CPU Cooler Recommendation for 8700k - Overclock.net - An Overclocking Community
post #1 of 42 (permalink) Old 01-19-2019, 11:21 AM - Thread Starter
JMattes's Avatar
Rep: 76 (Unique: 69)
Building a gaming PC with a 8700k and looking at maybe a closed water loop.
Not sure what kind of gains I can get.
Case is a Switch 810 Nzxt
Recommendations or link to comparisons are appreciated.
JMattes is offline
post #2 of 42 (permalink) Old 01-19-2019, 01:27 PM
Meep
Gilles3000's Avatar
Rep: 299 (Unique: 220)
Budget? The Switch 810 can basically fit any air cooler or AIO, so you're not limited by the case at all.
Gilles3000 is offline
post #3 of 42 (permalink) Old 01-19-2019, 01:34 PM
Senior OCN Member
shilka's Avatar
Rep: 2748 (Unique: 1629)
You are better off with a good air cooler or buying an AIO cooler/kit from EK or Swiftech
https://www.overclock.net/forum/61-w...lc-cooler.html
Seravee
(30 items)
Intel Core I7 6850K
Gigabyte X99 Ultra Gaming
MSI RTX 2070 Super Gaming X Trio
Kingston HyperX DDR4 Savage 3000 MHz
Samsung 840 Evo 500 GB
Corsair Force MP510 1,92 TB
Seagate Ironwolf Pro 14 TB
Seagate Ironwolf 12 TB
WD Ultrastar DC HC530 14 TB
Seagate Ironwolf Pro 12 TB
Seagate Ironwolf Pro 16 TB
Optical Drive
LG CH12NS30
Seasonic Prime Ultra Titanium 750 watt
Noctua NH-D15S
Phanteks Enthoo Luxe Tempered Glass
Operating System
Windows 7 Ultimate 64 bit
Operating System
Windows 10 Home 64 bit
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Corsair Strafe RGB MK.2 with Cherry MX Silent
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Dali E12 F Subwoofer
Audio
Sennheiser HD-599
Other
CableMod 30 CM Magnetic Red LED strip
shilka is online now
post #4 of 42 (permalink) Old 01-19-2019, 01:43 PM
Water Cooling "Wet Head"
rjb64's Avatar
Rep: 1 (Unique: 1)
Theres lots of decent 240 or 360 CLC's out there....Corsair...Swiftech....NZXT....to name a few...240 will be fine for 8700K......google reviews on them....a CLC is far better than an Air Cooler.....you may only get a few yrs life out of the CLC but there reasonalbe cheap and what I consider "disposable"......
9900K 5Ghz w EK Velocity / XSPC Photon Rez - Vario Pump Combo
MXIE w 32GB Platinum 3200
GTX 1080Ti SLi w FC EK Blocks / AX 1200i
Samsung 512G M.2 NVMe / Samsung 512G 860 Pro / Samsung 256G 860 Pro / WD 4 TB Red
Corsair 900D / 480*360*240 Rads - Dell Alienware 3440*1440p 120Hz
Timespy: 18.613K https://www.3dmark.com/spy/5538409
Firestrike Ex: 23.772K https://www.3dmark.com/fs/17562471
rjb64 is offline
post #5 of 42 (permalink) Old 01-19-2019, 01:50 PM
Senior OCN Member
shilka's Avatar
CLC coolers are not better than air coolers unless you are talking about 280mm or larger so you got it backwards
Swiftech kits are not CLC coolers by they way CLC stands for closed liquid cooler and Swiftech liquid coolers are not closed unless they have a new one i dont know about
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
post #6 of 42 (permalink) Old 01-19-2019, 02:06 PM
rjb64's Avatar
Rep: 1 (Unique: 1)
I stand corrected...I was always under the assumption a CLC is NOT a custom loop (open)...so ive always used CLC and AIO as one in the same.(closed loop cooler simply means you cannot open it up or customize it)...you guys get my drift....and I certainly wouldn't go with any Air Cooler against an AIO if you want decent (I gave up on Air Coolers years ago when I started OC'ing)....numbers...that been proven over n over again 8700K...and 9900K OC'ing.....3930K and even when I had a 980X....anyhow...a mix up of terms is all.....
....anyhow...when I "graduated" from Air Coolers to AIO the temp differences were far better....and it doesnt have to be a 280mm Rad...even 240 mm are far better....now Im strictly Open / Custom....although I do have a Corsair 240mm for benching and testing prior to installing in to custom loop...in fact my present 9900K was getting phenominal temps under a Corsair 240 AIO OC'd to 5.1 Ghz ...prior to incorporating into my Loop.....
rjb64 is offline
post #7 of 42 (permalink) Old 01-19-2019, 02:52 PM - Thread Starter
JMattes's Avatar
Thanks for the comments guys!
I am looking at AIOs like Corsair.. maybe the H115i Pro?
Ive done custom water loops before with multiple rads (see profile photo). Just looking for simple and reliable
JMattes is offline
post #8 of 42 (permalink) Old 01-19-2019, 02:54 PM
Senior OCN Member
shilka's Avatar
The H115i is not cheap not quiet and not reliable
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
post #9 of 42 (permalink) Old 01-19-2019, 02:57 PM
9 Cans of Ravioli
The Pook's Avatar
Rep: 1099 (Unique: 636)
H115i is working great on my 9900K @ 5.1. Ditched my Le Grand Macho RT for one when I moved to my new build.
Less reliable than an air cooler, sure, it has moving parts but they also have 3-5 year warranties depending on what one you buy.
Cheap is kind of a subjective, if you make minimum wage then yeah it's really expensive but so is a $70-80 air cooler.
Intel i9 9900K Coffee Lake @ X8 5309mhz (+47.5%)
AMD FX-8320 Vishera @ X4 5022mhz (+43.5%)
Intel i5 4690K Haswell @ X4 5013mhz (+43.2%)
AMD X4 960T Zosma @ X6 4870mhz (+62.3%)
Intel i7 6700 Skylake @ X4 4709mhz (+38.5%)
Intel i5 6400 Skylake @ X4 4588mhz (+69.9%)
2 OP pls nerf
(24 items)
NUC U
(10 items)
i9 9900K
AsRock Z390 Taichi
MSI GTX 1080 Ti
G.Skill DDR4 4133 32GB
Mushkin Pilot NVMe 1TB
HP EX950 NVMe 2TB
Samsung 860 Evo 1TB
Sandisk Ultra II 480GB SSD
Toshiba X300 5TB
Western Digital EZRZ 3TB
Seasonic Focus Plus Gold 750w
Corsair H115i Pro
Fractal Design Meshify S2
Operating System
Windows 10 Education x64
Acer XF270HU
Dell E2311H
Keyboard
CoolerMaster MasterKeys Pro S
Mouse
Logitech G502
Audio
SMSL SA50 + FiiO E10K
Audio
Micca RB42
Audio
Polk Audio PSW111
Audio
Philips Fidelio X2
Audio
Philips SHP9500S
Audio
Audio Technica ATH-M50X
i3 8109U
Intel NUC8i3BEH
Iris Plus 655
Kingston 8GB DDR4 2400
Dierka K1 120GB
ADATA SU800 128GB M.2
Operating System
Windows 10 Professional
Operating System
MX Linux
Keyboard
Rii RKM709 Wireless
Mouse
Logitech M510
i7 860
Advantech AIMB 280 ITX
EVGA GTX 950 2GB
Kingston 2GB DDR3 1333
Seagate Momentus 2.5" 500GB
Western Digital Blue 2.5" 320GB
Silverstone SFX-L Gold 500w
Arctic Alpine 11 GT 2
Silverstone Milo Z ML07B
Operating System
Windows XP x86 SP3
Keyboard
Velocifire TKL01 Outemu Browns
Mouse
Logitech M512
The Pook is offline
post #10 of 42 (permalink) Old 01-19-2019, 03:12 PM
Senior OCN Member
shilka's Avatar
A friend of mine had a H115i and he finally got fed up with the poor cooling performance and the noise and bought a Noctua NH-D15
He now has 20c lower max temps and a fraction of the noise he had before so i am not impressed
Seravee
(30 items)
Intel Core I7 6850K
Optical Drive
LG CH12NS30
Noctua NH-D15S
Operating System
Operating System
Asus PG279Q
LG 55C8 OLED TV
Keyboard
Mouse
Roccat Kone EMP
Mouse
HyperX Fury S XL
Audio
Sennheiser HD 598
Audio
Onkyo TX NR646
Audio
Dali Opticon Vokal
Audio
x2 Dali Opticon 2
Audio
x2 Dali Opticon 1
Audio
Audio
Sennheiser HD-599
Other
