Best way to clean a radiator - Page 2 - Overclock.net - An Overclocking Community
post #11 of 15 (permalink) Old 01-22-2019, 11:28 AM
Senioritis Member
Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about Lady Fitzgerald has a spectacular aura about
Lady Fitzgerald's Avatar
Quote: Originally Posted by rjb64 View Post
...I know another WC'ing enthusiasts that had a fitting made up for his garden hose that he attached to his rez.....opens his drain at the bottom of the loop and simply turns on the water at the hose faucet end (low flow rate) and lets it flush for an hour or so.........brilliant!!!!...
Be VERY careful doing something like that! It would be very, very easy to blow out a radiator or waterline doing that!
Jeannie
i7-3930k
ASUS P9X79 WS
MSI R7850 Twin Frozr 2GD5/OC Radeon HD 7850 2GB 256-bit GDDR5 PCI Express 3.0 x16 HDCP Ready CrossFireX Support Video Card
Monoprice 1x2 powered HDMI Splitter
Kingston HyperX 32GB (8 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K8/32GX
128GB Samsung 840 Pro SSD
4TB Samsung 850 EVO SSD
Optical Drive
LG 12X BD-ROM 16X DVD-ROM 48X CD-ROM SATA Internal Blu-ray Drive CH12LS28
Corsair HX750W
COOLER MASTER GeminII S524 120mm Long Life Sleeve CPU Cooler
Antec Two Hundred v2
Operating System
Windows 7 Ultimate
3 x Asus VG248QE
Vizio VO320E 32" TV
Keyboard
Logitech G510s
Mouse
Logitech M525 with Unifying Receiving
Audio
Corsair SP2500 2.1 Speakers
Audio
ASUS Xonar Essence STX Virtual 7.1 Channels 24-bit 192KHz PCI Express x1 Interface 124 dB SNR / Headphone AMP Card
Other
LSI 9211-8i HBA card
Other
HooToo® HT-CR001 3.5" PCI-E to USB 3.0 Multi-in-One Front Panel Internal Card Reader (6 Memory Slots, Genesys GL3220 Chipset) & SuperSpeed USB 3.0 3-Port Hub (VIA VL800 Chipset), can read & write: M2/MS Micro, High-Speed CF(UDMA), UHS-I, SD, SDHC,...
Other
StarTech HSB220SAT25B 2 Drive 2.5in Trayless Hot Swap SATA Mobile Rack Backplane
i7-5930K Haswell-e
Asus X99-E WS/USB 3.1
Visiontek Radeon 7870 2GB with 6 miniDisplayports
G-Skill Ripjaws 64GB (8x8GB) DDR4 2133
Samsung 850 EVO 4TB SSDs
Samsung 950 Pro 512GB m.2 SSD boot drive
Corsair AX760
Noctua NH-D15S Cpu cooler
Scratch built. Currently under construction at https://www.overclock.net/t/1602023/preparing-for-a-scratch-built-case
Operating System
Win 7 Ultimate
Mouse
Logitech M525
Mouse
El Cheapo Allsop hard plastic
Lady Fitzgerald is online now
post #12 of 15 (permalink) Old 01-28-2019, 08:41 AM
ezveedub is an unknown quantity at this point ezveedub is an unknown quantity at this point
ezveedub's Avatar
This was from a new Magicool 360 slim this weekend...I used pure white vinegar twice in the new radiator...this was the first dump out after like 10 minutes of shaking it. Definitely got lots of left over flux and sediment in there, lol....rinsed with hot water and ran more vinegar, it came out slightly green again, but much less...will run another vinegar wash and rinse for a 3rd time to make sure it all clean before distill water flush and setting up.
Sent from my iPhone using Tapatalk Pro
Intel Processor
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
HAF 932
Operating System
Windows 10
ezveedub is online now
post #13 of 15 (permalink) Old 02-08-2019, 12:59 AM
jelome1989 Level 1
jelome1989's Avatar
Quote: Originally Posted by Edge0fsanity View Post
distilled white vinegar soak for a few hours
flush thoroughly with hot tap water, do a few shake and rinses to get the loose stuff out, there will be a lot of it.
setup small loop with a d5 pump and an inline filter, fill with distilled water and some baking soda. Let it run for 24 hours.
drain the temp loop
shake and rinse with hot tap water until rads are clean
follow with distilled flushing
This is the only method i've found to completely get rid of the crud inside dirty rads.
This is for new and old rads, no? Is the baking soda part absolutely necessary?
jelome1989 is online now
post #14 of 15 (permalink) Old 02-08-2019, 04:58 AM
Overclocker
Edge0fsanity Level 1
Edge0fsanity's Avatar
new and old, and yes the baking soda part is necessary. You don't have to run a loop with a filter with it, just filling the rad with some baking soda and water is enough. This part is to neutralize any acids left behind from the vinegar.
I run the loop with the filter and baking soda because i find it easier than the shake and rinse method for getting the crud out once the vinegar breaks it down. The temp loop with the filter will grab most of the crud out of the rads, it significantly shortens the shake and rinse portion of this.
Singularity Cases Spectre
Intel 9900k @ 5.2ghz 1.365v
Nvidia 2080 TI SLI @ 2130mhz
G.Skill Trident Z memory 2x8gb 4000mhz 16-17-17-28 1.45v
Gigabyte z390 Aorus Master Motherboard
EVGA 1200w P2 psu
Custom waterloop
Edge0fsanity is offline
post #15 of 15 (permalink) Old 02-08-2019, 06:46 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Dawn disk soap way too easy
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
