Broken EK Rad Barb - Page 3 - Overclock.net - An Overclocking Community
Broken EK Rad Barb
post #21 of 238 (permalink) Old 01-29-2019, 09:28 AM - Thread Starter
Shawnb99's Avatar
Rep: 24 (Unique: 16)
Quote: Originally Posted by ezveedub View Post
Any pics? Corrosion as in green corrosion?
Sent from my iPhone using Tapatalk Pro
Nothing green, looks black. Could be the paint scrapped off I guess
Just noticed this on my second Radiator. I assume I have to replace this as it’s clearly bent. Not sure how that happened.
Looks like I have to buy a new rad no matter what now unless EK will replace it for that.
My Baby
(24 items)
Delidded Direct Die I9 9900K
ASUS Maximus XI Apex
EVGA FTW3 Hydro Copper GeForce RTX 2080 Ti
G.SKILL TridentZ Series 16GB DDR4 3600 F4-3600C15D-16GTZ
2x Samsung 970 EVO Plus 1TB
Asus Hyper M.2 card
2 x Intel 660P 2TB
Seasonic PRIME Ultra 1000 Titanium
Watercool HEATKILLER IV PRO
2x Swiftech MCP35X2 with MCP35X2 Heat Sink
2x Hardware Labs Black Ice Nemesis 360GTR
2x Hardware Labs Black Ice Nemesis 360GTS
Aquacomputer aqualis XT 450 ml with nano coating
9x Noctua NF-S12A PWM
2x Noctua NA-A15 PWM
24x EK Vadar F4120ER
Case Labs Magnum M8 with Pedestal
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Mr. Speakers Aeon Closed
Audio
Geek Pulse Inifnity DAC/AMP
Audio
Cavalii Audio Liquid Carbon HPA
Other
Aquacomputer Aquaero XT
Shawnb99 is offline
post #22 of 238 (permalink) Old 01-29-2019, 09:33 AM
ezveedub's Avatar
Rep: 143 (Unique: 101)
I don’t see any corrosion...just scraped paint. You know those radiator ends are covers and the insert removed is just aligned in the hole and screwed in the end tank threaded...which I’m sure the you can move to get the threaded insert back in.
i9 9900K
Gigabyte Aorus Master Z390
EVGA RTX2080 Gaming XC Ultra
G.Skill Trident 3200
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Gigabyte Z390 Aorus Master
Nvidia GTX1080Ti
G.Skill SNIPER 12GB 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800)
G.Skill RGB DDR4-3200
Kingston HyperX SSD
Optical Drive
LG WH10LS30 BD burner
Optical Drive
TSH663B DVD burner
Seasonic SSR-750PD Flagship Prime Series 750W Platinum
EK-Supremacy EVO - Nickel
XSPC RX360 radiator
EK WB D-BAYD5 PWM reservoir
CoolerMaster HAF 932
Operating System
Windows 10 Pro 64bit
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Gigabyte Z370 AORUS Gaming 5
Nvidia GTX 1070 FE
G.SKILL TridentZ RGB Series PC4 24000
Samsung EVO 850
Rosewill Quark Series 750W Full Modular Gaming Power Supply with LED Indicator
EK-FB GA Z270/Z370 GAMING Monoblock - Nickel
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #23 of 238 (permalink) Old 01-29-2019, 09:38 AM
ლ(╹ε╹ლ)
Rep: 176 (Unique: 137)
The internal fin array can be moved and is held on by those inserts.
Duality92 is offline
post #24 of 238 (permalink) Old 01-29-2019, 09:38 AM - Thread Starter
Shawnb99's Avatar
Ok good, I was worried for second there.
That’s good to know I can move it back. Saves me a major headache. Thanks.
I’ll see if I can fix it then
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #25 of 238 (permalink) Old 01-29-2019, 09:39 AM
ezveedub's Avatar
That I know....it’s OP that doesn’t from his post.
i9 9900K
Samsung EVO 960
Samsung EVO 950
Corsair AX-1200
CaseLabs M8
Operating System
Windows 10 Pro
i7 9700k
Nvidia GTX1080Ti
Kingston HyperX SSD
Optical Drive
Optical Drive
TSH663B DVD burner
XSPC RX360 radiator
Operating System
Acer GD235HZbid
Keyboard
Ducky Mechanical
8600K
Nvidia GTX 1070 FE
Samsung EVO 850
Lian Li O11 Dynamic
Operating System
Windows 10
ezveedub is offline
post #26 of 238 (permalink) Old 01-29-2019, 09:44 AM
Invalid Media
J7SC's Avatar
Rep: 27 (Unique: 13)
Last weekend while taking apart my build to add a new GPU, I was attempting to an EK-ACF 13/19mm fitting one of the extender thingy on the radiator had a price broke off.
Finding a replacement has been nothing but a headache.
Attempted to buy a replacement from Performance-PC’s only to be the wrong one, contacted EKWB only for them to send me the same wrong part. At this point I may have to buy a new rad all to replace a $2 part
Anyone know of any other options besides a new rad? Am looking to replace the extender thingy on the rad where the fittings screw into. There are 2 on each road, I broke one and now need to replace it.
Not sure why it’s been such a hassle.
I’ve tried other EK extenders, I’ve tried going by the radiators description page and still can’t get the right part.
Any help or suggestions would be appreciated.
...if the EK rep doesn't come through (per above posts), you might try an automotive radiator repair shop - I had computer-'specific' rads fixed there before.
J7SC is offline
post #27 of 238 (permalink) Old 01-29-2019, 09:49 AM - Thread Starter
Shawnb99's Avatar
Thanks. Yeah that was my next step.
Thanks for the suggestion.
I assume they changed the extenders on the Radiators in the last 6 months and that’s likely the confusion. Hopefully they can sort it out soon. If not I’ll have a task for the weekend
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
post #28 of 238 (permalink) Old 01-29-2019, 09:53 AM
Overclocker in training
ThrashZone's Avatar
Rep: 72 (Unique: 55)
Hi,
Yeah a radiator shop would be best.
i9-9940x With Heatkiller IV Pro and VRM Plexi-Copper water block
ASUS x299 Rampage VI Apex
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
ASUS VG248QE 24" 144Hz
Keyboard
Logitech G910 Orion spectrum
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
AOC G2460PG 24"G-Sync 144Hz
Mouse
Red Dragon Perdition
Audio
eLeaf MELO-3 4ml
Operating System
ThrashZone is offline
post #29 of 238 (permalink) Old 01-29-2019, 10:14 AM
ThrashZone's Avatar
Hi,
Doesn't look like your rad came with these inserts
Name:	ek rad inserts.JPG
Optical Drive
LG Blu-Ray WH16NS40
evga 1200-P2
Operating System
Keyboard
Mouse
Redragon Perdition
Audio
X99 Sabertooth
EVGA 1000-P2
Operating System
Mouse
Audio
eLeaf MELO-3 4ml
Operating System
post #30 of 238 (permalink) Old 01-29-2019, 10:25 AM - Thread Starter
Shawnb99's Avatar
Quote: Originally Posted by ThrashZone View Post
Hi,
My issue is I broke one of those and need a replacement, wrong one was sent and we’re now sorting it out.
Pic asking about corrosion was with them removed, just wanted to be extra safe.
My Baby
(24 items)
Asus Hyper M.2 card
2 x Intel 660P 2TB
Asus PG28Q
Keyboard
Das Keyboard 5Q
Mouse
Swiftpoint Z
Audio
Audio
Audio
Other
Shawnb99 is offline
