Broken EK Rad Barb - Page 2 - Overclock.net - An Overclocking Community
Broken EK Rad Barb
post #11 of 93 (permalink) Old 01-29-2019, 07:12 AM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
Might check with an actual plumber.
That was my next thought. Will hit up Home Depot or a Radiator store and see if I can find something. Kinda figured I was SOL as I tried multiple EK extenders with nothing working.
Anything I’ve tried never had a tight enough seal causing a leak.
Searched online but only answers I’ve seen have said contact EK, since that didn’t work out I figured I’d try here.
Sent from my iPhone using Tapatalk
Shawnb99 is offline
post #12 of 93 (permalink) Old 01-29-2019, 07:19 AM
Overclocker in training
ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough ThrashZone will become famous soon enough
ThrashZone's Avatar
Hi,
Plumber should be able to solder... something there to connect the g1/4" fitting too
I believe my ek 280p rads and a couple 240mm rads have brass couplers on them so the g1/4" fitting mounted to it and not directly to the rad it's self they were same g1/4" to rad and same on the coupler too so not sure what was up with that.
i9-7900x With evo and koolance vrm water blocks
ASUS Prime X299 Deluxe
Trident Z 3600C16 4x8gb's
Samsung 850 Pro 256gb for os and 500gb evo for favorite games plus other wd hdd's for data and backup's
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
redragon
i7-5930k with evo and koolance vrm water blocks
X99 Sabertooth
Trident-Z 3200C14 4x8gb's
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
VapeWild RazzleBerry 50-50-3mg
ThrashZone is online now
post #13 of 93 (permalink) Old 01-29-2019, 07:29 AM
EKWB Forum Rep
EKJake Level 1
EKJake's Avatar
Quote: Originally Posted by Shawnb99 View Post
Here’s with the fitting still attached.
Start a new support ticket detailing you received the wrong piece and send me a PM with that ticket number. I'll follow up on this and make sure we get you the right piece.
EKJake is offline
post #14 of 93 (permalink) Old 01-29-2019, 07:32 AM
EKWB Forum Rep
EKJake Level 1
EKJake's Avatar
Hi,
Don't hold your breath on a ek rep appearing
Shun the non believer!
EKJake is offline
post #15 of 93 (permalink) Old 01-29-2019, 07:35 AM
ezveedub is an unknown quantity at this point ezveedub is an unknown quantity at this point
ezveedub's Avatar
Wait...the piece that you have broken is threaded into the radiator end just like the compression fitting is? If so, then EK should have that piece available. I would unscrew the other insert and send that picture to EK for them to see the actual part.
Sent from my iPhone using Tapatalk Pro
Intel Processor
Z270X-Gaming 9
MSI GeForce GTX 1080 Ti SEA HAWK EK X
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
HAF 932
Operating System
Windows 10
ezveedub is offline
post #16 of 93 (permalink) Old 01-29-2019, 07:41 AM
ThrashZone's Avatar
Hi,
The only thing I believe is ek should pull all cryofuel premix it is defective
https://www.overclock.net/forum/61-w...ned-clear.html
https://www.overclock.net/forum/1806...s-deal-ek.html
https://www.overclock.net/forum/1806...oolants-5.html
Optical Drive
LG Blu-Ray WH16NS40
evga 1200P2
corsair 450D
Operating System
win-7 pro & 10 pro
Keyboard
Mouse
redragon
X99 Sabertooth
EVGA 1000w P2
Corsair 450D
Operating System
win-7 and 10 pro
Mouse
Red Dragon
eLeaf MELO-3 4ml
SMOK Alien 220w
Operating System
post #17 of 93 (permalink) Old 01-29-2019, 07:48 AM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
Thank you very much
Shawnb99 is offline
post #18 of 93 (permalink) Old 01-29-2019, 07:50 AM
EKWB Forum Rep
EKJake Level 1
EKJake's Avatar
If you consider 3 posts, two of which are older, to be defective, then I can't help you. The actual failure rate comparative to how many bottles we ship is incredibly low. And this is taking into account when people run Solid in aluminum loops or flush with harsh chemicals despite the product instructions. Even so, we still replace the coolant and give everyone benefit of the doubt.
EKWB Forum Rep
EKJake is offline
post #19 of 93 (permalink) Old 01-29-2019, 10:08 AM - Thread Starter
Shawnb99 Level 1
Shawnb99's Avatar
Broken EK Rad Barb
After taking off my radiators, I’m noticing signs of corrosion in them. I’ve only ever used EK fuilds so not sure why it would have any corrosion. Just had them just over 6 months
I can see gunk at the bottom of the rads, is this corrosion or not?
Shawnb99 is offline
post #20 of 93 (permalink) Old 01-29-2019, 10:12 AM
ezveedub's Avatar
Any pics? Corrosion as in green corrosion?
Intel Processor
Z270X-Gaming 9
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
HAF 932
Operating System
Windows 10
ezveedub is offline
