CPU Cooler Recommendation for 8700k - Page 5 - Overclock.net - An Overclocking Community
post #41 of 42 (permalink) Old 01-27-2019, 02:13 PM
Shooting down fallacies
ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about
ciarlatano's Avatar
Quote: Originally Posted by mattliston View Post
nearly all your "standard" aio/clc setups from corsair/nzxt/asus/deepcool use aluminum
It's not "nearly all", it's every single one of them. Thank you for adding more validation to my point.
ciarlatano is offline
post #42 of 42 (permalink) Old 01-27-2019, 02:39 PM
wingman99 Level 1
wingman99's Avatar
Quote: Originally Posted by JMattes View Post
I am going to record me temps with just the 2 Corsair fans it came with. Then replace them with the Artic P14s I get and record temps with just the 2. Then I will install the Artics in a push/pull and record again.
This will all be done within an hour or 2 in order to keep ambient room temps as close to static as possible. The tests will be run on Prime 95 and Realtemp and nothing else hardware or software wise will change.
I read that the Artic P14s are great for rads.. so we will see. They are still considered budget fans tho. Not 100% sure they are better than the Corsair ones.
Post your results when you can.
i5 8600K OC 5.0GHz
Noctua NH-U14S
Motherboard Gigabyte Z370-HD3
G.SKILL Ripjaws v 16GB F4-3200C14D-16GVK XMP Speed 3200 14-14-14-34
EVGA GeForce RTX 2070 XC ULTRA GAMING
wingman99 is online now
