High Temperatures On Custom Loop? - Overclock.net - An Overclocking Community
Old 01-22-2019, 10:14 PM - Thread Starter
Programmer
BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about BradleyW has a spectacular aura about
BradleyW's Avatar
My CPU hits up to 92c during Prime95 "AVX" SmallFFT stress testing.
Here are my specs:
9900K 5GHz HT 1.34v @ AVX LOAD
Custom loop:
EK Supremacy CPU block
EK D5 Pump, EK Res
Phobya 420mm RAD (NF A14's)
Phobya 360mm RAD (NF F12's P/P)
Mayhems X1 Clear
Flow rate is good, no air in the system, ambient around 16 - 18c.
Rad's and block are around 4 years old.
Cleaned once a year with vinegar, hot water, lots of shaking and a final distilled water flush.
Some oxidation can be seen inside the RAD's copper surface as you look through the inlet ports.
Intel Core i9 9900K HT 5GHz
GIGABYTE Z390 Ultra
AMD ASUS STRIX OC VEGA 64
G-Skill Trident 2x8GB DDR4 4000MHz
Samsung EVO NVM.e 250GB
SeaSonic 1250W Gold
Corsair 900D + Custom Loop.
BradleyW is offline
Old 01-23-2019, 03:26 AM
broodro0ster Level 1
broodro0ster's Avatar
Do you have a watertemp sensor?
It's probably fine. Small FFT with AVX generates so much heat it cannot escape the small die quickly enough. The only way to increase heat transfer is by die direct cooling.
I couldn't even do 5GHZ AVX prime testing on my 8700k before it was delidded. I would thermal after 2 minutes.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Corsair Vengeance LPX 3000C15
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
Dual Hardware Labs Nemesis 360GTS with FD Venturi HP-12 PWM fans
EK D5 PWM
EK 1080 Strix waterblock + backplate
Fractal Design Define R6
Operating System
Windows Pro 10
Acer XB271HU 1440p 165hz IPS
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Steel Series QCK Heavy
Audio
Sennheiser HD598 + ModMic 4.0
broodro0ster is offline
Old 01-23-2019, 05:03 AM - Thread Starter
Programmer
BradleyW's Avatar
If the heat can't escape the die fast enough, that will be bottlenecking the loop's performance to a degree.
As for the inside of my radiators, they have turned green like the statue of liberty. I assume this is oxidation and won't effect thermal performance?
I don't have a water temperature sensor fitted.
GIGABYTE Z390 Ultra
SeaSonic 1250W Gold
BradleyW is offline
Old 01-23-2019, 05:21 AM
Zammin
Zammin's Avatar
Yeah I agree with broodro0ster, small FFTs AVX is brutal, especially on the already toasty 9900k. From my understanding the soldered TIM doesn't deal with high heat very well, I remember Gamers Nexus talking about how that is one of the main reasons for liquid metal being much better. I personally don't use P95 AVX anymore. My testing suite is usually a few hours of AIDA64 and RealBench as well as a few real world use cases.
I highly recommend installing a temperature sensor, if you have a motherboard with temperature sensor plugs like the ASUS Maximus series you can just get a G1/4 plug type sensor from XSPC, Barrow etc for under $10 and install it somewhere in your loop. I personally run two in my main system, one before the radiators and one after, but even having just one is better than none. It gives you an important performance metric for gauging how well your loop is working and also allows you to control your fans based on water temp.
As for the green in the radiators, I'm not 100% sure but I think a little bit isn't unusual, but a lot might be copper corrosion or oxidisation? I notice that when I buy a new radiator the inside normally has a slight amount of greenish discoloration in some areas when I look through the ports, but not much. It might be worth trying something like Mayhems Blitz Part 1 if it's severe. I could be wrong about this though.
System Specs: Lian Li PC-011 Dynamic - ROG Maximus X Code - Watercooled Intel 8700k (5Ghz) - Watercooled Strix GTX 1080Ti OC (2050-2063Mhz) - G. Skill Trident Z RGB 3200Mhz 32GB - Seasonic X-1050W PSU - Intel 600P NVME SSD
Zammin is offline
Old 01-23-2019, 05:27 AM
Hmmm, I don't have experience with oxidation in radiators. I bet it will affect thermal performance to some degree, but I don't know how much.
Mayhems blitz should clean this up. Or a vinegar + salt mix if you don't want to buy Blitz. Just make sure to rinse it very good after the process.
My Rig
(18 items)
Intel i7 8700k
Asus Hero X
MSI 1080TI Gaming X
Samsung 970 EVO
Samsung 850 EVO
Corsair RM850X
EK Supremacy EVO
EK D5 PWM
Operating System
Windows Pro 10
Keyboard
Corsair K70
Mouse
Zowie FK-2
Mousepad
Audio
Old 01-23-2019, 08:30 AM
Overclocker
Edge0fsanity Level 1
Edge0fsanity's Avatar
those temps are fine, in fact rather good given the voltage. I hit similar temps at 1.31v 5.1ghz non avx small fft p95 on my 9900k. 23c ambient. This is with an EK velocity block and 2 EK PE 360 rads.
btw, don't test your 9900k with p95 avx small fft, way too stressful for any real world scenarios. Use 1344k in place ffts for avx testing in p95 and use in place small fft with avx disabled for non avx testing.
Singularity Cases Spectre
Intel 9900k @ 5.2ghz 1.365v
Nvidia 2080 TI SLI @ 2130mhz
G.Skill Trident Z memory 2x8gb 4000mhz 16-17-17-28 1.45v
Gigabyte z390 Aorus Master Motherboard
EVGA 1200w P2 psu
Custom waterloop
Edge0fsanity is offline
Old 01-23-2019, 09:30 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Yeah I'd use a more realist test
Real bench is okay
I'd use Blender and it's free demo rendering files classroom is a very good 10-14 minute test that can be repeated if one uses render animation instead of render image and cancel when ever one wants too more stressful that cinebench.
https://www.blender.org/
https://www.blender.org/download/demo-files/
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is offline
Old 01-23-2019, 10:15 AM
Almost Canadian
OutlawII Level 1
OutlawII's Avatar
I use real bench and aida 64 I haven't used prime for years don't really see the point in it being it does not represent any kind of real world usage scenario for me. If it passes both of my tests I fire up some games and go from there.
OutlawII is offline
Old 01-23-2019, 10:27 AM
Shooting down fallacies
ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about ciarlatano has a spectacular aura about
ciarlatano's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Real bench is okay
I'm with you two. I don't see the fascination with P95. It's like putting new tires on your car and testing them by repeatedly driving headlong into a telephone pole.
ciarlatano is offline
Old 01-23-2019, 10:36 AM
ThrashZone's Avatar
Hi,
I'd say buying new tires and burning them up and going no where
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
