Thread Starter
Rep: 0
https://www.ebay.com/itm/Acrylic-PC-...f[/IMG]f:0
@bfromcolo what do you mean need it for cooling capacity? I have already ordered 2 xspc x4 pump reservoir combos that i am going to mount side by side for dual loop a 360 alphacool for the cpu and a 120 alphacool for the gpu both copper. I am all out of funds but as soon as i get some i wouldn't mind getting the xspc filter good idea and mount it after the gpu exit.
Hi,
@ThrashZone I have ordered the primochill soft tubing that comes with "sysprep" & "liquid utopia" which is a concentrate that you mix with distilled water for 1 liter total coolant, have you tried this one? Or anyone else tried liquid utopia with good results? Also thanks for the dual loop advise as i was thinking along those lines, gonna need to drain the gpu loop early to check the fluid for particles cause the xspc filter i want i don't think you can see without taking it out first? And to drain the water into a container to look for contents in the liquid. Also yes the Utopia coolant is clear so is the tubing. I got red tubing but i hated it lol so i returned it and am waiting for the "crystal clear" tubing from primichill lol
Also everyone agrees with me using the 360 for the 5930k and the 120 for the 1080ti right? I mean i only want exhaust rads and those are the only spaces/sizes for exhaust radiators on the 780t, i don"t want the 360 or 240 intake rad setup that the 780t can do cause the hot air entering i can't live with that lol i would rather use those slots for positive pressure intake fans a dedicate a exhaust 360 to the cpu and exhaust 120 for the gpu as the 120 is a thicker rad than the larger but thin 360 so it is smaller but thicker that was my plan i think it is the preferred setup right?
Old 01-21-2019, 05:14 AM
ThrashZone's Avatar
Rep: 31
Hi,
There are a few 120mm rads 30mm-45mm-60mm
Not ideal but if it meets your needs would be as good or better than a gpu aio/ hybrid which also use a thinner rad than I listed.
Personally i wouldn't worry about the heat from the rads both mine are intake top and front all air is forced out the back...
I can see how the front and room for the reservoir might be valid though.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
Old 01-21-2019, 03:16 PM - Thread Starter
Rep: 0
Hi,
Well the reason I worry about intaking in hot air from the rads is because of the m.2 950 pro that sits in the middle of the board, I don't have a heatsink for it yet ( I know they are only like 15 bucks) but if it get hot it can throttle down. I suppose it is not that big of a deal but when I am editing the usage goes up for long periods of time or gaming so that is a constant flow of hot air being pushed into the case. Hmmm..
Old 01-21-2019, 06:23 PM
chas1723's Avatar
Rep: 1
If possible, you want your rads getting fresh cool air for best cpu/GPU temperatures. I have heat probes measuring intake and exhaust temperature on my rads and it normally is only 3-4 degrees delta t on the exhaust side.
Sent from my SM-N950U using Tapatalk
chas1723 is offline
Old 01-21-2019, 06:39 PM
RX7-2nr's Avatar
Rep: 175
Just say no to nickel plating.
AMD
(6 items)
Ryzen 1800x
ASUS ROG Crosshair 6 Hero
MSI Airboost Vega 64 8gb
G. Skill Trident Z 3200
Samsung 960 EVO 500 GB M.2
Samsung 860 EVO 1 TB
Intel Xeon X5650 @ 4.6
ASUS P6T
Powercolor PCS+ 290x
12gb Corsair Dominator
1tb WD Black
250gb Samsung 840 SSD
Cooler Master V850
XSPC Raystorm, EK 290X SE, EX240, EX360
XSPC Photon 270, Alphacool D5 Acetal HF Top
Corsair 750D
Operating System
8.1
Keyboard
Ducky Zero
Mouse
Mionix Naos 7000
RX7-2nr is offline
