Weird behave of D5 ..... any ideea? - Page 2 - Overclock.net - An Overclocking Community
post #11 of 32 (permalink) Old 01-23-2019, 09:46 AM - Thread Starter
um2802's Avatar
Rep: 0
Ok, i will try that to see what will be
THX for input.
The flow meter it is above the in for gpu wb, i think to move it at out of pump / in of cpu wb, will change anything that move?
um2802 is offline
post #12 of 32 (permalink) Old 01-23-2019, 09:56 AM
Overclocker in training
ThrashZone's Avatar
Rep: 33 (Unique: 25)
Hi,
Yeah if you want to use a flow meter try the inlet of the pump or outlet which ever is easiest to see.
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #13 of 32 (permalink) Old 01-23-2019, 01:33 PM - Thread Starter
um2802's Avatar
Rep: 0
Ok, i did the test.
And now i am more confused.
So, i switch the red arrow from 5 down below to 1, at the position 1 the pump is had no vibration, barely hearing, the speed it is around 1850 rpm and the flow it is 0.0 L/ h
I really do not understand....
This is the flow meter : https://shop.aquacomputer.de/product...oducts_id=2294
um2802 is offline
post #14 of 32 (permalink) Old 01-23-2019, 01:55 PM
broodro0ster's Avatar
Rep: 0
Quote: Originally Posted by um2802 View Post
Ok, i did the test.
Yea, the D5 at 1850rpm is really silent. I guess there is something wrong with the flow meter since your description about the pump is normal behavior.
Can you still return the flow meter and get it replaced?
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #15 of 32 (permalink) Old 01-23-2019, 02:05 PM
I don't even like Linux
cmpxchg8b's Avatar
Rep: 96 (Unique: 73)
Yep, bad flow meter.
Get rid of it, it does not do much, even when it's working well.
cmpxchg8b is offline
post #16 of 32 (permalink) Old 01-23-2019, 02:09 PM - Thread Starter
um2802's Avatar
Rep: 0
I think can send it back to caseking.
But what i put instead?
um2802 is offline
post #17 of 32 (permalink) Old 01-23-2019, 02:58 PM
ThrashZone's Avatar
Hi,
Water temp sensor.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #18 of 32 (permalink) Old 01-23-2019, 03:04 PM - Thread Starter
um2802's Avatar
Rep: 0
um2802 is offline
post #19 of 32 (permalink) Old 01-23-2019, 04:23 PM
cmpxchg8b's Avatar
Heat load changes -> Temperature goes up and down -> It makes sense to adjust fans up and down.
...on the other hand...
Loop restriction is constant -> Water flow does not change -> Set the pump's RPM once to get good flow, and leave it there.
Easy choice.
post #20 of 32 (permalink) Old 01-23-2019, 04:26 PM
ThrashZone's Avatar
Hi,
More like this
http://www.xs-pc.com/temperature-sen...-inline-sensor
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
