CPU Cooler Recommendation for 8700k - Page 3 - Overclock.net - An Overclocking Community
post #21 of 42 (permalink) Old 01-21-2019, 06:00 AM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
If you shop around you can probably assemble a custom budget loop 300.us and put an end to the air verses aio arguments
D5 pump res combo/ copper radiator/ 6 compression barb fittings/ copper cpu block/ soft hose boom.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #22 of 42 (permalink) Old 01-21-2019, 06:38 AM
Ghilly's Avatar
Rep: 8 (Unique: 8)
H115i on my 8700k and H100i v2 on my partners 6700k running fantastic over here - both coolers have been basically bombproof since purchase.
5 year warranties on both - you cant really go wrong
The NHD14/15 is also a very good cooler for the budget minded Overclocker . be careful with ram clearance though - my D14 encroached on ram slots - the D15 has cutouts for tall ram but you sacrifice a fan if you install 4 Ram sticks. not an issue if you only run 2 sticks . upgrading to 4 might be a pain though .
My 2 cents.
Ghill
Ghilly is offline
post #23 of 42 (permalink) Old 01-21-2019, 07:45 AM
Meep
Gilles3000's Avatar
Rep: 299 (Unique: 220)
Quote: Originally Posted by Ghilly View Post
The D15 has cutouts for tall ram but you sacrifice a fan if you install 4 Ram sticks. not an issue if you only run 2 sticks . upgrading to 4 might be a pain though .
Although with 4 sticks, if you have a case with some extra clearance, you can just move the front fan upwards a bit so it clears the ram, it isn't really an issue.
Alternatively there are other big coolers with better ram compatibility. I believe the fan of the Thermalright Le Grand Macho just sits in front the ram if you motherboard has enough room between the socket and the ram slots. This was certainly the case with my Macho Rev.B.
Gilles3000 is offline
post #24 of 42 (permalink) Old 01-21-2019, 08:16 AM - Thread Starter
JMattes's Avatar
Rep: 76 (Unique: 69)
I ended up with the H115i Pro.
I ordered more fans which come later this weeks so I can do push/pull.
So far I am happy. It's a lot easier than a real custom waterloop which I've done before..
Laundromatic - Feb 2012 TC Champs!
Laundromatic - July 2012 TC Champs!
JMattes is offline
post #25 of 42 (permalink) Old 01-21-2019, 08:20 AM
ThrashZone's Avatar
Hi,
Soft tubing makes it a lot easier but an aio is too easy
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #26 of 42 (permalink) Old 01-21-2019, 08:28 PM
Water Cooling "Wet Head"
rjb64's Avatar
Rep: 1 (Unique: 1)
Quote: Originally Posted by ciarlatano View Post
They don't use AiO and CLC interchangeably in that article. Every cooler in that article is a CLC. CLCs are a subset of AiO. All CLCs are AiOs. All AiOs are not CLCs. It would be like quoting an article about apples and saying they use "apples" and "fruit" as one in the same.
And that article is a nice way of saying that the NH-D15 is a better choice if you possess the sense of hearing, while CLCs may be a better choice if you are more visually oriented and find one-size-fits-none tubing less offensive than a large air cooler.
Enough already!!! You win
...wow .......you feeling better now lol ....
Great choice OP ...you'll really be happy with that AIO/CLC..... you wont be disspointed and you'll actually be able to see your Mobo and bling .....
9900K 5Ghz w EK Velocity / XSPC Photon Rez - Vario Pump Combo
MXIE w 32GB Platinum 3200
GTX 1080Ti SLi w FC EK Blocks / AX 1200i
Samsung 512G M.2 NVMe / Samsung 512G 860 Pro / Samsung 256G 860 Pro / WD 4 TB Red
Corsair 900D / 480*360*240 Rads - Dell Alienware 3440*1440p 120Hz
Timespy: 18.613K https://www.3dmark.com/spy/5538409
Firestrike Ex: 23.772K https://www.3dmark.com/fs/17562471
rjb64 is offline
post #27 of 42 (permalink) Old 01-21-2019, 08:48 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
The fins aren't dense enough to make push/pull worthwhile. I got virtually identical temps with the 2x OEM Corsair ~50CFM fans as I do with 4x Bitfenix ~100CFM fans in push pull.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is online now
post #28 of 42 (permalink) Old 01-21-2019, 08:59 PM
AMD OC'ing Enthusiast
mattliston's Avatar
Rep: 104 (Unique: 82)
X2 on push-pull not really worthwhile.
My noctua 140mm industrial ppc fans absolutely destroy the stock 140mm corsair rad fans in every way, and even managing to be quieter. Saw maybe 1-3*C if that can even be called something other than margin of error.
BUT push and pull means you can leave the fans at a lower RPM and have a much more pleasant cooling experience. The stock corsair fans are loud, and the bearings will clack on start up (except maglov fans, have not heard those in person yet)
mattliston is offline
post #29 of 42 (permalink) Old 01-21-2019, 09:40 PM
rjb64's Avatar
Rep: 1 (Unique: 1)
...low FPI (Fins Per Inch) Rads + High Static Pressure Fans (push / pull) n low RPM is how I roll ...I found with a lower static pressure but higher Air Flow Fan I needed higher RPM's for the same......found it harder to find the lower FPI Rads in gthe size needed...granted that was almost 5 yrs ago....perhaps theres a better selection of rads out there now
rjb64 is offline
post #30 of 42 (permalink) Old 01-21-2019, 10:20 PM
ChiTownButcher's Avatar
Rep: 34 (Unique: 30)
The bottom line from someone who has done all 3 (High End Air Cooler, 240mm CLC in push/pull, and Custom Loop) here is the truth as I see it in a brief nutshell. I did not include ratings for looks or difficulty as that is more subjective.
1st of all they each have their place and non of them is always the best option. A person must choose based on their priorities of performance, space availability, price, noise, skill, willingness for maintenance, aesthetic and other factors I may not have thought of in this brief description.
1)CLC - It will initially like you have better temps because of the heat capacity of the fluid BUT run your CPU test for 2hr+ and the temps will be in line with a high end air cooler as the fluid hits thermal saturation. Also the are generally noisier due to the pump noise and the fin density of the rad. Performance B+, Noise C+ to B-, Cost B, Reliability C, Repair F, Maintenance B+ (Dusting of the case and Rad every 6mo)
2) High End Air (Noctua NHD-15 or BQuiet! Darkrock Pro 4) You will have faster climbs and drops in temps than a CLC but your max temp will be about the same (usually +1-3deg from CLC). It will also be quieter than a CLC because you have no pump or noise from the air passing radiator dense fins. It's also less expensive and if a fan goes it's easy to recognize and change. When it breaks throw it away and if it doesnt I would still replace it in 4yr for various reasons. Performance B, Noise B+, Cost A, Reliability A, Repair A (Just replace the fan), Maintenance A+ (Normal Dusting of the case)
3) Custom Loop - Quietest over all assuming you have the right amount and selection of radiators/fans. Also since you can go with more rad space you can potentially run the fans really slow. Heat saturation of the fluid can occur but since you have 2-5x as much it takes longer and may never reach the same temps as you can have significantly more radiator space and higher flow rate of fluid (laws of thermodynamics and what happens as two objects approach entropy that would take too long to go over here). Also this option allows you to grow the cooling system to include more than just your CPU. D5 pumps are quiet and VERY reliable. You get the best of all with the downside of cost and maintenance. Performance B+ to A+, Noise B+ to A+, Cost D, Reliability A-, Repair A, Maintenance C (Drain, Flush and Fill every 6mo along with dusting of the case and rads)
Self Proclaimed Gaming Nutt
ChiTownButcher is offline
