Weird behave of D5 ..... any ideea? - Page 3 - Overclock.net - An Overclocking Community
post #21 of 32 (permalink) Old 01-23-2019, 03:36 PM
Jidonsu's Avatar
Rep: 23 (Unique: 22)
Quote: Originally Posted by um2802 View Post
Ok, i did the test.
And now i am more confused.
So, i switch the red arrow from 5 down below to 1, at the position 1 the pump is had no vibration, barely hearing, the speed it is around 1850 rpm and the flow it is 0.0 L/ h
I really do not understand....
This is the flow meter : https://shop.aquacomputer.de/product...oducts_id=2294
That's not surprising. Depending the amount of restriction in the loop, sometimes you get next to zero flow below a certain rpm.
Also, the flow meter won't be accurate without a calibration. You also don't really want any turns immediate before or after the meter, and since you have it plugged directly into a radiator, you're introducing some turbulence. I assume that may mess with the pressure drop measure that the flowmeter uses. Aquacomputer also recommends at least 5cm of tubing before and after it.
Jidonsu is offline
post #22 of 32 (permalink) Old 01-24-2019, 02:37 AM
broodro0ster's Avatar
Rep: 3 (Unique: 3)
This is true for the MPS pressure sensors, but TS has the mechanical version which should be very accurate. I suspect that his one is failing or clogged up.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #23 of 32 (permalink) Old 01-24-2019, 11:26 AM - Thread Starter
um2802's Avatar
Rep: 0
I will be out of town few days, but when return, i will opened it to see if it is something wrong, hardware, in case of not, i will mount in another position in the loop.
Another thing i noticed, when the temp of water go up - 34 / 36 degree C, the flow incline to decrease around 52 / 54 L/h, that fact point something wrong in loop or it is normal behavior of rising water temp?
um2802 is offline
post #24 of 32 (permalink) Old 01-25-2019, 01:13 AM
jura11's Avatar
Rep: 100 (Unique: 64)
Hi there
Hard to say, but in my case higher water temperature usually will rise water flow
Have look I'm running 4*360mm radiators plus MO-ra3 360mm and with Aquacomputer Kryos CPU block and 4*GPUs with EK GPU WB and my flow is around 141-142LPH if water temperature is around 18-20°C, when water temperature drops bellow 15°C or lessmy flow drops to 137LPH but when water temperature rise above 24°C my flow is around 149LPH, I have done few tests lately
In yours case hard to say why you getting no flow at all or some flow
My loop is pretty large with multiple 90° fittings in total around 12 I think, but I'm running two pairs of QDC fittings and multiple pumps(XSPC D5 Vario which is on my Monsoon MMRS reservoir, EK DDC 3.2 PWM Elite edition which is hidden in pedestal basement with another Barrow 17w DDC pump)
This is my loop
https://i.imgur.com/k2niFTP.jpg
At that moment I run only 3*GPUs setup and I changed motherboard for ASRock X99 WS and added to loop extra GPU or 4th RTX 2080Ti and changed tubing from Mayhems UV White to EK ZMT
I assume you are running Aquaero or do you have Aquacomputer Aquasuite?
With Aquacomputer High Flow shouldn't matter where is yours flow sensor located and what coolant are you running?
Assume you are not running Pastel coolant or do you?
I know MPS400 or any MPS sensor you shouldn't run with pastel coolants as they can clog the sensor
Hope this helps
Thanks, Jura
jura11 is offline
post #25 of 32 (permalink) Old 01-25-2019, 02:43 AM - Thread Starter
um2802's Avatar
Rep: 0
I have Quadro controller from Aquacomputer and Aquacomputer Aquasuite.
Nope, no color fluid, mayhem clear.
um2802 is offline
post #26 of 32 (permalink) Old 01-25-2019, 05:58 PM
Ashcroft's Avatar
Rep: 86 (Unique: 69)
This could be a case of air trapped in one of the rads. That loop should be producing over 200l/h with no trouble.
The mechanical flow metres from AC are pretty reliable so though it's always possible a fault exists, the fact that a reading is provided at all suggests there could be other issues.
Large air bubbles can produce low and variable flow rates.
Please ensure to let us know what you find out.
Ashcroft is offline
post #27 of 32 (permalink) Old 02-01-2019, 01:58 AM - Thread Starter
um2802's Avatar
Rep: 0
Hi there,
Small update, i just order a new pump - same vario - and another flow-meter.
When received, i will change the FM position to see any behavior modification.
um2802 is offline
post #28 of 32 (permalink) Old 02-10-2019, 10:04 AM - Thread Starter
um2802's Avatar
Rep: 0
Ok, some update :
I change the next items : gpu WB - i remove the phantek strix block and replaced with ek strix wb, the flow-meter was replaced with same model and the pump was replaced with D5 vario pump from AC.
The result : at the power the sistem, the flow it is around 212 L/h and decrese around 195.5 L/h where is stabilize until now - 45 min from power up.
Much better i said, but i really do not have any ideea the initial manifestation has been generated from.
um2802 is offline
post #29 of 32 (permalink) Old 02-10-2019, 11:24 AM
Shooting down fallacies
ciarlatano's Avatar
Rep: 404 (Unique: 271)
Ok, some update :
Isn't the EK a slightly more restrictive than the Phanteks? Not sure why you would replace a Phanteks block with an EK block, especially when your issue was flow problems.
ciarlatano is online now
post #30 of 32 (permalink) Old 02-10-2019, 12:04 PM - Thread Starter
um2802's Avatar
Rep: 0
I check the pump - nothing wrong - the old one, i check the flow-meter(old) - nothing wrong with that too, so i think the wb could be the issue.
um2802 is offline
