Tricky question please help - Page 4 - Overclock.net - An Overclocking Community
post #31 of 33 (permalink) Old 02-04-2019, 04:39 PM
Ashcroft's Avatar
Rep: 86 (Unique: 69)
I think you will be pleasantly surprised how much better it can look with some polishing using a Dremel.
Stripping the rest of the nickel would be harder than it might seem I think. You might end up with just an uglier block.
I'll find some examples of polished blocks after corrosion when I get home from work.
You can always try the stripping after polishing if you don't like the results but once you start stripping there is no going back.
Ashcroft is offline
post #32 of 33 (permalink) Old 02-05-2019, 05:08 PM - Thread Starter
VolatilXplosion's Avatar
Rep: 0
Bro can you please give me any more info on this please? I am considering taking a dremel mini steel bristle brush to smoothen out the corrosion damage then polishing them out. I would love to see some pictures if you know of any. I was also considering some very fine sand paper that i have that i can sand smooth every single part of the corrosion down. As long as the o-ring fits snug and the plexi glas is untouched it should still be leak proof. I am going to order a set of thermal pads and am hesitant but sooooo close to opening up the block and start to sand/dremel all the damage. Also what do you know about stripping? Have any pics or proof of someone doing this? Like eliminating the nickel altogether? I have not seen this done..
VolatilXplosion is offline
post #33 of 33 (permalink) Old 06-03-2019, 05:58 PM - Thread Starter
Rep: 0
It did not work. The corrosion is continuing. I looked around everywhere for a replacement block and all i found was this one
Check this out at Amazon.com
Water Block use for GIGABYTE AORUS GTX 1080Ti Xtreme Edition/GV-N108TAORUS-11GD/Full Cover Graphics Card Copper Radiator https://www.amazon.com/dp/B07JMGMH9P..._OeC9CbNVDSDZC
After it comes in and i install it i will report back the results. At least i can return it if it doesn't fit.
