Weird behave of D5 ..... any ideea? - Overclock.net - An Overclocking Community
post #1 of 32 (permalink) Old 01-22-2019, 07:03 AM - Thread Starter
um2802 Level 1
um2802's Avatar
I have very weird behave of D5 pump:
- power up the system, all ok, the pump it is at 4800 rpm with flow around 80L / h, and after 30 min arrive at 50 / 55L/h
- the system it is in pictures, i know i use a lot of 90/45 adapters, but ***, really choke the pump like this?
- i use one quadro with simple flow-meter from aq
- the rad = 2 xspc 360 / 50mm
It is pump defective?
The flow-meter defective ?
Or i do something wrong?
Thank you in advance
um2802 is offline
post #2 of 32 (permalink) Old 01-22-2019, 07:26 AM
Shooting down fallacies
ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about
ciarlatano's Avatar
Is it a PWM or Vario D5?
ciarlatano is offline
post #3 of 32 (permalink) Old 01-22-2019, 07:31 AM
broodro0ster Level 1
broodro0ster's Avatar
I have a lot 90's as well in my build. And 2x GTS 360's rads. I get around 200lph at 4800rpm, so something is off.
Does your pump sound strange?
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
post #4 of 32 (permalink) Old 01-22-2019, 09:16 AM - Thread Starter
um2802 Level 1
um2802's Avatar
Regular pump, molex for power and 3pins for monitoring.
Pump working normal, no strange sound, no buzzing no nothing, no weird vibration.
um2802 is offline
post #5 of 32 (permalink) Old 01-22-2019, 12:59 PM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Which D5 exactly haven't seen one with three wire to board
And also which port are you using a water pump port or chassis fan port..?
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
post #6 of 32 (permalink) Old 01-22-2019, 02:58 PM - Thread Starter
um2802 Level 1
um2802's Avatar
It is one old ek - lowarra mark on it - with red arrow on the position 5.
The pump it is connect direct on the molex from psu, and the blue wire with 3 pins fan connector go to fan 4 connector from Quadro AQ.
That 3 pins connector have only 1 wire on it
The pump go all time full - 4827 rpm - no matter i move the slider for fan 4 from Quadro.
um2802 is offline
post #7 of 32 (permalink) Old 01-22-2019, 03:34 PM
ThrashZone's Avatar
Hi,
2 molex wires for power and 1 wire for rpm feedback to a fan port = 3 wire lol okay
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #8 of 32 (permalink) Old 01-22-2019, 06:00 PM
I don't even like Linux
cmpxchg8b is an unknown quantity at this point cmpxchg8b is an unknown quantity at this point
cmpxchg8b's Avatar
Okay so we've established that this is a vario pump - not PWM. That takes funky BIOS/software out of the equation.
So you're saying that the flow drops from 80 to 50 L/h, but the pump RPM readout stays at 4800 RPM all the time?
I would suspect the flow meter. D5 pumps are pretty reliable, and if you aren't hearing any suspicious noises out of the pump, it's fine.
cmpxchg8b is offline
post #9 of 32 (permalink) Old 01-23-2019, 12:24 AM - Thread Starter
um2802 Level 1
um2802's Avatar
Yes, when power up the pc, the flow it is around 80L/h and slowly, in around half of hour go down around 50 - 56L/ h.
I think to flow-meter too, but it is a spinning propeller, nothing more, it is high-flow sensor from AQ, the only one who is compatible with quadro.
But still, the pump claim to work at 1500L / h, from that to 50L/h, it look like i have dirt inside loop
The rad are new, cpu / gpu wb was opened and clean.
No idea from where to start diagnose that situation
um2802 is offline
post #10 of 32 (permalink) Old 01-23-2019, 09:03 AM
ThrashZone's Avatar
Hi,
I'd ditch the flow meter and just use a temp sensor instead a lot more useful.
Try to back the dial down just a tad from
Over turning I have a d5 watercool vario not installed anymore but it did not like to be turned to far past 5 or it would actually slow down
Tap it and it sped up figured it was a defect just not worth rma to Germany so it's on wall of shame now as unreliable.
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
